hafijaa
(hafijaa)
April 6, 2021, 3:32am
1
I am trying to start lxd container By lxc start EID-DB but it shows
Error: Common start logic: Mount /dev/my-lvm/containers_EID–DB onto /var/lib/lxd/storage-pools/my-lvm/containers/EID-DB: input/output error
Try lxc info --show-log EID-DB for more info
root@lxd1:~# lxc info --show-log EID-DB
Remote: unix://
Created: 2019/12/11 05:40 UTC
Status: Stopped
Type: persistent
Profiles: default
Snapshots:
14122020 (taken at 2020/12/14 07:42 UTC) (stateless)
EID-DB (taken at 2021/03/09 11:33 UTC) (stateless)
Log:
I am trying to this
root@lxd1:~# vgscan --cache
WARNING: /dev/my-lvm/containers_Smart–DB: Thin’s thin-pool needs inspection.
WARNING: /dev/my-lvm/containers_EID–DB: Thin’s thin-pool needs inspection.
WARNING: /dev/my-lvm/containers_Smart–DB-nSmart–DB–backup: Thin’s thin-pool needs inspection.
WARNING: /dev/my-lvm/containers_EID–DB-14122020: Thin’s thin-pool needs inspection.
WARNING: /dev/my-lvm/containers_EID–DB-EID–DB: Thin’s thin-pool needs inspection.
WARNING: /dev/my-lvm/containers_Smart–DB-nSmart–DB: Thin’s thin-pool needs inspection.
Reading volume groups from cache.
Found volume group “vg1” using metadata type lvm2
Found volume group “my-lvm” using metadata type lvm2
Found volume group “ubuntu-vg” using metadata type lvm2
root@lxd1:~# lvchange -ay /dev/vg1/vo
Plz tell me what is the problem and give a solution plz.
hafijaa
(hafijaa)
April 6, 2021, 7:06am
3
@tomp could you help plz?
hafijaa
(hafijaa)
April 6, 2021, 7:08am
4
@simos could you help plz?
tomp
(Thomas Parrott)
April 6, 2021, 7:58am
5
I’ve not encountered that error myself before, but a quick search suggests using the command:
sudo lvconvert --repair <thinpool>
Please can you show the output of sudo lvs?
hafijaa
(hafijaa)
April 6, 2021, 8:27am
6
root@lxd1:~# lvs
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert
LXDThinPool my-lvm twi-cotzM- 1021.99g 16.95 10.91
containers_EID--DB my-lvm Vwi-a-tz-- 60.05g LXDThinPool 35.56
containers_EID--DB-14122020 my-lvm Vri-a-tz-- 60.05g LXDThinPool containers_NID--DB 36.99
containers_EID--DB-EID--DB my-lvm Vri-a-tz-- 60.05g LXDThinPool containers_EID--DB 35.31
containers_Smart--DB my-lvm Vwi-a-tz-- 500.00g LXDThinPool 11.07
containers_Smart--DB-Smart--DB my-lvm Vri-a-tz-- 500.00g LXDThinPool containers_nSmart--DB 9.97
containers_Smart--DB-Smart--DB--backup my-lvm Vri-a-tz-- 500.00g LXDThinPool containers_Smart--DB 19.96
custom_vdisk01 my-lvm Vwi-a-tz-- 150.00g LXDThinPool 2.24
ubuntu-lv ubuntu-vg -wi-ao---- <248.50g
vol1 vg1 -wi-ao---- <1024.00g
hafijaa
(hafijaa)
April 6, 2021, 8:38am
7
root@lxd1:~# lvconvert --repair /dev/vg1/vol1
WARNING: Disabling lvmetad cache for repair command.
WARNING: Not using lvmetad because of repair.
WARNING: /dev/my-lvm/custom_vdisk01: Thin’s thin-pool needs inspection.
WARNING: /dev/my-lvm/containers_EID–DB-NID–DB: Thin’s thin-pool needs inspection.
Command on LV vg1/vol1 does not accept LV type linear.
Command not permitted on LV vg1/vol1.
tomp
(Thomas Parrott)
April 6, 2021, 8:40am
8
The thin pool is /dev/vg1/LXDThinPool (indicated by the t in the Attr col). Try running it on that.
So:
sudo lvconvert --repair /dev/vg1/LXDThinPool
hafijaa
(hafijaa)
April 6, 2021, 8:42am
9
that means by run this command?
tomp
(Thomas Parrott)
10
You’ll also need to deactivate it by the looks of it:
sudo lvchange -an /dev/vg1/LXDThinPool
hafijaa
(hafijaa)
April 6, 2021, 8:43am
11
Plz give me the sequence command. I don’t know which one will 1st
tomp
(Thomas Parrott)
April 6, 2021, 8:44am
12
I don’t know the sequence of commands, we are exploring this problem together
hafijaa
(hafijaa)
April 6, 2021, 8:45am
13
OR
1.lvconvert --repair /dev/vg1/LXDThinPool
2. sudo lvchange -an /dev/vg1/LXDThinPool
tomp
(Thomas Parrott)
April 6, 2021, 8:46am
14
My thinking was:
Although I just tried this now on one of my test boxes and it complains about lack of disk space.
Please can you show output of sudo pvs for me too.
hafijaa
(hafijaa)
April 6, 2021, 8:49am
15
root@lxd1:~# pvs
WARNING: Not using lvmetad because a repair command was run.
WARNING: /dev/my-lvm/containers_Smart–DB-Smart–DB–backup: Thin’s thin-pool needs inspection.
WARNING: /dev/my-lvm/containers_Smart–DB-Smart–DB: Thin’s thin-pool needs inspection.
PV VG Fmt Attr PSize PFree
/dev/sde3 ubuntu-vg lvm2 a-- <248.50g 0
/dev/vg1/vol1 my-lvm lvm2 a-- 1023.99g 0
/dev/zd0 vg1 lvm2 a-- <1024.00g 0
tomp
(Thomas Parrott)
April 6, 2021, 8:50am
16
And what were you doing immediately before this issue started occurring?
hafijaa
(hafijaa)
April 6, 2021, 8:56am
17
vgscan --cache
lvchange -ay /dev/vg1/vol1
Alaways I have run those command then start container but lasta from yesterday after run those command container doesn’t start
tomp
(Thomas Parrott)
April 6, 2021, 8:58am
18
And what is vol1 in relation to your LXD containers?
hafijaa
(hafijaa)
April 6, 2021, 9:01am
19
My container get storage from lvm.
tomp
(Thomas Parrott)
April 6, 2021, 9:06am
20
You mean its attached as a custom volume? Because your container’s root disks are on /dev/my-lvm/ volume group. Just wondering why you needed to keep scanning the volume and then activating it.
