Issues when running netplan in a Ubuntu Noble 24.04 container
I tried the following both on a Ubuntu 22.04 host as well as on a Ubuntu 24.04 host with the same result.
When installing a guest (container) based on Ubuntu 24.04 and then try to run any netplan command (such as netplan apply, or netplan try), I get the following error message:
Failed to send reload request: No such file or directory
Traceback (most recent call last):
  File "/usr/sbin/netplan", line 23, in <module>
    netplan.main()
  File "/usr/share/netplan/netplan_cli/cli/core.py", line 58, in main
    self.run_command()
  File "/usr/share/netplan/netplan_cli/cli/utils.py", line 298, in run_command
    self.func()
  File "/usr/share/netplan/netplan_cli/cli/commands/apply.py", line 63, in run
    self.run_command()
    self.func()
  File "/usr/share/netplan/netplan_cli/cli/commands/apply.py", line 255, in command_apply
    subprocess.check_call(['udevadm', 'control', '--reload'])
  File "/usr/lib/python3.12/subprocess.py", line 413, in check_call
    raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['udevadm', 'control', '--reload']' returned non-zero exit status 1.
This seems to be related to systemd-udevd not running due to /sys not being read-only.
 systemctl status udev
○ systemd-udevd.service - Rule-based Manager for Device Events and Files
     Loaded: loaded (/usr/lib/systemd/system/systemd-udevd.service; static)
    Drop-In: /usr/lib/systemd/system/systemd-udevd.service.d
             └─syscall-architecture.conf
     Active: inactive (dead)
TriggeredBy: ○ systemd-udevd-control.socket
             ○ systemd-udevd-kernel.socket
  Condition: start condition unmet at Sun 2024-09-01 20:42:52 UTC; 24min ago
       Docs: man:systemd-udevd.service(8)
             man:udev(7)
Sep 01 20:42:52 plesk2 systemd[1]: systemd-udevd.service - Rule-based Manager for Device Events and Files was skipped because of an unmet condition check (ConditionPathIsReadWrite=/sys).
I looked through the discussions available on this topic. Frankly, I didn’t find a definitive answer on what to do about this. But I read on multiple occasions that making the container privileged and setting security.nesting to True should solve this issue albeit not being a recommended approach. Unfortunately, these configuration settings didn’t do anything for me.
It seems it’s possible to work around the issue by just starting systemd-udevd manually,
/lib/systemd/systemd-udevd --daemon
I don’t seem to have this issue on a Ubuntu 22.04 guest, by the way. Only 24.04 is affected.
Your help is appreciated.
Hi!
Can’t seem to replicate.
$ incus launch images:ubuntu/24.04/cloud netplan
Launching netplan
$ incus exec netplan -- netplan apply
The logs:
There’s a warning on OpenVSwitch, but it’s just an unrelated warning.
$ incus exec netplan -- tail -f /var/log/syslog
2024-09-01T22:07:09.868658+00:00 netplan systemd[1]: Reloading finished in 116 ms.
2024-09-01T22:07:09.930919+00:00 netplan systemd-networkd[444]: eth0: Reconfiguring with /run/systemd/network/10-netplan-eth0.network.
2024-09-01T22:07:09.930984+00:00 netplan systemd-networkd[444]: eth0: DHCP lease lost
2024-09-01T22:07:09.931463+00:00 netplan systemd-networkd[444]: eth0: DHCPv6 lease lost
2024-09-01T22:07:09.955913+00:00 netplan systemd-networkd[444]: eth0: DHCPv4 address 10.10.10.110/24, gateway 10.10.10.1 acquired from 10.10.10.1
2024-09-01T22:07:09.957398+00:00 netplan systemd-networkd[444]: eth0: Configuring with /run/systemd/network/10-netplan-eth0.network.
2024-09-01T22:07:09.957512+00:00 netplan systemd-networkd[444]: eth0: DHCP lease lost
2024-09-01T22:07:09.961236+00:00 netplan systemd[1]: netplan-ovs-cleanup.service - OpenVSwitch configuration for cleanup was skipped because of an unmet condition check (ConditionFileIsExecutable=/usr/bin/ovs-vsctl).
2024-09-01T22:07:09.964921+00:00 netplan systemd-networkd[444]: eth0: DHCPv6 lease lost
2024-09-01T22:07:09.985974+00:00 netplan systemd-networkd[444]: eth0: DHCPv4 address 10.10.10.110/24, gateway 10.10.10.1 acquired from 10.10.10.1
2024-09-01T22:07:40.020011+00:00 netplan systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Ctrl+C
In your case I see a reference to plesk. Does the simplest possible example shown above work for you?
I’m having a similar issue can’t get it to run netplan --diff
root@unifi:~# netplan status --diff Traceback (most recent call last): File "/usr/sbin/netplan", line 23, in <module> netplan.main() File "/usr/share/netplan/netplan_cli/cli/core.py", line 58, in main self.run_command() File "/usr/share/netplan/netplan_cli/cli/utils.py", line 298, in run_command self.func() File "/usr/share/netplan/netplan_cli/cli/commands/status.py", line 77, in run self.run_command() File "/usr/share/netplan/netplan_cli/cli/utils.py", line 298, in run_command self.func() File "/usr/share/netplan/netplan_cli/cli/commands/status.py", line 833, in command self.state_diff = diff_state.get_diff(self.ifname) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/share/netplan/netplan_cli/cli/state_diff.py", line 107, in get_diff self._analyze_routes(config, iface) File "/usr/share/netplan/netplan_cli/cli/state_diff.py", line 325, in _analyze_routes netplan_routes = self._normalize_routes(netplan_routes) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/share/netplan/netplan_cli/cli/state_diff.py", line 438, in _normalize_routes if ip_prefix[1] == '32' or ip_prefix[1] == '128':
Could you show the full backtrace please? You’ve missed off the most important part from the backtrace, which is the exception itself. Also, can you show how you created the container, and the netplan yaml file itself?
I’ve just tried netplan status --diff in an existing Ubuntu 24.04.1 container and it works for me, so there’s something about your container that’s causing the issue. (The host is 22.04.5 and I’m using incus LTS, version6.0.2-202409162053-ubuntu22.04)
I have exact the same problem. For me the host is proxmox 8.3.1 and guest LXC clean ubuntu 24.04 problem does not exists. When I do apt update && apt upgrade your problem starts to exist. I have not found the solution except starting udev daemon manually.
For clean ubuntu 24.10 problem existing from the beginning.
Hello, same problem for me when running netplan in a privileged container:
lxc launch ubuntu:24.04 noble -c security.privileged=true
lxc exec noble -- netplan apply
Causes the following error:
    netplan.main()
    self.run_command()
  File "/usr/share/netplan/netplan_cli/cli/utils.py", line 332, in run_command
    self.func()
  File "/usr/share/netplan/netplan_cli/cli/commands/apply.py", line 62, in run
    self.run_command()
    self.func()
  File "/usr/share/netplan/netplan_cli/cli/commands/apply.py", line 254, in command_apply
Still the same issue on Ubuntu 25.04 , inside an LXC container :
The udev service is not started:
# systemctl status udev
└─ ConditionPathIsReadWrite=/sys was not met
# checking this /sys mount :
mount -v | grep /sys
sysfs on /sys type sysfs (ro,nosuid,nodev,noexec,relatime)
The “netplan apply” command fails:
# netplan apply
subprocess.check_call([‘udevadm’, ‘control’, ‘–reload’]) ~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
File “/usr/lib/python3.13/subprocess.py”, line 419, in check_call
subprocess.CalledProcessError: Command ‘[‘udevadm’, ‘control’, ‘–reload’]’ returned non-zero exit status 1.
checking with “strace” why it failed (on some inexisting file):
# strace netplan apply
connect(3, {sa_family=AF_UNIX, sun_path=“/run/udev/control”}, 20) = -1 ENOENT (No such file or directory)
which indicates that indeed the cause is that the “udev” service is not running. So:
starting that daemon manually:
# /lib/systemd/systemd-udevd --daemon
# netplan apply
so no more error, and this socket seems indeed to be present now:
# ls -l /run/udev/control
srwxr-xr-x 1 root root 0 Aug 22 17:44 /run/udev/control
The problem is that “/sys” of type “sysfs” cannot be mounted read-write; and that is exactly a condition for the service-startup of “udev”: see the file “/usr/lib/systemd/system/systemd-udevd.service“ :
See this discussion about “sysfs”: https://groups.google.com/a/lists.linuxcontainers.org/g/lxc-users/c/8PIxOpqsl5E?pli=1
Anyhow, by tweaking the service-definition file “/usr/lib/systemd/system/systemd-udevd.service“ (remove this condition chec of sys), that service correctly starts now:
# vi /usr/lib/systemd/system/systemd-udevd.service
# systemctl daemon-reload
# systemctl start udev
Active
# netplan apply
# echo $?
0
I got the same issue. It got resolved in the following way.
I did a ip a and checked all the network adapters. There were 3 adapters. lo, eno1 and wlp1s01.
When I did sudo nano /etc/netplan/00-xxxx.yaml The YAML file was created as part of the installation whizard. For some reason it has named the adapter wlp2s01. Like below
network:
version: 2
renderer: networkd
wifis:
wlp2s0:
dhcp4: true
access-points:
"YourSSID":
password: "YourPassword"
key-management: "psk"
I corrected the adapter name to the correct one
network:
version: 2
renderer: networkd
wifis:
wlp1s0:
dhcp4: true
access-points:
"YourSSID":
Then ran sudo netplan apply and no errors came this time.
Note: The Yaml I have put is tab sensitive, so make sure you tab it appropriately, otherwise you will get other errors related to invalid YAML.
