Loop while trying to create the final cgroup 10, OCI containers fail to start
Following the upgrade to 7.1, I’m unable to successfully start various OCI containers that had previously been working fine under 7.0.
What appears to be happening on incus start vw is that the container repeatedly tries to create all the cgroups it needs, but appears to be failing to create the final one (10)
Log (lxc.log):
lxc vw 20260530110922.536 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-1) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-1)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-2) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-2)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-3) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-3)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-4) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-4)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-5) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-5)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-6) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-6)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-7) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-7)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-8) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-8)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-9) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-9)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-10) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-10)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-11) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-11)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-12) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-12)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-13) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-13)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-14) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-14)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-15) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-15)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-16) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-16)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-17) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-17)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-18) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-18)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-19) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-19)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-20) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-20)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-21) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-21)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-22) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-22)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-23) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-23)
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-24) failed
lxc vw 20260530110922.537 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-24)
lxc vw 20260530110922.538 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-25) failed
lxc vw 20260530110922.538 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-25)
lxc vw 20260530110922.538 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-26) failed
lxc vw 20260530110922.538 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-26)
lxc vw 20260530110922.538 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-27) failed
lxc vw 20260530110922.538 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-27)
lxc vw 20260530110922.538 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-28) failed
lxc vw 20260530110922.538 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-28)
lxc vw 20260530110922.538 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-29) failed
lxc vw 20260530110922.538 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-29)
lxc vw 20260530110922.538 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-30) failed
lxc vw 20260530110922.538 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-30)
lxc vw 20260530110922.538 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:507 - File exists - Creating the final cgroup 10(lxc.monitor.vw-31) failed
lxc vw 20260530110922.538 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:550 - File exists - Failed to create monitor cgroup 10(lxc.monitor.vw-31)
lxc vw 20260530110922.594 ERROR    utils - ../src/lxc/utils.c:safe_mount:1332 - Invalid argument - Failed to mount "none" onto "/opt/incus/lib/lxc/rootfs/run"
lxc vw 20260530110923.998 WARN     cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_destroy:665 - Device or resource busy - Failed to destroy 10(lxc.monitor.vw-32)
lxc 20260530110923.998 ERROR    af_unix - ../src/lxc/af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Connection reset by peer - Failed to receive response
lxc 20260530110923.998 ERROR    commands - ../src/lxc/commands.c:lxc_cmd_rsp_recv_fds:128 - Failed to receive file descriptors for command "get_state"
This leaves a pile of redundant cgroup hierarchies in /sys/fs/cgroup which are not cleaned up by incus on service restart.
The OCI container reverts to stopped status.
After checking cgroup.procs was empty in each of the lxc.monitor.vw* cgroups created, I cleared the duplicated cgroups manually to see whether this would rectify the problem, however the same problem occurs on container start.
As an aside, a non-OCI container appears to start with no problems.
Any advice on how to rectify this problem and restart my OCI containers?
I downgraded incus to 7.0 LTS again, rebooted for good measure, and now all my containers are starting with no problems.
With all the containers (OCI and incus-native) running, inside /sys/fs/cgroup there is a now only a single lxc.monitor.<foo> and lxc.payload.<foo> per container.
I appreciate this means I’m unable to share any further diagnostics from the broken system, for which I apologise.
Regression: OCI containers with storage volumes fail due to permission errors in Incus 7.1
