I am attempting to install Gitlab which requires certain Kernel parameters to be set. I understand certain parameters are not allowed to be set by containers unless they are privileged but it is my understanding that they should use the host’s settings. I set shmmax
on the host to a value of 17179869184
however in the container I get 18446744073692774399
. Am I missing something?
Off Topic: I’m curious how you’ll be able to get Gitlab to run in a LXC container. Did you run into any issues besides shmmax
Not necessarily, they can be namespaced but be tied to a namespace other than the user namespace. In this case I expect it to be tied to the IPC namespace.
So the kernel effectively gives you a new instance of that code along with its default value for every IPC namespace created but it was deemed unsafe for an unprivileged user to be able to increase the size so you end up with this behavior.
You can try using raw.lxc
to set a lxc.sysctl.kernel.shmmax
config key, this may work in this case.
@lhprojects I deleted the relevant section from the Chef recipe where it was trying to set the Kernel parameters and was able to get it running. That was the only issue so far.
@stgraber Yes after further research, 18446744073692774399
is the default value for shmmax so that makes sense now. I did attempt to set it via raw
however LXC errored out when attempting to set them. I was able to work around this for now by just making Gitlab not attempt to set these parameters. Hopefully upstream will allow this section to be optional so that other LXC users will not experience this issue.
