LVM storage pool on IncusOS
I am trying to create a cached LVM storage pool on IncusOS. According to this discussion I can do that by reusing a manually created LVM storage pool by setting lvm.vg.force_reuse=true.
First, I am wondering if the LVM service should be enabled on IncusOS to create LVM storage pools? According to the documentation:
The LVM service allows configuring of a clustered LVM storage backend.
I am not using any cluster. But upon creation of the pool I get:
~ % incus storage create backup lvm source=vg_test lvm.vg.force_reuse=true lvm.use_thinpool=true
Error: IncusOS service "lvm" isn't currently enabled
After enabling the LVM service the storage pool gets created successfully and seems functional even if I disable this service later.
Next, upon reboot, I notice the following error on IncusOS log:
[2026/08/13 14:55:53 CEST] lvm: modprobe: ERROR: ctx=0x55f5483ac2a0 path=/lib/modules/7.1.8-zabbly+/kernel/drivers/md/persistent-data/dm-persistent-data.ko error=No such file or directory
[2026/08/13 14:55:53 CEST] lvm: modprobe: ERROR: could not insert 'dm_thin_pool': Unknown symbol in module, or unknown parameter (see dmesg)
[2026/08/13 14:55:53 CEST] lvm:   /sbin/modprobe failed: 1
[2026/08/13 14:55:53 CEST] lvm:   Can't process LV vg_test/test_pool: thin-pool target support missing from kernel?
[2026/08/13 14:55:53 CEST] lvm:   0 logical volume(s) in volume group "vg_test" now active
[2026/08/13 14:55:53 CEST] systemd: lvm-activate-vg_test.service: Main process exited, code=exited, status=5/NOTINSTALLED
[2026/08/13 14:55:53 CEST] systemd: lvm-activate-vg_test.service: Failed with result 'exit-code'.
I created the volume group and thin volume in a separate VM lvm-worker by passing the disk path from the host:
root@lvm-worker:~# vgcreate vg_test /dev/sdb
  Volume group "vg_test" successfully created
root@lvm-worker:~# lvcreate --thinpool test_pool vg_test -L 10G
  Thin pool volume with chunk size 64.00 KiB can address at most <15.88 TiB of data.
  Logical volume "test_pool" created.
The storage pool seems to work fine, but I am wondering if the modprobe errors point to some missing module dependencies to dm-persistent-data.ko in the Zabbly kernel?
I had similar errors when trying to use a volume with cache devices although the storage pool worked again fine in Incus:
[2026/08/13 13:41:17 CEST] lvm: modprobe: ERROR: ctx=0x559cf16682a0 path=/lib/modules/7.1.8-zabbly+/kernel/drivers/md/persistent-data/dm-persistent-data.ko error=No such file or directory
[2026/08/13 13:41:17 CEST] lvm: modprobe: ERROR: could not insert 'dm_cache': Unknown symbol in module, or unknown parameter (see dmesg)
[2026/08/13 13:41:17 CEST] lvm:   /sbin/modprobe failed: 1
[2026/08/13 13:41:17 CEST] lvm:   Can't process LV vg_backup/tm_backup: cache target support missing from kernel?
[2026/08/13 13:41:17 CEST] lvm:   0 logical volume(s) in volume group "vg_backup" now active
[2026/08/13 13:41:17 CEST] audit: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=lvm-activate-vg_backup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[2026/08/13 13:41:17 CEST] systemd: lvm-activate-vg_backup.service: Main process exited, code=exited, status=5/NOTINSTALLED
[2026/08/13 13:41:17 CEST] systemd: lvm-activate-vg_backup.service: Failed with result 'exit-code'.
My system:
IncusOS Version: 202608102114
Installed applications
incus 202608102114
You probably want to check the full boot log. You may be looking at very early boot (initrd) entries which run with a much narrower set of modules than the fully booted system.
Indeed, the messages are quite early in the boot. Right before:
[2026/08/13 16:03:51 CEST] systemd: Finished initrd-multipath.service - Configure basic multipath.
Later in the boot the device is reported to be online.
[2026/08/13 16:03:51 CEST] lvm: PV /dev/sda online, VG vg_backup is complete.
So I guess the messages are benign. It just caught my eye because of ERROR in all caps.
What about the LVM service? Should it be enabled?
The LVM service is really mostly there for LVM cluster, though I believe we also use it to keep /etc/lvm/ clean which is why Incus requires it for pool creation.
