I try to sync container between 2 hosts.
Profile are differents between source and destination, so I use the -p flag but it fail:
# /snap/bin/lxc copy local:redmine remote:bck-redmine --refresh --mode=push -p default
Error: Failed instance migration: Failed reading migration index header: websocket: close 1006 (abnormal closure): unexpected EOF
lxd monitor display this error on remote:
metadata:
context:
class: websocket
description: Creating instance
err: 'Error transferring instance data: Profile not found'
operation: 7c619393-ee9d-4e65-96e5-4f03947c118e
project: default
level: debug
message: Failure for operation
timestamp: "2022-12-07T11:54:32.61458309+01:00"
type: logging
metadata:
class: websocket
created_at: "2022-12-07T11:54:32.378287067+01:00"
may_cancel: false
metadata:
control: d5876ca2a261aa332f6d21640828d62cdde01b822de519473d08d09a6036b0ca
fs: 64c87cc151aba4249a2f6cb366fd8e0b2fab5b7df307e5c44a7b65fa64fc9ad1
resources:
containers:
- /1.0/containers/bck-redmine
instances:
- /1.0/instances/bck-redmine
status: Failure
status_code: 400
updated_at: "2022-12-07T11:54:32.378287067+01:00"
project: default
timestamp: "2022-12-07T11:54:32.614696903+01:00"
type: operation
Strange thing, it fail on 1 host only, I had a second server with the same specific profile (lanprofile) and it success
Note:
I had to upgrade local LXD from 4.x to 5.8 just before because lxc copy hang (cf my previous question)
my backup script was not bullet proof so multiple execution occured in parralell (now corrected)
bck-redmine is not visible on remote (try to check in lxd database but don’t find how)
Thanks for your time
tomp
(Thomas Parrott)
December 8, 2022, 7:03am
3
So both hosts run lxd 5.8?
Thanks
Yes:
Client version: 5.8
Server version: 5.8
On both server
I just made another test, if I create another container on the same source server with default profile (lxc init test) instead of my custom profile (lanprofile) I can successfully copy it to my remote (/snap/bin/lxc copy local:test remote:bck-test --refresh --mode=push -p default)
The problem seem to be that my -p default flag is not recognised ?
I created on destination a copy of default profile named like the used source profile and it works.
The problem is clearly in -p flag
tomp
(Thomas Parrott)
December 15, 2022, 8:16am
7
Thanks, I’ve assigned this to myself and its on my list to look at.
Thanks for the detail.
tomp
(Thomas Parrott)
December 16, 2022, 1:15pm
8
So I tried to reproduce this (unsuccessfully) using LXD 5.9:
Host A:
lxc profile create foo
lxc profile show default | lxc profile edit foo
lxc profile list
| NAME | DESCRIPTION | USED BY |
| default | Default LXD profile | 2 |
| foo | Default LXD profile | 1 |
lxc init images:alpine/3.17 c1 -p foo
lxc config show c1
image.architecture: amd64
image.description: Alpine 3.17 amd64 (20221213_13:01)
image.os: Alpine
image.release: "3.17"
image.requirements.secureboot: "false"
image.serial: "20221213_13:01"
image.type: squashfs
image.variant: default
volatile.apply_template: create
volatile.base_image: fb6a90c9a45b42c74dbbf2c27551a02a63ecd920016609aaa2758079479b0c0d
volatile.cloud-init.instance-id: bb76df35-0675-4563-b4a9-3764cd2667b1
volatile.eth0.hwaddr: 00:16:3e:94:a3:73
volatile.eth0.name: eth0
volatile.idmap.base: "0"
volatile.uuid: 0c2d28db-519d-436d-8c79-4c6530a06774
devices: {}
- foo
Host B:
lxc profile list
| default | Default LXD profile | 4 |
Host A:
lxc copy c1 hostb: --mode=push --refresh
Error: Requested profile "foo" doesn't exist
lxc copy c1 hostb: --mode=push --refresh -p default
Host B:
lxc config show c1
image.os: Alpine
devices: {}
All seems to be working as expected.
Is your lxc client command also 5.8?
Does using LXD 5.9 fix it?
tomp
(Thomas Parrott)
December 16, 2022, 1:16pm
9
Are you also using different projects?
Thanks for your time, I’me not surprised because as I said, on another server with the same profile it’s works fine
For now, the copy of my default profile on destination with the same name of source profile make the job.
Still don’t updated my servers to 5.9 so I can’t tell you.
I don’t understand your last question (projects ?)
tomp
(Thomas Parrott)
December 21, 2022, 5:24pm
12
I wondered if your instances were in different LXD projects?
