We have a 7 node cluster, one of the node’s lxd storage volume was corrupted, couldn’t recover thus i had to delete and create the logical volume, post which I’m unable to run containers.
[lxd_admin@lxd-01 ~]$ lxc launch --target lxd-01.x.com ubuntu:18.04 c1
Creating c1
Error: Failed instance creation: Create instance from image: Failed to run: btrfs subvolume create /var/snap/lxd/common/lxd/storage-pools/lxd_storage/images/2cfc5a5567b8d74c0986f3d8a77a2a78e58fe22ea9abd2693112031f85afa1a1: ERROR: can’t access ‘/var/snap/lxd/common/lxd/storage-pools/lxd_storage/images’: No such file or directory[lxd_admin@lxd-cloud-01 ~]$ lxc storage create lxd_storage btrfs source=/data Error: Config key ‘source’ is node-specific
[lxd_admin@lxd-01 ~]$ lxc storage list
| NAME | DESCRIPTION | DRIVER | STATE | USED BY |
| lxd_storage | | btrfs | CREATED | 12 |
[lxd_admin@lxd-01 ~]$lxc profile show default
config: {}
nictype: bridged
parent: virbr0
pool: lxd_storage
- /1.0/instances/rch
- /1.0/instances/tr1
- /1.0/instances/ts1
Kindly help resolve this issue.
