On my gentoo host system, lxc-checkconfig gives the following output:
$ lxc-checkconfig
— Namespaces —
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled— Control groups —
Cgroups: enabledCgroup v1 mount points:
/sys/fs/cgroup/openrc
/sys/fs/cgroup/cpuset
/sys/fs/cgroup/cpu
/sys/fs/cgroup/cpuacct
/sys/fs/cgroup/blkio
/sys/fs/cgroup/memory
/sys/fs/cgroup/devices
/sys/fs/cgroup/freezer
/sys/fs/cgroup/net_cls
/sys/fs/cgroup/perf_event
/sys/fs/cgroup/net_prio
/sys/fs/cgroup/hugetlb
/sys/fs/cgroup/pids
/sys/fs/cgroup/rdmaCgroup v2 mount points:
/sys/fs/cgroup/unifiedCgroup v1 systemd controller: missing
Cgroup v1 clone_children flag: enabled
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup cpuset: enabled— Misc —
Veth pair device: enabled, not loaded
Macvlan: enabled, not loaded
Vlan: enabled, not loaded
Bridges: enabled, not loaded
Advanced netfilter: enabled, not loaded
CONFIG_NF_NAT_IPV4: enabled, not loaded
CONFIG_NF_NAT_IPV6: enabled, not loaded
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled, not loaded
FUSE (for use with lxcfs): enabled, not loaded— Checkpoint/Restore —
checkpoint restore: enabled
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: enabled
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: enabled
CONFIG_NETLINK_DIAG: enabled
File capabilities:Note : Before booting a new kernel, you can check its configuration
What does ‘enabled, not loaded’ mean exactly?
