Hi there,
I’m trying to set up an LXC container for Gui-Apps. I followed the blog of stgraber (https://stgraber.org/2014/02/09/lxc-1-0-gui-in-containers/) and the programs start.
But the sound is not working.
My host is running Void Linux with kernel 5.7.11_1
I created a debian sid container with lxc-create, installed nvidia drivers. It is an unprivileged container.
Then i tried to play some sound via
aplay test.wav
and that worked. Because many programs rely on pulseaudio, I then installed pulseaudio. There is no sound when pulseaudio is installed, and it only shows the “Dummy Output” as available devices.
I hope you can help me getting the sound work inside the container.
Container Config:
# Template used to create this container: /usr/share/lxc/templates/lxc-download
# Parameters passed to the template:
# Template script checksum (SHA-1): 9893b2e0dba7be0d74cf38537bebe0af939c269c
#lxc.include = /usr/share/lxc/config/nesting.conf
#bind-mounts for nvidia proprietary driver
# Distribution configuration
lxc.arch = linux64
#lxc.mount.entry = tmpfs tmp tmpfs defaults
#lxc.mount.entry = /dev/nvidia-uvm dev/nvidia-uvm none bind,optional,create=file
lxc.mount.entry = /dev/dri dev/dri none bind,optional,create=dir
lxc.mount.entry = /dev/snd dev/snd none bind,optional,create=dir
lxc.mount.entry = /tmp/.X11-unix tmp/.X11-unix none bind,optional,create=dir
lxc.mount.entry = /dev/nvidia0 dev/nvidia0 none bind,optional,create=file
lxc.mount.entry = /dev/nvidiactl dev/nvidiactl none bind,optional,create=file
lxc.mount.entry = /dev/nvidia-modeset dev/nvidia-modeset none bind,optional,create=file
#audio test
#lxc.mount.entry = /home/k/.config/pulse home/k/.config/pulse none bind,optional,create=dir
#lxc.mount.entry = /run/user/1000/pulse/native tmp/pulse/native none rw,bind,create=file 0 0
#lxc.environment = PULSE_SERVER=unix:/tmp/pulse/native
#lxc.cgroup.devices.allow = c 116:* rwm
lxc.idmap = u 0 100000 1000
lxc.idmap = g 0 100000 1000
lxc.idmap = u 1000 1000 1
lxc.idmap = g 1000 1000 1
lxc.idmap = u 1001 101001 64535
lxc.idmap = g 1001 101001 64535
lxc.hook.pre-start=/home/k/.config/lxc/preStartHook.sh
lxc.rootfs.path = dir:/home/k/.local/share/lxc/sid/rootfs
lxc.uts.name = sid
# Network configuration
lxc.net.0.type = veth
lxc.net.0.link = virbr0
lxc.net.0.flags = up
preStartHook.sh:
#!/bin/sh
  mountpoint -q "/sys/fs/cgroup/systemd" \
   || (sudo mkdir -p /sys/fs/cgroup/systemd && sudo mount -t cgroup cgroup -o none,name=systemd /sys/fs/cgroup/systemd)
  for d in /sys/fs/cgroup/*; do
    f=$(basename $d)
    if [ "$f" = "unified" ]; then
        continue
    elif [ "$f" = "cpuset" ]; then
        echo 1 | sudo tee -a $d/cgroup.clone_children;
    elif [ "$f" = "memory" ]; then
        echo 1 | sudo tee -a $d/memory.use_hierarchy;
    fi
    sudo mkdir -p $d/$USER
    sudo chown -R $USER $d/$USER
    echo $PPID > $d/$USER/tasks
  done
PULSE_PATH=$LXC_ROOTFS_PATH/home/k/.pulse_socket
if [ ! -e "$PULSE_PATH" ] || [ -z "$(lsof -n $PULSE_PATH 2>&1)" ]; then
    pactl load-module module-native-protocol-unix auth-anonymous=1 socket=$PULSE_PATH
fi
aplay -L
default
    Playback/recording through the PulseAudio sound server
surround21
    2.1 Surround output to Front and Subwoofer speakers
surround40
    4.0 Surround output to Front and Rear speakers
surround41
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50
    5.0 Surround output to Front, Center and Rear speakers
surround51
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
null
    Discard all samples (playback) or generate zero samples (capture)
lavrate
    Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pulse
    PulseAudio Sound Server
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
hdmi:CARD=NVidia,DEV=0
    HDA NVidia, HDMI 0
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
    HDA NVidia, HDMI 1
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
    HDA NVidia, HDMI 2
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 3
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=4
    HDA NVidia, HDMI 4
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=5
    HDA NVidia, HDMI 5
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=6
    HDA NVidia, HDMI 6
    HDMI Audio Output
dmix:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
    Direct sample mixing device
dmix:CARD=NVidia,DEV=7
    HDA NVidia, HDMI 1
dmix:CARD=NVidia,DEV=8
    HDA NVidia, HDMI 2
dmix:CARD=NVidia,DEV=9
    HDA NVidia, HDMI 3
dmix:CARD=NVidia,DEV=10
    HDA NVidia, HDMI 4
dmix:CARD=NVidia,DEV=11
    HDA NVidia, HDMI 5
dmix:CARD=NVidia,DEV=12
    HDA NVidia, HDMI 6
dsnoop:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
    Direct sample snooping device
dsnoop:CARD=NVidia,DEV=7
    HDA NVidia, HDMI 1
dsnoop:CARD=NVidia,DEV=8
    HDA NVidia, HDMI 2
dsnoop:CARD=NVidia,DEV=9
    HDA NVidia, HDMI 3
dsnoop:CARD=NVidia,DEV=10
    HDA NVidia, HDMI 4
dsnoop:CARD=NVidia,DEV=11
    HDA NVidia, HDMI 5
dsnoop:CARD=NVidia,DEV=12
    HDA NVidia, HDMI 6
hw:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
    Direct hardware device without any conversions
hw:CARD=NVidia,DEV=7
    HDA NVidia, HDMI 1
hw:CARD=NVidia,DEV=8
    HDA NVidia, HDMI 2
hw:CARD=NVidia,DEV=9
    HDA NVidia, HDMI 3
hw:CARD=NVidia,DEV=10
    HDA NVidia, HDMI 4
hw:CARD=NVidia,DEV=11
    HDA NVidia, HDMI 5
hw:CARD=NVidia,DEV=12
    HDA NVidia, HDMI 6
plughw:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
    Hardware device with all software conversions
plughw:CARD=NVidia,DEV=7
    HDA NVidia, HDMI 1
plughw:CARD=NVidia,DEV=8
    HDA NVidia, HDMI 2
plughw:CARD=NVidia,DEV=9
    HDA NVidia, HDMI 3
plughw:CARD=NVidia,DEV=10
    HDA NVidia, HDMI 4
plughw:CARD=NVidia,DEV=11
    HDA NVidia, HDMI 5
plughw:CARD=NVidia,DEV=12
    HDA NVidia, HDMI 6
usbstream:CARD=NVidia
    HDA NVidia
    USB Stream Output
sysdefault:CARD=Generic
    HD-Audio Generic, ALC892 Analog
    Default Audio Device
front:CARD=Generic,DEV=0
    Front speakers
surround21:CARD=Generic,DEV=0
surround40:CARD=Generic,DEV=0
surround41:CARD=Generic,DEV=0
surround50:CARD=Generic,DEV=0
surround51:CARD=Generic,DEV=0
surround71:CARD=Generic,DEV=0
iec958:CARD=Generic,DEV=0
    HD-Audio Generic, ALC892 Digital
    IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=Generic,DEV=0
dmix:CARD=Generic,DEV=1
dsnoop:CARD=Generic,DEV=0
dsnoop:CARD=Generic,DEV=1
hw:CARD=Generic,DEV=0
hw:CARD=Generic,DEV=1
plughw:CARD=Generic,DEV=0
plughw:CARD=Generic,DEV=1
usbstream:CARD=Generic
    HD-Audio Generic
    USB Stream Output
sysdefault:CARD=U192k
    UMC202HD 192k, USB Audio
front:CARD=U192k,DEV=0
    Front speakers
surround21:CARD=U192k,DEV=0
surround40:CARD=U192k,DEV=0
surround41:CARD=U192k,DEV=0
surround50:CARD=U192k,DEV=0
surround51:CARD=U192k,DEV=0
surround71:CARD=U192k,DEV=0
iec958:CARD=U192k,DEV=0
dmix:CARD=U192k,DEV=0
dsnoop:CARD=U192k,DEV=0
hw:CARD=U192k,DEV=0
plughw:CARD=U192k,DEV=0
usbstream:CARD=U192k
    UMC202HD 192k
    USB Stream Output
pacmd list-cards
0 card(s) available.
