Issue description
I’m trying to install kubernetes on a few lxc ubuntu containers which need to have some raw.lxc properties profile for the image. In the lxc profile, I have this piece of properties:
raw.lxc: |
lxc.mount.auto=sys:rw
which froze my pc after. Note that I have tried lxc.mount.auto=proc:rw
which worked fine. And I also tried all 3 different storage types. I have also tried to wait it out to see if it will goes away because it needs longer start up time but after 30’-1hr, it still hangs. I also tried to removed my storage, network but it didn’t work either. Below is my full profile config:
limits.cpu: "2"
limits.memory: 2GB
limits.memory.swap: "false"
linux.kernel_modules: ip_tables,ip6_tables,nf_nat,overlay,br_netfilter
raw.lxc: |
lxc.apparmor.profile=unconfined
lxc.cap.drop=
lxc.cgroup.devices.allow=a
lxc.mount.auto=proc:rw sys:rw
security.privileged: "true"
security.nesting: "true"
description: LXD profile for Kubernetes
nictype: bridged
parent: lxdbr0
kmsg:
path: /dev/kmsg
source: /dev/kmsg
type: unix-char
pool: default
used_by: []
Required information
Distribution:
arch linux -
Distribution version:
6.6.10-arch1-1 -
The output of “lxc info” or if that fails:
config: {}
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- macaroon_authentication
- network_sriov
- console
- restrict_devlxd
- migration_pre_copy
- infiniband
- maas_network
- devlxd_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- devlxd_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- candid_authentication
- backup_compression
- candid_config
- nvidia_runtime_config
- storage_unmapped
- projects
- candid_config_key
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- snapshot_schedule_aliases
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- rbac
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
- network_type_ovn
- projects_networks
- custom_volume_backup
- backup_override_name
- storage_rsync_compression
- network_type_physical
- network_ovn_nat
- tpm_device_type
- gpu_mdev
- resources_pci_iommu
- resources_network_usb
- resources_disk_address
- network_ovn_dhcp
- projects_limits_instances
- network_state_vlan
- instance_bulk_state_change
- network_gvrp
- instance_pool_move
- gpu_sriov
- pci_device_type
- storage_volume_state
- network_acl
- migration_stateful
- disk_state_quota
- storage_ceph_features
- projects_compression
- certificate_project
- network_ovn_acl
- projects_images_auto_update
- images_default_architecture
- network_ovn_acl_defaults
- gpu_mig
- project_usage
- network_bridge_acl
- warnings
- clustering_join_token
- clustering_description
- server_trusted_proxy
- clustering_update_cert
- storage_api_project
- resources_gpu_usb
- clustering_evacuation
- network_ovn_nat_address
- network_bgp
- network_forward
- custom_volume_refresh
- network_counters_errors_dropped
- metrics
- image_source_project
- clustering_config
- network_peer
- linux_sysctl
- network_dns
- ovn_nic_acceleration
- certificate_self_renewal
- instance_project_move
- storage_volume_project_move
- cloud_init
- network_dns_nat
- database_leader
- instance_all_projects
- clustering_groups
- ceph_rbd_du
- instance_get_full
- qemu_metrics
- gpu_mig_uuid
- event_project
- clustering_evacuation_live
- instance_allow_inconsistent_copy
- network_state_ovn
- storage_volume_api_filtering
- image_restrictions
- storage_zfs_export
- network_dns_records
- storage_zfs_reserve_space
- network_acl_log
- storage_zfs_blocksize
- metrics_cpu_seconds
- instance_snapshot_never
- certificate_token
- instance_nic_routed_neighbor_probe
- event_hub
- agent_nic_config
- projects_restricted_intercept
- metrics_authentication
- images_target_project
- cluster_migration_inconsistent_copy
- cluster_ovn_chassis
- container_syscall_intercept_sched_setscheduler
- storage_lvm_thinpool_metadata_size
- storage_volume_state_total
- instance_file_head
- instances_nic_host_name
- image_copy_profile
- container_syscall_intercept_sysinfo
- clustering_evacuation_mode
- resources_pci_vpd
- qemu_raw_conf
- storage_cephfs_fscache
- network_load_balancer
- vsock_api
- instance_ready_state
- network_bgp_holdtime
- storage_volumes_all_projects
- metrics_memory_oom_total
- storage_buckets
- storage_buckets_create_credentials
- metrics_cpu_effective_total
- projects_networks_restricted_access
- storage_buckets_local
- loki
- acme
- internal_metrics
- cluster_join_token_expiry
- remote_token_expiry
- init_preseed
- storage_volumes_created_at
- cpu_hotplug
- projects_networks_zones
- network_txqueuelen
- cluster_member_state
- instances_placement_scriptlet
- storage_pool_source_wipe
- zfs_block_mode
- instance_generation_id
- disk_io_cache
- amd_sev
- storage_pool_loop_resize
- migration_vm_live
- ovn_nic_nesting
- oidc
- network_ovn_l3only
- ovn_nic_acceleration_vdpa
- cluster_healing
- instances_state_total
- auth_user
- security_csm
- instances_rebuild
- numa_cpu_placement
- custom_volume_iso
- network_allocations
- storage_api_remote_volume_snapshot_copy
- zfs_delegate
- operations_get_query_all_projects
- metadata_configuration
- syslog_socket
- event_lifecycle_name_and_project
- instances_nic_limits_priority
- disk_initial_volume_configuration
- operation_wait
- cluster_internal_custom_volume_copy
- disk_io_bus
- storage_cephfs_create_missing
- instance_move_config
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
auth_user_name: wpham
auth_user_method: unix
environment:
addresses: []
architectures:
- x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----
MIIB7TCCAXOgAwIBAgIRAN+TwLBtKAL0WpGZ20Q/kYowCgYIKoZIzj0EAwMwJzEM
MAoGA1UEChMDTFhEMRcwFQYDVQQDDA5yb290QGFyY2hsaW51eDAeFw0yNDAxMjQw
NDMzMzRaFw0zNDAxMjEwNDMzMzRaMCcxDDAKBgNVBAoTA0xYRDEXMBUGA1UEAwwO
cm9vdEBhcmNobGludXgwdjAQBgcqhkjOPQIBBgUrgQQAIgNiAATPM4qR3WnQmpqq
eIzd0QtreB0hf+04QAl1+zA/7NGQGy/yvjd+ceguyq5sTJx0KZrodt74QOsIuv2n
AFB5cNzLhQmx7m0cA9H8Pz+78TvaBNKAqVBN5J/WcKR48yeSULejYzBhMA4GA1Ud
DwEB/wQEAwIFoDATBgNVHSUEDDAKBggrBgEFBQcDATAMBgNVHRMBAf8EAjAAMCwG
A1UdEQQlMCOCCWFyY2hsaW51eIcEfwAAAYcQAAAAAAAAAAAAAAAAAAAAATAKBggq
hkjOPQQDAwNoADBlAjBM6ra5rtrOwffAlk4YDlOgTSGZa4kQE6XuMsLYECTZ7uSF
yo32pnHZXHjZ9qOBANECMQCPSxKxGUtI5ogM2pK9RXfIhtumvTZOPXIn+e9alFj+
SYHQQldICcjnEXI//RRoHBs=
-----END CERTIFICATE-----
certificate_fingerprint: c977efc0340356f5f7f5b1099599565681862c27890f91c8e2df1873b573f07e
driver: qemu | lxc
driver_version: 8.2.0 | 5.0.3
firewall: nftables
kernel: Linux
kernel_architecture: x86_64
kernel_features:
idmapped_mounts: "true"
netnsid_getifaddrs: "true"
seccomp_listener: "true"
uevent_injection: "true"
unpriv_fscaps: "true"
kernel_version: 6.6.10-arch1-1
lxc_features:
cgroup2: "true"
core_scheduling: "true"
devpts_fd: "true"
idmapped_mounts_v2: "true"
mount_injection_file: "true"
network_ipvlan: "true"
network_l2proxy: "true"
network_veth_router: "true"
pidfd: "true"
seccomp_notify: "true"
os_name: Arch Linux
os_version: ""
project: default
server: lxd
server_clustered: false
server_event_mode: full-mesh
server_name: archlinux
server_pid: 21685
server_version: "5.20"
storage: dir
storage_version: "1"
storage_supported_drivers:
- name: dir
version: "1"
remote: false
- name: lvm
version: 2.03.22(2) (2023-08-02) / 1.02.196 (2023-08-02) / 4.48.0
remote: false
- name: btrfs
version: 6.6.3
remote: false
nproc
32 -
free -h
total used free shared buff/cache available
Mem: 62Gi 10Gi 48Gi 3.8Gi 7.6Gi 51Gi
Swap: 4.0Gi 0B 4.0Gi -
cat /proc/self/cgroup
0::/user.slice/user-1000.slice/user@1000.service/app.slice/app-org.kde.konsole-f5b5472244e14e3bbe022785a9b9cb9b.scope -
cat /proc/1/mounts
/dev/sdd2 / ext4 rw,relatime 0 0
devtmpfs /dev devtmpfs rw,nosuid,size=4096k,nr_inodes=8217104,mode=755,inode64 0 0
tmpfs /dev/shm tmpfs rw,nosuid,nodev,inode64 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
sysfs /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0
securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0
cgroup2 /sys/fs/cgroup cgroup2 rw,nosuid,nodev,noexec,relatime 0 0
pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0
efivarfs /sys/firmware/efi/efivars efivarfs rw,nosuid,nodev,noexec,relatime 0 0
bpf /sys/fs/bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 0 0
proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0
tmpfs /run tmpfs rw,nosuid,nodev,size=13150976k,nr_inodes=819200,mode=755,inode64 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=36,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5167 0 0
hugetlbfs /dev/hugepages hugetlbfs rw,nosuid,nodev,relatime,pagesize=2M 0 0
mqueue /dev/mqueue mqueue rw,nosuid,nodev,noexec,relatime 0 0
debugfs /sys/kernel/debug debugfs rw,nosuid,nodev,noexec,relatime 0 0
tracefs /sys/kernel/tracing tracefs rw,nosuid,nodev,noexec,relatime 0 0
configfs /sys/kernel/config configfs rw,nosuid,nodev,noexec,relatime 0 0
fusectl /sys/fs/fuse/connections fusectl rw,nosuid,nodev,noexec,relatime 0 0
/dev/sdd1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
tmpfs /tmp tmpfs rw,nosuid,nodev,nr_inodes=1048576,inode64 0 0
binfmt_misc /proc/sys/fs/binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime 0 0
tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=6575484k,nr_inodes=1643871,mode=700,uid=1000,gid=1000,inode64 0 0
portal /run/user/1000/doc fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 0 0
lxcfs /var/lib/lxcfs fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other 0 0
tmpfs /var/lib/lxd/shmounts tmpfs rw,relatime,size=100k,mode=711,inode64 0 0
tmpfs /var/lib/lxd/devlxd tmpfs rw,relatime,size=100k,mode=755,inode64 0 0
Information to attach
subgid and subuid
user:100000:65536
root:1000000:1000000000 -
/etc/lxc/default.conf
lxc.net.0.type = veth
lxc.net.0.link = lxcbr0
lxc.net.0.flags = up
lxc.net.0.hwaddr = 00:16:3e:xx:xx:xx -
/etc/default/lxc-net
USE_LXC_BRIDGE=“true”
LXC_BRIDGE=“lxcbr0”
LXC_ADDR=“10.0.3.1”
LXC_NETMASK=“255.255.255.0”
LXC_NETWORK=“10.0.3.0/24”
LXC_DHCP_RANGE=“10.0.3.2,10.0.3.254”
LXC_DHCP_MAX=“253” -
Any relevant kernel output (
dmesg
[ 709.848010] lxdbr0: port 1(veth29f91374) entered blocking state
[ 709.848025] lxdbr0: port 1(veth29f91374) entered disabled state
[ 709.848035] veth29f91374: entered allmulticast mode
[ 709.848085] veth29f91374: entered promiscuous mode
[ 709.848135] lxdbr0: port 1(veth29f91374) entered blocking state
[ 709.848138] lxdbr0: port 1(veth29f91374) entered forwarding state
[ 709.848383] lxdbr0: port 1(veth29f91374) entered disabled state
[ 709.857968] veth29f91374: left allmulticast mode
[ 709.857971] veth29f91374: left promiscuous mode
[ 709.857992] lxdbr0: port 1(veth29f91374) entered disabled state
[ 714.977598] lxdbr0: port 1(veth3bc69d9b) entered blocking state
[ 714.977607] lxdbr0: port 1(veth3bc69d9b) entered disabled state
[ 714.977619] veth3bc69d9b: entered allmulticast mode
[ 714.977664] veth3bc69d9b: entered promiscuous mode
[ 714.984166] veth3bc69d9b: left allmulticast mode
[ 714.984169] veth3bc69d9b: left promiscuous mode
[ 714.984191] lxdbr0: port 1(veth3bc69d9b) entered disabled state
[ 720.103524] lxdbr0: port 1(veth80f7c88e) entered blocking state
[ 720.103528] lxdbr0: port 1(veth80f7c88e) entered disabled state
[ 720.103535] veth80f7c88e: entered allmulticast mode
[ 720.103577] veth80f7c88e: entered promiscuous mode
[ 720.111064] veth80f7c88e: left allmulticast mode
[ 720.111067] veth80f7c88e: left promiscuous mode
[ 720.111090] lxdbr0: port 1(veth80f7c88e) entered disabled state -
Container log (
lxc info NAME --show-log
Status: STOPPED
Type: container
Created: 2024/01/25 09:45 AEDT
Last Used: 2024/01/25 09:45 AEDT
Log:
- Container configuration (
lxc config show NAME --expanded
image.architecture: amd64
image.description: ubuntu 22.04 LTS amd64 (release) (20240123)
image.label: release
image.os: ubuntu
image.release: jammy
image.serial: "20240123"
image.type: squashfs
image.version: "22.04"
limits.cpu: "2"
limits.memory: 2GB
raw.lxc: |
lxc.cap.drop=
volatile.base_image: 1d32d0a8227079e9175b0127ae357c7f4890b5b25f1112ff195bee28338a3ed1
volatile.cloud-init.instance-id: 0da60c5b-1deb-4bd8-9267-9916529ee5e3
volatile.eth0.hwaddr: 00:16:3e:f1:f4:bb
volatile.idmap.base: "0"
volatile.idmap.current: '[]'
volatile.idmap.next: '[]'
volatile.uuid: 49e984b1-cc53-4fe8-b6ce-09a707695ebb
volatile.uuid.generation: 49e984b1-cc53-4fe8-b6ce-09a707695ebb
nictype: bridged
parent: lxdbr0
kmsg:
path: /dev/kmsg
source: /dev/kmsg
type: unix-char
pool: default
- k8s
- Main daemon log (at /var/log/lxd/lxd.log or /var/snap/lxd/common/lxd/logs/lxd.log)
Nothing related at the time I started the container - Output of the daemon with --debug (alternatively output of
lxc monitor
while reproducing the issue)
It froze while doinglxc monitor
so I can’t retrieve the logs. But based on what I have seen, nothing stand out
