I run a LXC container on my ubuntu VM by UTM on my mac laptop
but I cannot ping 8.8.8.8 inside my LXC container.
I downloaded lxc via snap
note: I have search many info to fix the problems, it still not work
I can ping my LXC container on my VM and vice versa.
I can ping my LXC container’s default getway on my LXC container
I have done systemctl restart the snap service
or set ipv4 and firewall to false and true , but the problem still exits.
my container info:
lxc config show ubuntu --expanded
architecture: aarch64
image.architecture: arm64
image.description: Ubuntu focal arm64 (20240118_07:42)
image.os: Ubuntu
image.release: focal
image.serial: “20240118_07:42”
image.type: squashfs
image.variant: default
volatile.base_image: 2c855bd13a6d33ff3ea6a9adcf9f6454da4314cd4629d988c98b7da91e00eb09
volatile.cloud-init.instance-id: 57f1f7c4-33fb-40cb-9bc3-9f4a75bc881c
volatile.eth0.host_name: veth84f5e9b3
volatile.eth0.hwaddr: 00:16:3e:d8:ca:72
volatile.idmap.base: “0”
volatile.idmap.current: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000}]’
volatile.idmap.next: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000}]’
volatile.last_state.idmap: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000}]’
volatile.uuid: 0c87c07d-4693-4344-bc7d-cb5d95f1747e
volatile.uuid.generation: 0c87c07d-4693-4344-bc7d-cb5d95f1747e
network: lxdbr0
pool: default
default
description: “”
lxc exec ubuntu – ip a
inet6 ::1/128 scope host
26: eth0@if27: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:d8:ca:72 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.4.135.180/24 brd 10.4.135.255 scope global dynamic eth0
valid_lft 1989sec preferred_lft 1989sec
inet6 fd42:e368:9853:dcf7:216:3eff:fed8:ca72/64 scope global mngtmpaddr noprefixroute
inet6 fe80::216:3eff:fed8:ca72/64 scope link
lxc exec ubuntu – ip r
default via 10.4.135.1 dev eth0 proto dhcp src 10.4.135.180 metric 100
10.4.135.0/24 dev eth0 proto kernel scope link src 10.4.135.180
10.4.135.1 dev eth0 proto dhcp scope link src 10.4.135.180 metric 100
my VM info:
ip a
2: enp0s1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether d6:ae:f7:20:02:a4 brd ff:ff:ff:ff:ff:ff
inet 192.168.64.3/24 metric 100 brd 192.168.64.255 scope global dynamic enp0s1
valid_lft 72951sec preferred_lft 72951sec
inet6 fdbd:2af3:625b:81be:d4ae:f7ff:fe20:2a4/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 2591887sec preferred_lft 604687sec
inet6 fe80::d4ae:f7ff:fe20:2a4/64 scope link
3: br-251cc27d7151: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:59:7f:0b:21 brd ff:ff:ff:ff:ff:ff
inet 172.19.0.1/16 brd 172.19.255.255 scope global br-251cc27d7151
4: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:23:b4:8c:aa brd ff:ff:ff:ff:ff:ff
5: br-df1c5081bc7d: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:34:97:a8:d8 brd ff:ff:ff:ff:ff:ff
inet 172.18.0.1/16 brd 172.18.255.255 scope global br-df1c5081bc7d
22: lxcbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 00:16:3e:00:00:00 brd ff:ff:ff:ff:ff:ff
inet 10.0.3.1/24 brd 10.0.3.255 scope global lxcbr0
25: lxdbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:6e:79:97 brd ff:ff:ff:ff:ff:ff
inet 10.4.135.1/24 scope global lxdbr0
inet6 fd42:e368:9853:dcf7::1/64 scope global
inet6 fe80::216:3eff:fe6e:7997/64 scope link
27: veth84f5e9b3@if26: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether a2:36:90:15:0e:ee brd ff:ff:ff:ff:ff:ff link-netnsid 0
ip r
default via 192.168.64.1 dev enp0s1 proto dhcp src 192.168.64.3 metric 100
10.0.3.0/24 dev lxcbr0 proto kernel scope link src 10.0.3.1 linkdown
10.4.135.0/24 dev lxdbr0 proto kernel scope link src 10.4.135.1
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown
172.18.0.0/16 dev br-df1c5081bc7d proto kernel scope link src 172.18.0.1 linkdown
172.19.0.0/16 dev br-251cc27d7151 proto kernel scope link src 172.19.0.1 linkdown
192.168.64.0/24 dev enp0s1 proto kernel scope link src 192.168.64.3 metric 100
192.168.64.1 dev enp0s1 proto dhcp scope link src 192.168.64.3 metric 100
ip route get in container:
lxc exec ubuntu – ip route get 8.8.8.8
8.8.8.8 via 10.4.135.1 dev eth0 src 10.4.135.180 uid 0
cache
listening from the VM, output:
sudo tcpdump -ni lxdbr0 icmp
[sudo] password for harris:
tcpdump: verbose output suppressed, use -v[v]… for full protocol decode
listening on lxdbr0, link-type EN10MB (Ethernet), snapshot length 262144 bytes
23:01:50.099598 IP 10.4.135.180 > 8.8.8.8: ICMP echo request, id 188, seq 68, length 64
23:01:51.126634 IP 10.4.135.180 > 8.8.8.8: ICMP echo request, id 188, seq 69, length 64
23:01:52.147930 IP 10.4.135.180 > 8.8.8.8: ICMP echo request, id 188, seq 70, length 64
23:01:53.174693 IP 10.4.135.180 > 8.8.8.8: ICMP echo request, id 188, seq 71, length 64
23:01:54.195179 IP 10.4.135.180 > 8.8.8.8: ICMP echo request, id 188, seq 72, length 64
23:01:55.219536 IP 10.4.135.180 > 8.8.8.8: ICMP echo request, id 188, seq 73, length 64
23:01:56.242768 IP 10.4.135.180 > 8.8.8.8: ICMP echo request, id 188, seq 74, length 64
23:01:57.267456 IP 10.4.135.180 > 8.8.8.8: ICMP echo request, id 188, seq 75, length 64
23:01:58.295056 IP 10.4.135.180 > 8.8.8.8: ICMP echo request, id 188, seq 76, length 64
