Hello everyone,
I’m currently running Plex inside a docker container inside an LXC container. The cluster is backed by CEPH storage. The issue I’m encountering though is that sometimes the LXC container runs out of memory. I have this happening for a few other LXC containers too.
The container has a memory limit of 8gb but after a while it gets closer and closer to this limit until it eventually runs out. When this happens I can’t even connect to the container anymore and have to force stop it.
Today when I wanted to investigate the issue a bit further I noticed my Plex LXC was filling up again. So I logged in and started stopping all processed.
I first manually stopped all containers, and then also stopped docker and containerd using systemctl stop.
The strange thing is though that after that the memory usage in both Proxmox and htop still reported 7gb/8gb used:
(I can only add one image, so I’ll add the other one later)
What is weird though is that none of the processes in htop show any significant memory usage.
The command free -m also shows that about 7gb is used:
root@lxc-plex:~/dockercomposers/plexplox# free -m
total used free shared buff/cache available
Mem: 8192 7129 769 0 292 1062
Swap: 0 0 0
Next I ran ps aux to find out the memory usage per process:
root@lxc-plex:~/dockercomposers/plexplox# ps aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.0 168800 8320 ? Ss Mar13 0:26 /sbin/init
root 43 0.0 0.2 74308 20608 ? Ss Mar13 0:02 /lib/systemd/systemd-journald
systemd+ 82 0.0 0.0 17996 3840 ? Ss Mar13 0:00 /lib/systemd/systemd-networkd
root 114 0.0 0.0 3600 640 ? Ss Mar13 0:00 /usr/sbin/cron -f
message+ 115 0.0 0.0 9296 2176 ? Ss Mar13 0:02 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
root 119 0.0 0.0 17164 2688 ? Ss Mar13 0:00 /lib/systemd/systemd-logind
root 124 0.0 0.0 2516 640 pts/0 Ss+ Mar13 0:00 /sbin/agetty -o -p -- \u --noclear --keep-baud - 115200,38400,9600 linux
root 125 0.0 0.0 6120 1152 pts/1 Ss Mar13 0:00 /bin/login -p --
root 126 0.0 0.0 2516 512 pts/2 Ss+ Mar13 0:00 /sbin/agetty -o -p -- \u --noclear - linux
root 132 0.0 0.0 15412 1920 ? Ss Mar13 0:00 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
root 287 0.0 0.0 42652 788 ? Ss Mar13 0:00 /usr/lib/postfix/sbin/master -w
postfix 289 0.0 0.0 43088 896 ? S Mar13 0:00 qmgr -l -t unix -u
root 3367 0.0 0.0 6632 3712 pts/1 S Mar13 0:00 -bash
postfix 519708 0.0 0.0 43052 6400 ? S 18:09 0:00 pickup -l -t unix -u -c
root 519711 0.0 0.0 8088 4096 pts/1 R+ 18:25 0:00 ps aux
ps aux again suggest that there’s barely any memory usage.
Another interesting one is cat /proc/meminfo:
root@lxc-plex:~/dockercomposers/plexplox# cat /proc/meminfo
MemTotal: 8388608 kB
MemFree: 788216 kB
MemAvailable: 1087576 kB
Buffers: 0 kB
Cached: 299360 kB
SwapCached: 0 kB
Active: 6515140 kB
Inactive: 444628 kB
Active(anon): 6337184 kB
Inactive(anon): 323328 kB
Active(file): 177956 kB
Inactive(file): 121300 kB
Unevictable: 0 kB
Mlocked: 221280 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Zswap: 0 kB
Zswapped: 0 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 6660408 kB
Mapped: 0 kB
Shmem: 104 kB
KReclaimable: 787484 kB
Slab: 0 kB
SReclaimable: 0 kB
SUnreclaim: 0 kB
KernelStack: 20336 kB
PageTables: 41200 kB
SecPageTables: 0 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 16314548 kB
Committed_AS: 16080536 kB
VmallocTotal: 34359738367 kB
VmallocUsed: 253936 kB
VmallocChunk: 0 kB
Percpu: 4448 kB
HardwareCorrupted: 0 kB
AnonHugePages: 0 kB
ShmemHugePages: 0 kB
ShmemPmdMapped: 0 kB
FileHugePages: 0 kB
FilePmdMapped: 0 kB
Unaccepted: 0 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
Hugetlb: 0 kB
DirectMap4k: 372040 kB
DirectMap2M: 15124480 kB
DirectMap1G: 17825792 kB
This lists about 6.5gb and 6.3gb respectively for Active and Active(anon).
Even with all this information I have no clue what is using the memory inside this LXC container.
One vague idea I have is that it might have something to do with me mapping the Intel N100 chip to the container so that Plex can do hardware transcoding, but again, this might be something that’s completely unrelated.
Here’s my LXC config /etc/pve/lsx/201.conf:
root@proxmox1:/etc/pve/lxc# cat 201.conf
arch: amd64
cores: 4
features: nesting=1
hostname: lxc-plex
memory: 8192
mp0: /mnt/lxc_shares/Plex/,mp=/mnt/Plex,shared=1
net0: name=eth0,bridge=vmbr0,gw=10.88.20.254,hwaddr=8E:48:71:B7:12:98,ip=10.88.21.201/23,type=veth
onboot: 1
ostype: debian
rootfs: ReplicatedPool_2:vm-201-disk-0,size=100G
swap: 512
lxc.cgroup2.devices.allow: c 226:0 rwm
lxc.cgroup2.devices.allow: c 226:128 rwm
lxc.mount.entry: /dev/dri dev/dri none bind,optional,create=dir
I know I could just restart the container and have things resolved again but I think I have a beautiful scenario now for debugging. Let’s hope I can get some input here to figure out what’s going wrong.
Note: I also crossposted this issue here:
