getent passwd and getent group works as expected.
But when I want to login over SSH
Login with SSH key:
LOG:
Mar 10 07:06:05 ah sshd[1727]: fatal: initgroups: me@kanidm.example.com: Invalid argument
No home folder created.
Login with password:
ssh me@ah.incus
me@ah.incus's password:
client_loop: send disconnect: Broken pipe
LOG:
Mar 10 07:02:35 ah unix_chkpwd[1691]: check pass; user unknown
Mar 10 07:02:35 ah unix_chkpwd[1691]: password check failed for user (me)
Mar 10 07:02:35 ah sshd[1688]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=fd42:8eeb:a9a2:85db::1 user=me
Mar 10 07:02:36 ah unix_chkpwd[1692]: could not obtain user info (me)
Mar 10 07:02:36 ah sshd[1688]: Accepted password for me from fd42:8eeb:a9a2:85db::1 port 40356 ssh2
Mar 10 07:02:36 ah sshd[1688]: pam_keyinit(sshd:session): Unable to change GID to 1883861673 temporarily
Mar 10 07:02:36 ah sshd[1688]: pam_unix(sshd:session): session opened for user me(uid=1883861673) by (uid=0)
Mar 10 07:02:36 ah sshd[1688]: pam_systemd(sshd:session): Failed to stat() runtime directory '/run/user/1883861673': No such file or directory
Mar 10 07:02:36 ah sshd[1688]: pam_systemd(sshd:session): Not setting $XDG_RUNTIME_DIR, as the directory is not in order.
Mar 10 07:02:36 ah sshd[1688]: pam_motd(sshd:session): pam_modutil_drop_priv: initgroups failed: Invalid argument
Mar 10 07:02:36 ah sshd[1688]: pam_motd(sshd:session): pam_modutil_drop_priv: change_gid failed: Invalid argument
Mar 10 07:02:36 ah sshd[1688]: pam_motd(sshd:session): Unable to drop privileges
Mar 10 07:02:36 ah sshd[1688]: pam_motd(sshd:session): Unable to change UID to 1883861673 temporarily
Mar 10 07:02:36 ah sshd[1688]: pam_motd(sshd:session): pam_modutil_regain_priv: called with invalid state
Mar 10 07:02:36 ah sshd[1688]: pam_motd(sshd:session): Unable to change UID back to -1
Mar 10 07:02:36 ah sshd[1688]: pam_mail(sshd:session): pam_modutil_drop_priv: initgroups failed: Invalid argument
Mar 10 07:02:36 ah sshd[1688]: pam_mail(sshd:session): pam_modutil_drop_priv: change_gid failed: Invalid argument
Mar 10 07:02:36 ah sshd[1688]: pam_unix(sshd:session): session closed for user me
Mar 10 07:02:36 ah sshd[1688]: fatal: initgroups: me@kanidm.example.com: Invalid argument
It creates the home folders:
drwxr-x--- 2 root root 4096 Mar 10 06:53 a6086074-562e-479d-9a0c-b952504972a9
lrwxrwxrwx 1 root root 42 Mar 10 07:02 me@kanidm.example.com -> /home/a6086074-562e-479d-9a0c-b952504972a
Same with
root@node-incus-1:~# incus exec ah -- su --login me
su: cannot set groups: Invalid argument
It authenticates ok but breaks right after it.
The same setup works when I don’t run it in a system container.
Any pointers please? Thank you.
