Any hints on how I might progress / workarounds / references / things to try would be great.
Also if someone could explain to me what is happening on the host after fdisk writes to the loopback device that causes the new /dev/loop0pn devices to be created that would be really excellent!
The host uses devtmpfs for /dev which is a virtual filesystem from the kernel that dynamically creates devices for you based on uevents.
The containers can’t use that filesystem because it’s not namespaced and so instead use a regular tmpfs + manually created (or bind-mounted) device nodes.
When you run that losetup, the kernel will likely emit those uevents and the device may appear on the host, but in the container, nothing is there to react to those (if they even make it) and so nothing shows up.
One potential workaround is to bind-mount /dev/mapper into the container using something like:
lxc config device add NAME mapper disk source=/dev/mapper path=/dev/mapper recursive=true
There’s then a good chance that the uevent will trigger creation of /dev/mapper/XYZ devices that would then be visible in the container.
Ah excellent, thanks Stefan for your help. That’s really useful.
I bind-mount’d /dev/mapper as you suggested:
ls -alh /dev/mapper/control
crw------- 1 root root 10, 236 Mar 30 18:05 /dev/mapper/control
I attempted to use kpartx to create devices for each partition explicitly - this method works on the host but not in the container. I strace'd it to see what is going on:
stat("/dev/mapper/control", {st_mode=S_IFCHR|0600, st_rdev=makedev(10, 236), ...}) = 0
open("/dev/mapper/control", O_RDWR) = -1 EPERM (Operation not permitted)
write(2, "/dev/mapper/control: open failed"..., 57/dev/mapper/control: open failed: Operation not permitted) = 57
The permissions for /dev/mapper/control are identical in the container and on the host, and the container is running in privileged mode - I can see its init process running as root.
Do you have any ideas as to why I’m seeing the O_RDWR open failure, or any further thoughts about how I might solve this issue?
On the host these dm-* nodes appear correctly, but not in the container.
I compared the kpartxstrace outputs on both the container and host but there was no discernible difference (aside from memory addresses and device numbers) - so it looks as though the dm-* files are created by something else (presumably udev on the host). I put udev into debug mode (udev_log="debug" in /etc/udev/udev.log - this showed that is was calling out to dmsetup so presumably that’s what is creating the device nodes.
Rather than try to replicate the udev setup in the container I opted to create the dm-* nodes using mknod inside the container:
mknod /dev/dm-0 b 254 0
mknod /dev/dm-1 b 254 1
In conjunction with running kpartx this workaround meets my needs, allowing me to continue on with formatting the loopback partitions.
