ls -lh /var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/snapshots
total 12K
lrwxrwxrwx 1 root root 76 Nov 8 2018 dbserver -> /var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/dbserver
lrwxrwxrwx 1 root root 78 Nov 8 2018 mailserver -> /var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/mailserver
lrwxrwxrwx 1 root root 77 Jun 30 02:59 webserver -> /var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/webserver
ls -lh /var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/snapshots/webserver
lrwxrwxrwx 1 root root 77 Jun 30 02:59 /var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/snapshots/webserver -> /var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/webserver
ls -lh /var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/storage-pool/default/containers-snapshots
ls: cannot access '/var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/storage-pool/default/containers-snapshots': No such file or directory
ls -lh /var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/storage-pool/default/containers-snapshots/webserver
ls: cannot access '/var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/storage-pool/default/containers-snapshots/webserver': No such file or directory
ok…there seems to be a typo:
root@indianer2:/home/michael# ls -lh /var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/webserver/
total 0
drwxr-xr-x+ 1 100000 100000 78 Sep 26 2018 20181108
drwxr-xr-x+ 1 100000 100000 78 Sep 26 2018 snap3
drwxr-xr-x+ 1 100000 100000 78 Sep 26 2018 snap4
drwxr-xr-x+ 1 100000 100000 78 Sep 26 2018 snap5
drwx--x--x+ 1 root root 78 Sep 26 2018 snap6
total 0
drwx--x--x 1 root root 76 Jun 30 02:37 dbserver
drwx--x--x 1 root root 86 Mai 13 10:49 mailserver
drwx--x--x 1 root root 76 Mai 13 10:50 mailtools
drwx--x--x 1 root root 56 Jun 30 02:38 webserver
stgraber
(Stéphane Graber)
June 30, 2019, 2:19am
43
Ok, can you see if:
sudo rm -Rf /var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/storage-pools/default/containers/webserver
sudo mv /var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/webserver/snap5 /var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/storage-pools/default/containers/webserver
lxc start webserver
Gets things back online somehow?
man…
…you made it!!!
my webserver is online again!
wohoooo!
Thank you very much!
Can you say what the problem was?
ok…just one thing:
i tried to start an export to be sure:
michael@indianer2:~/backup/container/webserver$ lxc export webserver webserver_20190630.tar.gz
Error: Create backup: Backup storage: subvolume snapshot failed, source=/var/snap/lxd/common/lxd/storage-pools/default/containers/webserver, dest=/var/snap/lxd/common/lxd/storage-pools/default/containers/webserver055383746/.backup, output=ERROR: not a subvolume: /var/snap/lxd/common/lxd/storage-pools/default/containers/webserver
this doesnt work.
would this be a further problem?
for the other containers also didnt work:
michael@indianer2:~/backup/container/mailserver$ lxc export mailserver mailserver_20190630.tar.gz
Error: Create backup: Backup storage: subvolume snapshot failed, source=/var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/mailserver/20181108.ro, dest=/var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/mailserver/20181108, output=ERROR: not a subvolume: /var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/mailserver/20181108.ro
michael@indianer2:~/backup/container/mailserver$ cd ../mailtools
michael@indianer2:~/backup/container/mailtools$ lxc export mailtools mailtools_20190630.tar.gz
Error: Create backup: Backup storage: subvolume snapshot failed, source=/var/snap/lxd/common/lxd/storage-pools/default/containers/mailtools, dest=/var/snap/lxd/common/lxd/storage-pools/default/containers/mailtools771957203/.backup, output=ERROR: not a subvolume: /var/snap/lxd/common/lxd/storage-pools/default/containers/mailtools
stgraber
(Stéphane Graber)
June 30, 2019, 3:35am
48
Sounds like a lot of those containers aren’t on btrfs subvolumes, this can get fixed manually by creating btrfs subvolumes in those locations and moving the data over.
I have no idea how volumes on a btrfs storage pool aren’t using btrfs though.
Can you show `nsenter -t $(pgrep daemon.start) -m – /snap/lxd/current/bin/btrfs subvol show /var/snap/lxd/common/lxd/storage-pools/default/
is it possible that there is a – too much in the command?
If i execute this i get
nsenter: failed to execute –: No such file or directory
if i execute:
nsenter -t $(pgrep daemon.start) -m /snap/lxd/current/bin/btrfs subvol show /var/snap/lxd/common/lxd/storage-pools/default/
i get:
/var/snap/lxd/common/lxd/storage-pools/default is toplevel subvolume
short question:
I dont need the snapshots anymore if i have my systems running and am able to export the containers.
Can i simply delete all the snapshots and may be able to export the containers then?
Or wouldn’t that fix the problem?
other point:
i am absolutely thankful that you helped me so much!
stgraber
(Stéphane Graber)
July 1, 2019, 9:58pm
51
If you don’t need the snapshots, I would recommend you atempt to delete them from LXD, then get rid of whatever’s left on the filesystem.
The output from the btrfs
command above is a bit odd as far as the containers are concerned and this will give you trouble when making snapshots or exports down the line.
Once the snapshots are gone, the next step would to manually convert those container directories back into subvolumes so that btrfs subvol show
gets you one entry per container, once that’s done, snapshots, exports, … will all work again properly.
i deleted all snapshots via
lxc delete container/snapshot
now the output of
lxd sql global “SELECT * FROM containers;”
is
| id | node_id | name | architecture | type | ephemeral | creation_date | stateful | last_use_date | description | project_id | expiry_date |
| 1 | 1 | webserver | 2 | 0 | 0 | 2018-09-26T22:06:19+02:00 | 0 | 2019-07-02T10:45:55.608809434+02:00 | | 1 | 0001-01-01T00:00:00Z |
| 2 | 1 | mailserver | 2 | 0 | 0 | 2018-09-26T22:10:35+02:00 | 0 | 2019-07-02T10:45:52.053275161+02:00 | | 1 | 0001-01-01T00:00:00Z |
| 3 | 1 | mailtools | 2 | 0 | 0 | 2018-09-27T08:52:25+02:00 | 0 | 2019-07-02T10:45:54.099506826+02:00 | | 1 | 0001-01-01T00:00:00Z |
| 4 | 1 | dbserver | 2 | 0 | 0 | 2018-09-27T13:34:36+02:00 | 0 | 2019-07-02T10:45:50.486462266+02:00 | | 1 | 0001-01-01T00:00:00Z |
what do i have to delete now? (and how)?
is it possible / will it work if i mount the default.img (e.g. to /mnt/def_leer) and then delete the content via
rm -Rf /mnt/def_leer/containers-snapshots/*
and
rm -Rf /mnt/def_leer/snapshots/*
as sudo?
Or will there be a problem with read-only file system (btrfs subvolumes)?
Edit: Added question for deleting the snapshots from the filesystem
stgraber
(Stéphane Graber)
July 2, 2019, 5:26pm
53
You should definitely try those two as root.
If they don’t work, then each snapshot will likely need:
sudo btrfs property set PATH readonly no
sudo btrfs subvol delete PATH
ok…both rm commands could be executed without problems as sudo.
stgraber:
can you tell me how i have to convert the container directories into subvolumes?
the command (as root)
still gives the output
stgraber
(Stéphane Graber)
July 4, 2019, 4:30am
55
Ok, so for that part you will need to stop all your containers, then mount the btrfs pool in /mnt.
Then for each directory in containers/
(one per container), you’ll need to:
mv NAME NAME.bak
btrfs subvolume create NAME
chown + chmod the newly created directory to match the old one
mv NAME.bak/* NAME/
rmdir NAME
After doing that for all containers, you’ll end up with a filesystem that looks identical in ls -lh
but with each container now backed by a subvolume which can be confirmed with btrfs subvol show
With that done, you should be able to snapshot containers just fine (as well as export, publish, …)
Thank you, thank you, thank you!!!
Now everything works fine again. I was able to export all my containers again.
Snapshots can be made too.
just one little thing i changed:
stgraber:
rmdir NAME
i think this must be
rmdir NAME.bak
if i am not totally wrong - at least this worked for me.
Otherwise i would have deleted the files i already copied, i think.
Thanks a lot and best regards
Michael
stgraber
(Stéphane Graber)
July 5, 2019, 3:30am
57
Oh, indeed, sorry about that
Great to hear that this all worked fine.
