In an attempt to prevent automatic snap updates, I have resorted to installing LXD’s snap locally so that snap won’t refresh it.
However I have noticed that when the snap is locally installed, LXC commands no longer work, however LXD commands remain functional.
Following is a freshly created Ubuntu Server VM:
$ snap list
core18 20201210 1944 latest/stable canonical✓ base
lxd 4.0.5 19188 4.0/stable/… canonical✓ -
snapd 2.48.2 10707 latest/stable canonical✓ snapd
$ lxd --version
4.0.5
$ lxc --version
4.0.5
$ lxc list
If this is your first time running LXD on this machine, you should also run: lxd init
To start your first instance, try: lxc launch ubuntu:18.04
Both LXD and LXC commands work normally as expected. However after locally installing the snap:
$ snap download lxd --channel=4.0/stable
Fetching snap "lxd"
Fetching assertions for "lxd"
Install the snap with:
snap ack lxd_21029.assert
snap install lxd_21029.snap
$ snap install lxd_21029.snap --dangerous
lxd 4.0.7 installed
$ snap list
lxd 4.0.7 x1 4.0/stable/… - -
LXC commands stop working:
$ lxd --version
4.0.7
$ lxc --version
Command 'lxc' not found, but can be installed with:
apt install lxd-installer # version 1, or
apt install lxd # version 1:0.9
Any help is appreciated.
