Dear maintainers,
I a trying to use limitation cgroup features on CPU and memory on a
pure cgroupv2 system.
The target system is a Rock64 SBC (ARM64 architecture) with 4 GB of
RAM, a 16 GB SD card, and a 32 GB MMC card.
The current version is Debian 12.9 (Bookworm) with the latest Debian
Trixie Linux kernel.
ansible@hn-rock64-130:~$ cat /etc/debian_version
12.9
ansible@hn-rock64-130:~$ dpkg -l |grep linux-image
ii linux-image-6.12.12-arm64 6.12.12-1 arm64 Linux 6.12 for 64-bit ARMv8 machines (signed)
ii linux-image-arm64 6.12.12-1 arm64 Linux for 64-bit ARMv8 machines (meta-package)
ansible@hn-rock64-130:~$ dpkg -l |grep lxc
ii liblxc-common 1:5.0.2-1+deb12u3 arm64 Linux Containers userspace tools (library)
ii liblxc1:arm64 1:5.0.2-1+deb12u3 arm64 Linux Containers userspace tools (library)
ii lxc 1:5.0.2-1+deb12u3 arm64 Linux Containers userspace tools
Init system use sysvinit, no systemd. Therefore, in order to be sure
to boot one pure cgroupv2 system, kernel is booting (via flashkernel
Debian tools) wit following args
ansible@hn-rock64-130:~$ cat /proc/cmdline
UUID=df5f524b-9e81-463b-946b-fcf9034f7cb3 log_buf_len=1M net.ifnames=0 fsck.mode=force fsck.repair=yes ipv6.disable=1 loglevel=7 apparmor=0 selinux=0 cgroup_no_v1=all
Furthermore, /etc/fstab is update from brevious old cgroup V1 with
following lines
ansible@hn-rock64-130:~$ grep cgroup /etc/fstab
cgroup2 /sys/fs/cgroup cgroup2 rw,nosuid,nodev,noexec,relatime 0 0
Therefore, cgroupV2 seems correctly initialized, because …
ansible@hn-rock64-130:~$ stat -fc %T /sys/fs/cgroup/
cgroup2fs
…and
ansible@hn-rock64-130:~$ mount |grep cgroup
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime)
ansible@hn-rock64-130:~$ lxc-checkconfig
LXC version 5.0.2
Kernel configuration not found at /proc/config.gz; searching…
Kernel configuration found at /boot/config-6.12.12-arm64
— Namespaces —
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled
— Control groups —
Cgroups: enabled
Cgroup namespace: enabled
Cgroup v1 mount points:
Cgroup v2 mount points:
- /sys/fs/cgroup
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup cpuset: enabled
— Misc —
Macvlan: enabled, not loaded
Vlan: enabled, loaded
Bridges: enabled, loaded
Advanced netfilter: enabled, loaded
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled, not loaded
FUSE (for use with lxcfs): enabled, loaded
— Checkpoint/Restore —
checkpoint restore: enabled
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: enabled
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: enabled
CONFIG_NETLINK_DIAG: enabled
File capabilities: enabled
Configuration for one test containter (name : vn-ntp-130) is defined
here …
According LXC documentation, is seems that when using pure cgroupv2
system, it is the mandatory to change prefix cgroup to cgroup2 in
configuration (see above).
Therefore, i make the change on the 2 following lines, but the
container can no more start, log file is bellow
---- change done —
lxc.cgroup2.memory.limit_in_bytes = 410M
lxc.cgroup2.memory.memsw.limit_in_bytes = 410M
— full confiuration file
ansible@hn-rock64-130:~$ sudo cat /etc/lxc/auto/vn-ntp-130 |grep -v “#” |grep -v ^$
lxc.arch = aarch64
lxc.uts.name = vn-ntp-130
lxc.start.auto = 1
lxc.start.order = 10
lxc.start.delay = 0
lxc.group = grp_lxc_start_on_boot
lxc.init.cmd = /sbin/init
lxc.init.uid = 0
lxc.init.gid = 0
lxc.ephemeral = 0
lxc.console.buffer.size = 102400
lxc.console.size = 102400
lxc.log.level = DEBUG
lxc.log.file = /var/log/lxc/vn-ntp-130.log
lxc.tty.max = 4
lxc.pty.max = 10
lxc.signal.halt = SIGPWR
lxc.signal.reboot = SIGINT
lxc.signal.stop = SIGKILL
lxc.cgroup.devices.deny = a
lxc.autodev = 1
lxc.cgroup.devices.allow = c 1:3 rwm
lxc.cgroup.devices.allow = c 1:5 rwm
lxc.cgroup.devices.allow = c 1:8 rwm
lxc.cgroup.devices.allow = c 1:9 rwm
lxc.cgroup.devices.allow = c 5:1 rwm
lxc.cgroup.devices.allow = c 5:2 rwm
lxc.cgroup.devices.allow = c 136:0 rwm
lxc.cgroup.devices.allow = c 136:1 rwm
lxc.cgroup.devices.allow = c 136:2 rwm
lxc.cgroup.devices.allow = c 136:3 rwm
lxc.cgroup.devices.allow = c 136:4 rwm
lxc.cgroup.devices.allow = c 136:5 rwm
lxc.cgroup.devices.allow = c 136:6 rwm
lxc.cgroup.devices.allow = c 136:7 rwm
lxc.cgroup.devices.allow = c 136:8 rwm
lxc.cgroup.devices.allow = c 136:9 rwm
lxc.cgroup.devices.allow = c 5:0 rwm
lxc.cgroup.devices.allow = c 4:64 rwm
lxc.cgroup.devices.allow = c 4:65 rwm
lxc.cgroup.devices.allow = c 4:0 rwm
lxc.cgroup.devices.allow = c 4:1 rwm
lxc.cgroup.devices.allow = c 4:2 rwm
lxc.cgroup.devices.allow = c 4:3 rwm
lxc.cgroup.devices.allow = c 4:4 rwm
lxc.cgroup.devices.allow = c 4:5 rwm
lxc.cgroup.devices.allow = c 4:6 rwm
lxc.rootfs.mount = /var/lib/lxc/vn-ntp-130/rootfs
lxc.rootfs.path = /dev/mapper/vg_vn_ntp_130-lv_rootfs
lxc.rootfs.options = defaults,noatime,nodiratime
lxc.mount.entry = proc /var/lib/lxc/vn-ntp-130/rootfs/proc proc nodev,noexec,nosuid 0 0
lxc.mount.entry = devpts /var/lib/lxc/vn-ntp-130/rootfs/dev/pts devpts defaults 0 0
lxc.mount.entry = sysfs /var/lib/lxc/vn-ntp-130/rootfs/sys sysfs defaults 0 0
lxc.mount.entry = /dev/mapper/vg_vn_ntp_130-lv_usr /var/lib/lxc/vn-ntp-130/rootfs/usr ext4 defaults,noatime,nodiratime
lxc.mount.entry = /dev/mapper/vg_vn_ntp_130-lv_var /var/lib/lxc/vn-ntp-130/rootfs/var ext4 defaults,noatime,nodiratime
lxc.mount.entry = /dev/mapper/vg_vn_ntp_130-lv_tmp /var/lib/lxc/vn-ntp-130/rootfs/tmp ext4 defaults,noatime,nodiratime
lxc.mount.entry = /dev/mapper/vg_vn_ntp_130-lv_home /var/lib/lxc/vn-ntp-130/rootfs/home ext4 defaults,noatime,nodiratime
lxc.mount.entry = /dev/mapper/vg_vn_ntp_130-lv_var_log /var/lib/lxc/vn-ntp-130/rootfs/var/log ext4 defaults,noatime,nodiratime
lxc.mount.entry = /dev/mapper/vg_vn_ntp_130-lv_var_lib /var/lib/lxc/vn-ntp-130/rootfs/var/lib ext4 defaults,noatime,nodiratime
lxc.mount.entry = /dev/mapper/vg_vn_ntp_130-lv_var_cache /var/lib/lxc/vn-ntp-130/rootfs/var/cache ext4 defaults,noatime,nodiratime
lxc.mount.entry = /dev/mapper/vg_vn_ntp_130-lv_var_lib_apt /var/lib/lxc/vn-ntp-130/rootfs/var/lib/apt ext4 defaults,noatime,nodiratime
lxc.cap.drop = sys_ptrace
lxc.cap.drop = mknod
lxc.cap.drop = sys_module
lxc.cap.drop = sys_rawio
lxc.cap.drop = syslog
lxc.net.0.type = veth
lxc.net.0.flags = up
lxc.net.0.link = br-admin
lxc.net.0.name = if-admin
lxc.net.0.hwaddr = 02:00:30:70:04:9
lxc.net.0.veth.pair = if-ntp-adm
lxc.net.1.type = veth
lxc.net.1.flags = up
lxc.net.1.link = br-user
lxc.net.1.name = if-user
lxc.net.1.hwaddr = 02:00:30:70:04:8
lxc.net.1.veth.pair = if-ntp-usr
lxc.net.2.type = veth
lxc.net.2.flags = up
lxc.net.2.link = br-ntp
lxc.net.2.name = if-ntp
lxc.net.2.hwaddr = 02:00:30:70:04:7
lxc.net.2.veth.pair = if-ntp-ntp
lxc.net.3.type = veth
lxc.net.3.flags = up
lxc.net.3.link = br-serv
lxc.net.3.name = if-serv
lxc.net.3.hwaddr = 02:00:30:70:04:6
lxc.net.3.veth.pair = if-ntp-srv
lxc.net.4.type = veth
lxc.net.4.flags = up
lxc.net.4.link = br-factory
lxc.net.4.name = if-factory
lxc.net.4.hwaddr = 02:00:30:70:04:15
lxc.net.4.veth.pair = if-ntp-fact
lxc.apparmor.allow_incomplete = 1
lxc.apparmor.profile = unconfined
ansible@hn-rock64-130:~$ tail -f /var/log/lxc/vn-ntp-130.log
lxc-start vn-ntp-130 20250313085530.640 INFO lsm - …/src/lxc/lsm/lsm.c:lsm_init_static:38 - Initialized LSM security driver nop
lxc-start vn-ntp-130 20250313085530.641 INFO start - …/src/lxc/start.c:lxc_init:881 - Container “vn-ntp-130” is initialized
lxc-start vn-ntp-130 20250313085530.642 INFO cgfsng - …/src/lxc/cgroups/cgfsng.c:cgfsng_monitor_create:1391 - The monitor process uses “lxc.monitor.vn-ntp-130” as cgroup
lxc-start vn-ntp-130 20250313085530.671 DEBUG storage - …/src/lxc/storage/storage.c:storage_query:231 - Detected rootfs type “lvm”
lxc-start vn-ntp-130 20250313085530.672 INFO cgfsng - …/src/lxc/cgroups/cgfsng.c:cgfsng_payload_create:1499 - The container process uses “lxc.payload.vn-ntp-130” as inner and “lxc.payload.vn-ntp-130” as limit cgroup
lxc-start vn-ntp-130 20250313085530.675 INFO start - …/src/lxc/start.c:lxc_spawn:1762 - Cloned CLONE_NEWNS
lxc-start vn-ntp-130 20250313085530.675 INFO start - …/src/lxc/start.c:lxc_spawn:1762 - Cloned CLONE_NEWPID
lxc-start vn-ntp-130 20250313085530.675 INFO start - …/src/lxc/start.c:lxc_spawn:1762 - Cloned CLONE_NEWUTS
lxc-start vn-ntp-130 20250313085530.675 INFO start - …/src/lxc/start.c:lxc_spawn:1762 - Cloned CLONE_NEWIPC
lxc-start vn-ntp-130 20250313085530.675 INFO start - …/src/lxc/start.c:lxc_spawn:1762 - Cloned CLONE_NEWNET
lxc-start vn-ntp-130 20250313085530.675 INFO start - …/src/lxc/start.c:lxc_spawn:1762 - Cloned CLONE_NEWCGROUP
lxc-start vn-ntp-130 20250313085530.675 DEBUG start - …/src/lxc/start.c:lxc_try_preserve_namespace:139 - Preserved mnt namespace via fd 16 and stashed path as mnt:/proc/19844/fd/16
lxc-start vn-ntp-130 20250313085530.675 DEBUG start - …/src/lxc/start.c:lxc_try_preserve_namespace:139 - Preserved pid namespace via fd 17 and stashed path as pid:/proc/19844/fd/17
lxc-start vn-ntp-130 20250313085530.676 DEBUG start - …/src/lxc/start.c:lxc_try_preserve_namespace:139 - Preserved uts namespace via fd 18 and stashed path as uts:/proc/19844/fd/18
lxc-start vn-ntp-130 20250313085530.676 DEBUG start - …/src/lxc/start.c:lxc_try_preserve_namespace:139 - Preserved ipc namespace via fd 19 and stashed path as ipc:/proc/19844/fd/19
lxc-start vn-ntp-130 20250313085530.676 DEBUG start - …/src/lxc/start.c:lxc_try_preserve_namespace:139 - Preserved net namespace via fd 20 and stashed path as net:/proc/19844/fd/20
lxc-start vn-ntp-130 20250313085530.676 DEBUG start - …/src/lxc/start.c:lxc_try_preserve_namespace:139 - Preserved cgroup namespace via fd 21 and stashed path as cgroup:/proc/19844/fd/21
lxc-start vn-ntp-130 20250313085530.677 WARN cgfsng - …/src/lxc/cgroups/cgfsng.c:cgfsng_setup_limits_legacy:3155 - Invalid argument - Ignoring legacy cgroup limits on pure cgroup2 system
lxc-start vn-ntp-130 20250313085530.677 ERROR cgfsng - …/src/lxc/cgroups/cgfsng.c:cgfsng_setup_limits:3246 - No such file or directory - Failed to set “memory.limit_in_bytes” to “410M”
lxc-start vn-ntp-130 20250313085530.677 ERROR start - …/src/lxc/start.c:lxc_spawn:1810 - Failed to setup cgroup limits for container “vn-ntp-130”
lxc-start vn-ntp-130 20250313085530.678 DEBUG network - …/src/lxc/network.c:lxc_delete_network:4173 - Deleted network devices
lxc-start vn-ntp-130 20250313085530.679 ERROR start - …/src/lxc/start.c:__lxc_start:2107 - Failed to spawn container “vn-ntp-130”
lxc-start vn-ntp-130 20250313085530.680 WARN start - …/src/lxc/start.c:lxc_abort:1036 - No such process - Failed to send SIGKILL via pidfd 15 for process 19846
Thank in advance for your help
PS: i have also try to limit cpu, but without any succes
