Hi all,
today I run into 2 issues with my ZFS pool.
First I found that my ZFS pool was running out of space:
$ lxc storage list
| lxd | | zfs | lxd | 13 |
$ zpool list
NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
lxd 19.9G 18.6G 1.30G - 77% 93% 1.00x ONLINE -
Digging a little bit more, I found that a container moved to another host is still eating space under the “deleted” path:
# zfs list
lxd 18.6G 698M 24K none
lxd/containers 14.2G 698M 24K none
lxd/deleted 3.08G 698M 24K none
lxd/deleted/containers 3.08G 698M 24K none
lxd/deleted/containers/c8ad47df-a92d-4b4c-b0fb-09fbb718da27 3.08G 664M 2.32G none
I’m not sure, but I suppose that something happened due to lack of space, and LXD was unable to delete the moved container.
Is it possibile?
Is there a chance to reclaim the space?
Then, I decided to grow the ZFS pool, so I first resized the underlying disk (on AWS) from 20G to 40G.
Note that I had already run these same commands previously on the same host without any issue, but this time it din’t work as expected.
Here are the commands I executed, the drive is: /dev/nvme0n1p1
$ zpool status -v
pool: lxd
state: ONLINE
scan: scrub repaired 0B in 0h3m with 0 errors on Sun May 12 00:27:19 2019
NAME STATE READ WRITE CKSUM
lxd ONLINE 0 0 0
nvme0n1 ONLINE 0 0 0
errors: No known data errors
$ parted -l
Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you
can fix the GPT to use all of the space (an extra 41943040 blocks) or continue
with the current setting?
Fix/Ignore? Fix
$ growpart /dev/nvme0n1 1
CHANGED: partition=1 start=2048 old: size=41940959 end=41943007 new: size=83883999,end=83886047
$ fdisk -l /dev/nvme0n1
Disk /dev/nvme0n1: 40 GiB, 42949672960 bytes, 83886080 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 847423D4-75AD-0444-9E63-8A4319EF6750
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 83886046 83883999 40G Solaris /usr & Apple ZFS
$ zpool list
lxd 19.9G 19.2G 753M - 81% 96% 1.00x ONLINE -
$ zpool online -e lxd nvme0n1
cannot expand nvme0n1: cannot relabel '/dev/nvme0n1': unable to read disk capacity
I tried do execute partprobe again, but it didn’t work.
Any idea?
Thank you.
Alessandro
