Hi, I’ve setup an LXC container where I can successfully run nested virtualization (libvirt).
But for some months following package updates, I can no longer start a VM with Libvirt (Vagrant) inside an LXC container. Libvirtd configuration inside LXC container is default.
I get this error:
Error while attaching new device to domain. Call to virDomainAttachDeviceFlags failed: unsupported configuration: 'virtiofs' requires shared memory
Do you have any solutions that could help me please ?
My Vagrantfile
# Molecule managed
Vagrant.configure('2') do |config|
if Vagrant.has_plugin?('vagrant-cachier')
config.cache.scope = 'machine'
end
config.vm.define "ansible-lvm-2375154-D11" do |c|
# Box definition
c.vm.box = "generic/debian11"
# Config options
c.vm.synced_folder ".", "/vagrant", disabled: true
c.ssh.insert_key = true
c.vm.hostname = "ansible-lvm-D11"
# Network
# instance_raw_config_args
# Provider
c.vm.provider "libvirt" do |libvirt, override|
libvirt.memory = 512
libvirt.driver = "kvm"
libvirt.nic_model_type = "virtio"
libvirt.qemu_use_session = false
libvirt.storage :file, :size => '1G', :device => 'sdb'
libvirt.storage :file, :size => '1G', :device => 'sdc'
libvirt.channel :type => 'unix', :target_name => 'org.qemu.guest_agent.0', :target_type => 'virtio'
end
end
end
LXC config container
# lxc config show gitlab-runner-lxc-molecule-01
image.architecture: amd64
image.description: Ubuntu jammy amd64 (20220606_08:50)
image.os: Ubuntu
image.release: jammy
image.serial: "20220606_08:50"
image.type: squashfs
image.variant: cloud
limits.memory.swap: "false"
linux.kernel_modules: ip_tables,ip6_tables,netlink_diag,nf_nat,overlay,br_netfilter
volatile.base_image: b9bd1a4570080612164741f4b90200ff32762632b421cdb95dd9a44067774395
volatile.cloud-init.instance-id: cadd34de-9176-41fd-9fd8-8bb9868fef09
volatile.idmap.base: "0"
volatile.idmap.current: '[]'
volatile.idmap.next: '[]'
volatile.uuid: fefaf272-81ce-4064-a3d6-c2813477451c
raw.lxc: |
lxc.apparmor.profile=unconfined
lxc.mount.auto=proc:rw sys:rw
lxc.cap.drop=
lxc.cgroup.devices.allow=a
security.nesting: "true"
security.privileged: "true"
security.syscalls.intercept.mknod: "true"
security.syscalls.intercept.setxattr: "true"
aadisable:
path: /sys/module/apparmor/parameters/enabled
source: /dev/null
type: unix-char
aadisable2:
source: /dev/kmsg
type: unix-char
kvm:
source: /dev/kvm
type: unix-char
pool: default
shared_etc_ssh_authorized_keys:
path: /etc/ssh/authorized_keys
source: /etc/ssh/authorized_keys
shared_root_ssh:
path: /root/.ssh
source: /root/.ssh
tun:
source: /dev/net/tun
type: unix-char
vhost-net:
source: /dev/vhost-net
type: unix-char
vhost-vsock:
source: /dev/vhost-vsock
type: unix-char
Versions
Host
- Ubuntu 20.04.5 LTS (host LXC)
- libvirtd (libvirt) 6.0.0
- QEMU emulator version 4.2.1 (Debian 1:4.2-3ubuntu6.23
- lxc --version =5.7
- snap list
core18 20221027 2620 latest/stable canonical✓ base
core20 20221027 1695 latest/stable canonical✓ base
lxd 5.7-c62733b 23889 latest/stable canonical✓ -
snapd 2.57.5 17576 latest/stable canonical✓ snapd
- uname -a
Linux gitlab-runners 5.15.0-52-generic #58~20.04.1-Ubuntu SMP Thu Oct 13 13:09:46 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Guest
- Ubuntu 22.04.1 LTS
- libvirtd (libvirt) 8.0.0
- QEMU emulator version 6.2.0 (Debian 1:6.2+dfsg-2ubuntu6.5)
Best regards
