I have a 3 node cluster all built on ubuntu 24.04,
Node1 is running desktop, node2-3 server.
On node1 I am able to build a lxc with apache2 and get it working with the port forwards to node1.
however if I migrate to node2, add in a new forward to node 2 it will not work.
I have confirmed that the services are running in the container after migration.
I have scratch created a new container in node2 with the same result, port forwarding is not working
Ufw is not enabled
Is there a location where I can see any error logs?
