Hi all! I have these containers set on my localhost:
# lxc-ls --fancy
NAME STATE AUTOSTART GROUPS IPV4 IPV6 UNPRIVILEGED
ansible STOPPED 0 - - - false
jenkins RUNNING 0 - 10.0.3.73 - false
k8s-master STOPPED 0 - - - false
In container jenkins (ubuntu) I’ve got a jenkins running on port 8080:
# ssh ubuntu@10.0.3.73
ubuntu@jenkins:~$ curl http://localhost:8080
<html><head><meta http-equiv='refresh' content='1;url=/login?from=%2F'/><script>window.location.replace('/login?from=%2F');</script></head><body style='background-color:white; color:white;'>
Authentication required
You are authenticated as: anonymous
Groups that you are in:
Permission you need to have (but didn't): hudson.model.Hudson.Administer
</body></html>
How can I map the container port to my localhost port? I tried this (following this https://blog.simos.info/how-to-use-the-lxd-proxy-device-to-map-ports-between-the-host-and-the-containers/) way but didn’t work:
# lxc config device add jenkins myport8080 proxy listen=tcp:0.0.0.0:8080 connect=tcp:127.0.0.1:8080
Error: not found
My lxc version
# lxc --version
3.0.3
What is this Error: not found?
this command returns empty:
# lxc config get jenkins
