Kvm nested in LXC, problem accessing /dev/kvm inside lxc - Debian11
Sorry for the ugly format - I try to improve this now…
running on 64bit Debian11 host a lxc container called android-dev. Android Studio requires /dev/kvm for the emulator, therefor this is nested kvm in lxc: Debian11>lxc>qemu/kvm
LXC runs on the debian11 host using a bridge and the config of the container
cat /var/lib/lxc/android-dev/config
# I tried with or without the next line
lxc.include = /usr/share/lxc/config/nesting.conf
# lxc.apparmor.profile = generated
lxc.apparmor.profile = unconfined
lxc.apparmor.allow_nesting = 1
lxc.net.0.type = veth
lxc.net.0.link = br0
lxc.net.0.flags = up
lxc.net.0.hwaddr = 00:16:3e:14:ba:34
lxc.rootfs.path = dir:/var/lib/lxc/android-dev/rootfs
# Common configuration
lxc.include = /usr/share/lxc/config/debian.common.conf
lxc.tty.max = 4
lxc.uts.name = android-dev
lxc.arch = amd64
lxc.pty.max = 1024
# Permit access to /dev/loop*
LXC.cgroup.devices.allow: b 7:* rwm
LXC.cgroup.devices.allow: c 10:237 rwm
# Setup access to /dev/net/tun and /dev/kvm
lxc.mount.entry = /dev/net/tun dev/net/tun none bind,create=file 0 0
lxc.mount.entry = /dev/kvm dev/kvm none bind,create=file 0 0
cat /usr/share/lxc/config/nesting.conf
# Use a profile which allows nesting
lxc.apparmor.profile = lxc-container-default-with-nesting
# Add uncovered mounts of proc and sys, else unprivileged users
# cannot remount those
lxc.mount.entry = proc dev/.lxc/proc proc create=dir,optional 0 0
lxc.mount.entry = sys dev/.lxc/sys sysfs create=dir,optional 0 0
cat /usr/share/lxc/config/debian.common.conf
# This derives from the global common config
# Doesn’t support consoles in /dev/lxc/
lxc.tty.dir =
# When using LXC with apparmor, the container will be confined by default.
# If you wish for it to instead run unconfined, copy the following line
# (uncommented) to the container’s configuration file.
LXC.apparmor.profile = unconfined
# If you wish to allow mounting block filesystems, then use the following
# line instead, and make sure to grant access to the block device and/or loop
# devices below in lxc.cgroup.devices.allow.
LXC.apparmor.profile = lxc-container-default-with-mounting
# Extra cgroup device access
## rtc
lxc.cgroup.devices.allow = c 254:0 rm
## tun
lxc.cgroup.devices.allow = c 10:200 rwm
## hpet
lxc.cgroup.devices.allow = c 10:228 rwm
## kvm
lxc.cgroup.devices.allow = c 10:232 rwm
## To use loop devices, copy the following line to the container’s
## configuration file (uncommented).
LXC.cgroup.devices.allow = b 7:* rwm
cat /etc/lxc/default.conf
lxc.net.0.link = lxcbr0
lxc.net.0.hwaddr = 00:16:3e:xx:xx:xx
on the host
virt-host-validate
QEMU: Checking for hardware virtualization : PASS
QEMU: Checking if device /dev/kvm exists : PASS
QEMU: Checking if device /dev/kvm is accessible : PASS
QEMU: Checking if device /dev/vhost-net exists : PASS
QEMU: Checking if device /dev/net/tun exists : PASS
QEMU: Checking for cgroup ‘cpu’ controller support : PASS
QEMU: Checking for cgroup ‘cpuacct’ controller support : PASS
QEMU: Checking for cgroup ‘cpuset’ controller support : PASS
QEMU: Checking for cgroup ‘memory’ controller support : PASS
QEMU: Checking for cgroup ‘devices’ controller support : PASS
QEMU: Checking for cgroup ‘blkio’ controller support : PASS
QEMU: Checking for device assignment IOMMU support : PASS
QEMU: Checking if IOMMU is enabled by kernel : PASS
QEMU: Checking for secure guest support : WARN (Unknown if this platform has Secure Guest support)
LXC: Checking for Linux >= 2.6.26 : PASS
LXC: Checking for namespace ipc : PASS
LXC: Checking for namespace mnt : PASS
LXC: Checking for namespace pid : PASS
LXC: Checking for namespace uts : PASS
LXC: Checking for namespace net : PASS
LXC: Checking for namespace user : PASS
LXC: Checking for cgroup ‘cpu’ controller support : PASS
LXC: Checking for cgroup ‘cpuacct’ controller support : PASS
LXC: Checking for cgroup ‘cpuset’ controller support : PASS
LXC: Checking for cgroup ‘memory’ controller support : PASS
LXC: Checking for cgroup ‘devices’ controller support : PASS
LXC: Checking for cgroup ‘freezer’ controller support : FAIL (Enable ‘freezer’ in kernel Kconfig file or mount/enable cgroup controller in your system)
LXC: Checking for cgroup ‘blkio’ controller support : PASS
LXC: Checking if device /sys/fs/fuse/connections exists : PASS
inside android-dev lxc
virt-host-validate
QEMU: Checking if device /dev/kvm is accessible : FAIL (Check /dev/kvm is world writable or you are in a group that is allowed to access it)
QEMU: Checking if device /dev/vhost-net exists : WARN (Load the ‘vhost_net’ module to improve performance of virtio networking)
root@android-dev:/#
Somethings really interesting is that /dev/kvm gets updated when the lxc container gets started:
root@host:/var/lib/lxc/android-dev# ls -la /dev/kvm
crw-rw----+ 1 root kvm 10, 232 Jan 22 20:05 /dev/kvm
root@host:/var/lib/lxc/android-dev# lxc-start android-dev
crw-rw----+ 1 root Debian-exim 10, 232 Jan 22 20:05 /dev/kvm
root@host:/var/lib/lxc/android-dev# lxc-stop android-dev
inside lxc
ls -la /dev/kvm
crw-rw----+ 1 root kvm 10, 232 Jan 22 09:05 /dev/kvm
I saw that the group id in lxc and the host don’t match, because I have most likely installed packages in a different order.
host:
root@host:/var/lib/lxc/android-dev# lsmod | grep kvm
kvm_intel 327680 0
kvm 921600 1 kvm_intel
irqbypass 16384 1 kvm
lxc:
root@android-dev:/# lsmod | grep kvm
kvm_intel 327680 0
root@host:/var/lib/lxc/android-dev# cat /etc/modules
# /etc/modules: kernel modules to load at boot time.
coretemp
ipmi_devintf
ipmi_msghandler
ipmi_si
fuse
vhost_net
kvm_intel
root@android-dev:/# cat /etc/modules
kvm_intel
vhost_net
kvm-intel
How can I get /dev/kvm to be useable within the lxc container?
Security is not an issue, I use the lxc container for pure software package separation purposes.
Help is appreciated.
add to my initial post:
I got from here:
to add
I tried it, but it didn’t work
And I struggle to find out how these permissions work, meaning c10:232 rwm
I found here: https://github.com/lxc/lxd/issues/2718
That it should be possible to run:
lxc config device add CONTAINER kvm unix-char path=/dev/kvm
The problem is that under debian there is no such lxc “wrapper”, there is lxc-config, but the feature set of lxc-config is different.
@stgraber Stephane, do you have an input regarding this?
This means that you can remove your lxc.mount.entry for /dev/kvm and can instead create the device node directly inside of the container.
This should allow you to do mknod /dev/kvm c 10 232 and then chmod 660 /dev/kvm and finally chown root:kvm /dev/kvm.
Creating your own device node in this way will save you from any potential impact on the entry on the host.
Thank you for your input, I adapted the config and added:
to the config file and then run
chmod 777 /dev/kvm
running kvm-ok reports:
kvm-ok
INFO: /dev/kvm exists
KVM acceleration can be used
running virt-host-validate reports:
virt-host-validate
QEMU: Checking if device /dev/net/tun exists : FAIL (Load the ‘tun’ module to enable networking for QEMU guests)
For testing I ran (under root) X and tried android studio, so both virt-host-validate and android studio are not happy yet with the required changes.
Got it working.
config file:
lxc.net.0.hwaddr = 00:16:3e:74:da:31
# lxc.include = /usr/share/lxc/config/debian.common.conf
lxc.tty.max = 4
lxc.arch = amd64
lxc.pty.max = 1024
lxc.cgroup.devices.deny = a
lxc.cgroup.devices.allow = c : m
lxc.cgroup.devices.allow = b : m
lxc.cgroup.devices.allow = c 1:3 rwm
lxc.cgroup.devices.allow = c 1:5 rwm
lxc.cgroup.devices.allow = c 5:0 rwm
lxc.cgroup.devices.allow = c 5:1 rwm
lxc.cgroup.devices.allow = c 1:8 rwm
lxc.cgroup.devices.allow = c 1:9 rwm
lxc.cgroup.devices.allow = c 5:2 rwm
lxc.cgroup.devices.allow = c 136:* rwm
lxc.cgroup.devices.allow = c 10:229 rwm
lxc.cgroup.devices.allow = c 1:7 rwm
inside the host run this
chmod 777 /dev/kvm
mkdir -p dev/net
mknod /dev/net/tun c 10 200
chmod 777 /dev/net/tun
chown root:root /dev/net/tun
I needed to run chmod 777 for android studio to work. chmod 660 might be enough
You must have installed lxc alone (using sudo apt install lxc). The command “lxc config ...” comes from lxd which is a snap package. Install it using sudo snap install lxd.
Hi Jithin,
the issue was resolved before.
No need for LXD, I just used LXC.
Kind regards
Hi, where is located this configuration? if it’s a specific configuration for a CT, where is located the file?
on debian10/11:
/var/lib/lxc/CONTAINER/config
As root on the container:
root@Android10 ~# cat init.sh
chmod 777 /dev/kvm
mkdir -p /dev/net
usermod -aG docker root
usermod -aG docker android
usermod -aG kvm root
usermod -aG kvm android
docker run --privileged -d -p 6080:6080 -p 5554:5554 -p 5555:5555 -e DEVICE=“Samsung Galaxy S10” f48b3c678d6a
got:
root@Android10 ~# docker exec -it nifty_rhodes tail -f /var/log/supervisor/docker-android.stderr.log
The KVM line in /etc/group is: [kvm:x:104:]
If the current user has KVM permissions,
the KVM line in /etc/group should end with “:” followed by your username.
If we see LINE_NOT_FOUND, the kvm gr
More info on configuring VM acceleration on Linux:
General information on acceleration: https://developer.android.com/studio/run/emulator-acceleration.
kvm:x:102:root,android is present into /etc/group
LXC config for container
root@qatesting:/var/lib/lxc/105# cat config
lxc.cgroup.relative = 0
lxc.cgroup.dir.monitor = lxc.monitor/105
lxc.cgroup.dir.container = lxc/105
lxc.cgroup.dir.container.inner = ns
lxc.arch = amd64
lxc.apparmor.raw = mount fstype=fuse,
lxc.mount.entry = /dev/fuse dev/fuse none bind,create=file 0 0
lxc.monitor.unshare = 1
lxc.tty.max = 2
lxc.environment = TERM=linux
lxc.uts.name = Android10
lxc.cgroup2.memory.max = 17179869184
lxc.cgroup2.memory.swap.max = 8589934592
lxc.rootfs.path = /var/lib/lxc/105/rootfs
lxc.net.0.veth.pair = veth105i0
lxc.net.0.hwaddr = B2:C9:5A:55:FC:6A
lxc.net.0.name = eth0
lxc.net.0.script.up = /usr/share/lxc/lxcnetaddbr
lxc.cgroup2.cpuset.cpus = 5,7-8,20-21,26,28,30
lxc.tty.dir =
lxc.apparmor.profile = lxc-container-default-with-mounting
rtc
LXC.cgroup.devices.allow = c 254:0 rm
tun
LXC.cgroup.devices.allow = c 10:200 rwm
hpet
LXC.cgroup.devices.allow = c 10:228 rwm
kvm
LXC.cgroup.devices.allow = c 10:232 rwm
lxc.cgroup.devices.allow = a
lxc.cap.drop =
** uname -a **
Linux qatesting 5.13.19-2-pve #1 SMP PVE 5.13.19-4 (Mon, 29 Nov 2021 12:10:09 +0100) x86_64 GNU/Linux
I’m working on an unprivileged container with fuse=1 and nesting=1 via Proxmox. Could anyone help me?
