Hey there,
I have the following scenario
container1 → limit disk space of 100GB, used 30GB
lxc copy container1 container2
lxc config device set container2 root size 50GB
lxc start container2
lxc exec container2 – df -h
default/containers/container2 100G 30G 70G
pool is not “updated” with the new parameters
lxc config show → shows the correct value
zfs list gives
default/containers/container1 30G 70G 30G legacy
default/containers/container2 76.9M 50G 29.8G legacy
Since it’s a copy why there isn’t any updates on the used disk space? Also lxc copy happened for like 2-3 seconds.
