This is the repetition of
cluster Setup
- 31 nodes in total: node00 ~ node31, but without node08
- node00 is the master node
- node01 ~ node31 are slave nodes of LXD cluster
- All nodes were Ubuntu 17.10 and LXD 3.0 was installed with snap
- LXD cluster has been created, with LXD cluster feature
- All nodes had same configuration, with local storage provider to ‘/dev/sda6’ and no remote storage
I didn’t touch this cluster for few days, and today I found out that both ‘lxc’ and ‘lxd’ commands are not responding
Also found that there are lots of lxd processes
This is the result of “ps -aux | grep lxd”, acquired from node00 but all same around any node
root 1948 1.3 0.5 2026472 67952 ? Sl Apr30 33:21 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 3816 0.0 0.1 328304 19244 ? Sl 02:51 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 3911 0.0 0.1 255980 20388 ? Sl 03:01 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 4007 0.0 0.1 255980 19056 ? Sl 03:11 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 4104 0.0 0.1 255980 19712 ? Sl 03:21 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 4200 0.0 0.1 256236 20384 ? Sl 03:31 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 4294 0.0 0.1 253260 20212 ? Sl 03:41 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 4389 0.0 0.1 187980 18932 ? Sl 03:51 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 4485 0.0 0.1 255980 19636 ? Sl 04:01 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 4580 0.0 0.1 255980 20108 ? Sl 04:11 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 4676 0.0 0.1 255980 19712 ? Sl 04:21 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 4770 0.0 0.1 187980 20084 ? Sl 04:31 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 4865 0.0 0.1 253260 19420 ? Sl 04:41 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 4960 0.0 0.1 190444 18792 ? Sl 04:51 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 5055 0.0 0.1 253260 19940 ? Sl 05:01 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 5150 0.0 0.1 189036 19652 ? Sl 05:11 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 5248 0.0 0.1 254572 19132 ? Sl 05:21 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 5344 0.0 0.1 190444 19668 ? Sl 05:31 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 5439 0.0 0.1 190444 19252 ? Sl 05:41 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 5535 0.0 0.1 254828 20228 ? Sl 05:51 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 5629 0.0 0.1 253260 19020 ? Sl 06:01 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 5723 0.0 0.1 254828 19976 ? Sl 06:11 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 5865 0.0 0.1 255980 19440 ? Sl 06:21 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 6037 0.0 0.1 253260 19388 ? Sl 06:31 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 6132 0.0 0.1 255980 19116 ? Sl 06:41 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 6225 0.0 0.1 190444 19640 ? Sl 06:51 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 6321 0.0 0.1 253260 20180 ? Sl 07:01 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 6416 0.0 0.1 187724 18668 ? Sl 07:11 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 6514 0.0 0.1 254572 19304 ? Sl 07:21 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 6609 0.0 0.1 255980 19136 ? Sl 07:31 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 6704 0.0 0.1 253260 18692 ? Sl 07:41 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 6799 0.0 0.1 255980 19264 ? Sl 07:51 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 6893 0.0 0.1 190444 19488 ? Sl 08:01 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 6986 0.0 0.1 190444 19564 ? Sl 08:11 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 7082 0.0 0.1 187724 19508 ? Sl 08:21 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 7177 0.0 0.1 253260 19068 ? Sl 08:31 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 7272 0.0 0.1 255980 19240 ? Sl 08:41 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 7366 0.0 0.1 326992 19168 ? Sl 08:51 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 7462 0.0 0.1 256236 19888 ? Sl 09:01 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 7556 0.0 0.1 187724 20180 ? Sl 09:11 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 7653 0.0 0.1 255980 19200 ? Sl 09:21 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 7747 0.0 0.1 255980 19288 ? Sl 09:31 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 7841 0.0 0.1 255980 19028 ? Sl 09:41 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 7935 0.0 0.1 253260 19448 ? Sl 09:51 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 8035 0.0 0.1 190444 19968 ? Sl 10:01 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 8129 0.0 0.1 253260 19244 ? Sl 10:11 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 8226 0.0 0.1 254572 20448 ? Sl 10:21 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 8320 0.0 0.1 253260 19244 ? Sl 10:31 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 8413 0.0 0.1 253260 18900 ? Sl 10:41 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 8507 0.0 0.1 255980 19364 ? Sl 10:51 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 8601 0.0 0.1 255980 19224 ? Sl 11:01 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 8696 0.0 0.1 256236 19836 ? Sl 11:11 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 8794 0.0 0.1 255980 18984 ? Sl 11:21 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 8888 0.0 0.1 255980 19512 ? Sl 11:31 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 8991 0.0 0.1 255980 18968 ? Sl 11:41 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 9086 0.0 0.1 187980 19616 ? Sl 11:51 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 9180 0.0 0.1 256236 19664 ? Sl 12:01 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 9275 0.0 0.1 255980 19808 ? Sl 12:11 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 9374 0.0 0.1 255980 19788 ? Sl 12:21 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 9469 0.0 0.1 254572 19480 ? Sl 12:31 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 9565 0.0 0.1 189292 18576 ? Sl 12:41 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 9661 0.0 0.1 190444 18996 ? Sl 12:52 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 9757 0.0 0.1 256236 19584 ? Sl 13:02 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 9853 0.0 0.1 190444 20016 ? Sl 13:12 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 9951 0.0 0.1 255980 19528 ? Sl 13:22 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 10046 0.0 0.1 189036 18912 ? Sl 13:32 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 10142 0.0 0.1 253260 19052 ? Sl 13:42 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 10236 0.0 0.1 190444 19352 ? Sl 13:52 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 10340 0.0 0.1 255980 19504 ? Sl 14:02 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 10435 0.0 0.1 254572 18924 ? Sl 14:12 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 10533 0.0 0.1 190444 19032 ? Sl 14:22 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 10629 0.0 0.1 254572 19420 ? Sl 14:32 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 10724 0.0 0.1 253260 18952 ? Sl 14:42 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 10873 0.0 0.1 256236 19448 ? Sl 14:52 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 10969 0.0 0.1 189388 20268 ? Sl 15:02 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 11064 0.0 0.1 253260 20164 ? Sl 15:12 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 11162 0.0 0.1 254572 18760 ? Sl 15:22 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 11257 0.0 0.1 187724 19572 ? Sl 15:32 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 11365 0.0 0.1 255980 19500 ? Sl 15:42 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 11460 0.0 0.1 253260 18936 ? Sl 15:52 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 11554 0.0 0.1 254572 19064 ? Sl 16:02 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 11649 0.0 0.1 255980 18952 ? Sl 16:12 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 11748 0.0 0.1 253260 20044 ? Sl 16:22 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 11843 0.0 0.1 255980 19496 ? Sl 16:32 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 11939 0.0 0.1 190700 19400 ? Sl 16:42 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 12033 0.0 0.1 256236 19024 ? Sl 16:52 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 12133 0.0 0.1 254572 18768 ? Sl 17:02 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 12280 0.0 0.1 187724 19024 ? Sl 17:12 0:00 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
user 12395 0.0 0.0 47040 5488 pts/0 S 17:15 0:00 ssh node02 sudo snap remove lxd && sudo apt remove -y snap
user 12635 0.0 0.0 15428 2116 pts/0 S+ 17:25 0:00 grep --color=auto lxd
This is clusterwide
This is tar archive of “/var/snap/lxd/common/lxd/logs” from cluster node04 ~ node31
I accidently removed LXD from node00 ~ node03
Hope this could help
