On a fresh install on 19.04, lxd latest snap
core 16-2.38.1 6818 stable canonical✓ core
lxd 3.14 10934 stable/… canonical✓ -
For some reason, if I apply limits.disk.priority, for example limits.disk.priority: "9", upon trying to start the container it fails and get this error:
Config parsing error: Failed to set cgroup blkio.weight="900": setting cgroup item for the container failed.
Any ideas about whats happening?
Various logs and configs/logs:
lxc.conf
lxc.log.file = /var/snap/lxd/common/lxd/logs/test/lxc.log
lxc.log.level = warn
lxc.console.buffer.size = auto
lxc.console.size = auto
lxc.console.logfile = /var/snap/lxd/common/lxd/logs/test/console.log
lxc.mount.auto = proc:rw sys:rw
lxc.autodev = 1
lxc.pty.max = 1024
lxc.mount.entry = /dev/fuse dev/fuse none bind,create=file,optional 0 0
lxc.mount.entry = /dev/net/tun dev/net/tun none bind,create=file,optional 0 0
lxc.mount.entry = /proc/sys/fs/binfmt_misc proc/sys/fs/binfmt_misc none rbind,create=dir,optional 0 0
lxc.mount.entry = /sys/fs/fuse/connections sys/fs/fuse/connections none rbind,create=dir,optional 0 0
lxc.mount.entry = /sys/fs/pstore sys/fs/pstore none rbind,create=dir,optional 0 0
lxc.mount.entry = /sys/kernel/debug sys/kernel/debug none rbind,create=dir,optional 0 0
lxc.mount.entry = /sys/kernel/security sys/kernel/security none rbind,create=dir,optional 0 0
lxc.mount.entry = /dev/mqueue dev/mqueue none rbind,create=dir,optional 0 0
lxc.include = /snap/lxd/current/lxc/config//common.conf.d/
lxc.arch = linux64
lxc.hook.version = 1
lxc.hook.pre-start = /snap/lxd/current/bin/lxd callhook /var/snap/lxd/common/lxd 5 start
lxc.hook.stop = /snap/lxd/current/bin/lxd callhook /var/snap/lxd/common/lxd 5 stopns
lxc.hook.post-stop = /snap/lxd/current/bin/lxd callhook /var/snap/lxd/common/lxd 5 stop
lxc.tty.max = 0
lxc.uts.name = test
lxc.mount.entry = /var/snap/lxd/common/lxd/devlxd dev/lxd none bind,create=dir 0 0
lxc.apparmor.profile = lxd-test_//&:lxd-test_:
lxc.seccomp.profile = /var/snap/lxd/common/lxd/security/seccomp/test
lxc.idmap = u 0 1000000 1000000000
lxc.idmap = g 0 1000000 1000000000
lxc.rootfs.path = dir:/var/snap/lxd/common/lxd/containers/test/rootfs
lxc.net.0.type = veth
lxc.net.0.script.up = /snap/lxd/current/bin/lxd callhook /var/snap/lxd/common/lxd 5 network-up eth0
lxc.net.0.flags = up
lxc.net.0.link = lxdbr0
lxc.net.0.hwaddr = 00:16:3e:32:16:57
lxc.net.0.name = eth0
lxc.mount.auto = shmounts:/var/snap/lxd/common/lxd/shmounts/test:/dev/.lxd-mounts
cat /var/snap/lxd/common/lxd/logs/test/lxc.log
lxc test 20190620140756.925 WARN conf - conf.c:lxc_map_ids:2970 - newuidmap binary is missing
lxc test 20190620140756.926 WARN conf - conf.c:lxc_map_ids:2976 - newgidmap binary is missing
lxc test 20190620140756.928 WARN conf - conf.c:lxc_map_ids:2970 - newuidmap binary is missing
lxc test 20190620140756.928 WARN conf - conf.c:lxc_map_ids:2976 - newgidmap binary is missing
lxc test 20190620140757.632 WARN conf - conf.c:lxc_setup_devpts:1641 - Invalid argument - Failed to unmount old devpts instance
cat /var/snap/lxd/common/lxd/logs/lxd.log
t=2019-06-20T13:28:19+0000 lvl=info msg="LXD 3.14 is starting in normal mode" path=/var/snap/lxd/common/lxd
t=2019-06-20T13:28:19+0000 lvl=info msg="Kernel uid/gid map:"
t=2019-06-20T13:28:19+0000 lvl=info msg=" - u 0 0 4294967295"
t=2019-06-20T13:28:19+0000 lvl=info msg=" - g 0 0 4294967295"
t=2019-06-20T13:28:19+0000 lvl=info msg="Configured LXD uid/gid map:"
t=2019-06-20T13:28:19+0000 lvl=info msg=" - u 0 1000000 1000000000"
t=2019-06-20T13:28:19+0000 lvl=info msg=" - g 0 1000000 1000000000"
t=2019-06-20T13:28:19+0000 lvl=warn msg="CGroup memory swap accounting is disabled, swap limits will be ignored."
t=2019-06-20T13:28:19+0000 lvl=info msg="Kernel features:"
t=2019-06-20T13:28:19+0000 lvl=info msg=" - netnsid-based network retrieval: yes"
t=2019-06-20T13:28:19+0000 lvl=info msg=" - uevent injection: yes"
t=2019-06-20T13:28:19+0000 lvl=info msg=" - seccomp listener: yes"
t=2019-06-20T13:28:19+0000 lvl=info msg=" - unprivileged file capabilities: yes"
t=2019-06-20T13:28:19+0000 lvl=info msg=" - shiftfs support: no"
t=2019-06-20T13:28:19+0000 lvl=info msg="Initializing local database"
t=2019-06-20T13:28:20+0000 lvl=info msg="Starting /dev/lxd handler:"
t=2019-06-20T13:28:20+0000 lvl=info msg=" - binding devlxd socket" socket=/var/snap/lxd/common/lxd/devlxd/sock
t=2019-06-20T13:28:20+0000 lvl=info msg="REST API daemon:"
t=2019-06-20T13:28:20+0000 lvl=info msg=" - binding Unix socket" inherited=true socket=/var/snap/lxd/common/lxd/unix.socket
t=2019-06-20T13:28:20+0000 lvl=info msg=" - binding TCP socket" socket=[::]:8443
t=2019-06-20T13:28:20+0000 lvl=info msg="Initializing global database"
t=2019-06-20T13:28:20+0000 lvl=info msg="Initializing storage pools"
t=2019-06-20T13:28:20+0000 lvl=info msg="Applying patch: storage_api_rename_container_snapshots_dir_again"
t=2019-06-20T13:28:20+0000 lvl=info msg="Applying patch: storage_api_rename_container_snapshots_links_again"
t=2019-06-20T13:28:20+0000 lvl=info msg="Applying patch: storage_api_rename_container_snapshots_dir_again_again"
t=2019-06-20T13:28:20+0000 lvl=info msg="Initializing networks"
t=2019-06-20T13:28:21+0000 lvl=info msg="Pruning leftover image files"
t=2019-06-20T13:28:21+0000 lvl=info msg="Done pruning leftover image files"
t=2019-06-20T13:28:21+0000 lvl=info msg="Loading daemon configuration"
t=2019-06-20T13:28:21+0000 lvl=info msg="Started seccomp handler" path=/var/snap/lxd/common/lxd/seccomp.socket
t=2019-06-20T13:28:21+0000 lvl=info msg="Pruning expired images"
t=2019-06-20T13:28:21+0000 lvl=info msg="Done pruning expired images"
t=2019-06-20T13:28:21+0000 lvl=info msg="Pruning expired container backups"
t=2019-06-20T13:28:21+0000 lvl=info msg="Done pruning expired container backups"
t=2019-06-20T13:28:21+0000 lvl=info msg="Updating instance types"
t=2019-06-20T13:28:21+0000 lvl=info msg="Done updating instance types"
t=2019-06-20T13:28:21+0000 lvl=info msg="Updating images"
t=2019-06-20T13:28:21+0000 lvl=info msg="Done updating images"
t=2019-06-20T13:28:21+0000 lvl=info msg="Expiring log files"
t=2019-06-20T13:28:21+0000 lvl=info msg="Done expiring log files"
t=2019-06-20T13:28:21+0000 lvl=info msg="Starting container" action=start created=2019-06-20T13:22:20+0000 ephemeral=false name=test project=default stateful=false used=2019-06-20T13:26:17+0000
t=2019-06-20T13:28:22+0000 lvl=eror msg="Failed to apply network priority" container=test err="Can't set network priority on stopped container"
t=2019-06-20T13:28:22+0000 lvl=eror msg="Failed starting container" action=start created=2019-06-20T13:22:20+0000 ephemeral=false name=test project=default stateful=false used=2019-06-20T13:26:17+0000
t=2019-06-20T13:28:22+0000 lvl=eror msg="Failed to start container 'test': Failed to run: /snap/lxd/current/bin/lxd forkstart test /var/snap/lxd/common/lxd/containers /var/snap/lxd/common/lxd/logs/test/lxc.conf: "
Essentially before, I could define a config like the following and would start fine, not sure whats changed.
boot.autostart: "1"
image.architecture: amd64
image.description: ubuntu 19.04 amd64 (release) (20190619)
image.label: release
image.os: ubuntu
image.release: disco
image.serial: "20190619"
image.version: "19.04"
limits.cpu: "1"
limits.cpu.allowance: 100%
limits.cpu.priority: "9"
limits.memory: 1024MB
limits.memory.enforce: hard
limits.memory.swap: "1"
limits.memory.swap.priority: "10"
limits.network.priority: "7"
limits.processes: "1000"
security.nesting: "1"
security.privileged: "0"
volatile.eth0.hwaddr: 00:16:3e:32:16:57
volatile.idmap.base: "0"
devices: {}
description: this is a description...
Thanks in advance anyone who can see whats wrong, please ask for further info if you need it.
