Spec: Jammy jelly fish and lxd 5.10/stable.
Juju bootstrapping failed ‘waiting for address’. I have an assumption that it is a network error. It seems like there is no IPV4 assignment for the container I newly created.
I tried to use lxd 5.0/stable and encountered a similar issue.
I also launched an Ubuntu container, which doesn’t have an IP address assigned to it.
Appreciate your help
Are there are any issues with lxd and encrypted disks? I have a newly installed Jammy and the only set up I have is that my Secure Boot is disabled
When I launched, the containers don’t get a network address. Unclear why at this point. On jammy with 5.0/stable and 5.10/stable. The default profile has eth0.
IP - the default parameters are preferred, and the network bridge should be set to have no IPv6 addresses since Juju does not support IPv6 addresses with LXD:
lxc network set lxdbr0 ipv6.address none
To allow traffic from lxdbr0 interface to the LXD host and for traffic from lxdbr0 to be routed to the external network without allowing all external inbound traffic:
sudo ufw allow in on lxdbr0
sudo ufw route allow in on lxdbr0
sudo ufw route allow out on lxdbr0
Try different LXD versions
Failed
My machine is encrypted, and secure boot is disabled. Will it impact any of the installation?
Possible reason for failure:
When I launch LXD - e.g. ubuntu 22.04 or Juju, the containers don’t get a network address. Unclear why at this point. On jammy with 5.0/stable and 5.10/stable. The default profile has eth0.
This set up worked with me when I tried to install Juju in my 20.04. Is this because of the OS version?
