John
1
To show the number of running processes in an LXC container (Ubuntu 24.04) I know of the following command to do so:
ps -e | wc -l
Is that the process count which is limited by the LXC limits.processes setting?
It probably is but I just wanted to make sure.
Thanks
stgraber
(Stéphane Graber)
2
Basically, yes. The count doesn’t always exactly match as threads may not be counted in some scenarios.
You may be able to get the current pid count from /sys/fs/cgroup instead which would give you the exact value.
