Hi
I want to have a container with an Ubuntu 18.04 image.
I want to install inside the container, the opencv library so that the applications that are running inside the container can use my physical GPU . (https://www.pyimagesearch.com/2020/02/03/how-to-use-opencvs-dnn-module-with-nvidia-gpus-cuda-and-cudnn/)
Apart from the installation part of opencv with GPU flags available during build, is there anything else that i should do ?
@stgraber any help ?
