I wonder if there is a way to create an lvmcluster storage which is only accessible to a subset of nodes?
Here’s a specific example of what I might want to do:
Create a three node cluster: A, B, C
Create a partition on A and B with DRBD mirroring between them, configured as dual-primary
Create lvmcluster on top of that DRBD mirror device
A VM running on node A or B could access the shared volume with lvmcluster, and could live-migrate between those nodes. But the volume would not be accessible on node C.
I know there are cluster groups, and I could create a “drbd” group containing instances A and B to constraint an instance launch, but I don’t know if that prevents the instance being migrated to node outside its initial group - and I don’t think it prevents explicitly creating an instance on node C using the configured lvmcluster storage.
Extending this scenarios, you could also set up other mirrored pairs between B and C, and A and C, with their own separate storage pools, and VMs would need similar mobility constraints. I can also think of other scenarios where a particular SAN backend is only available to a subset of nodes, but you might still want all nodes to be in the same incus cluster.
Thanks. I think it should be possible with drbd9, which allows N-way replication (up to 32 copies) and also allows disks to be accessed from nodes which don’t host a replica.
Ack. I was asked by a friend if it was possible to run incus over drbd directly, as he thinks linstor looks a bit too complex. I think that by the time you’ve set up drbd manually, it’s probably not a huge difference, especially since it takes cluster LVM and lvm-lockd/sanlock out of the equation.
I’ve just built a test cluster using three Ubuntu 22.04 + drbd9 nodes (Linbit haven’t published deb packages for drdb9 for 24.04 yet) and it does work, e.g. VMs can live migrate. I should probably write it up.
