Ive been trying to follow Canonicals implantation of Micro Cloud - which is know is just packaging up LXC/OVN/Ceph, and Im running into issues with the default network link. Im not following their instructions to the T since Im creating 3 Ubuntu 22.04 VMs, and then building them out from there. Each of the VMs have dual nics assigned to them.
Main nic: eth0 - dhcp from pfsense router
Second nic: ens19 - no ip - using for the distributed networking
Output from the servers is identical for Netplan:
network:
version: 2
ethernets:
dhcp4: true
dhcp6: no
match:
macaddress: 3a:29:b2:d8:8d:25
set-name: eth0
ens19:
dhcp4: no
dhcp6: no
link-local: []
I had to set the link-local since it was showing an IPv6 address, and LXC will ignore it if there is an address.
Output for the interfaces:
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 3a:29:b2:d8:8d:25 brd ff:ff:ff:ff:ff:ff
altname enp0s18
inet 192.168.10.6/24 metric 100 brd 192.168.10.255 scope global dynamic eth0
valid_lft 5178sec preferred_lft 5178sec
inet6 fe80::3829:b2ff:fed8:8d25/64 scope link
3: ens19: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel master ovs-system state UP group default qlen 1000
link/ether e6:c0:3b:78:db:c2 brd ff:ff:ff:ff:ff:ff
altname enp0s19
4: ovs-system: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN group default qlen 1000
link/ether 7a:53:3f:34:ab:23 brd ff:ff:ff:ff:ff:ff
inet6 fe80::7853:3fff:fe34:ab23/64 scope link
5: br-int: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN group default qlen 1000
link/ether fe:d1:3a:47:9f:90 brd ff:ff:ff:ff:ff:ff
inet6 fe80::fcd1:3aff:fe47:9f90/64 scope link
6: genev_sys_6081: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 65000 qdisc noqueue master ovs-system state UNKNOWN group default qlen 1000
link/ether 86:2f:fc:9b:70:3f brd ff:ff:ff:ff:ff:ff
inet6 fe80::4865:a4ff:fef8:b5bb/64 scope link
7: lxdovn1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN group default qlen 1000
link/ether 36:10:a9:c7:89:42 brd ff:ff:ff:ff:ff:ff
inet6 fd44:707e:d19a:dd4a:3410:a9ff:fec7:8942/64 scope global dynamic mngtmpaddr
valid_lft 1786sec preferred_lft 1786sec
inet6 fe80::3410:a9ff:fec7:8942/64 scope link
lxc network output:
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| UPLINK | physical | YES | | | | 1 | CREATED |
| br-int | bridge | NO | | | | 0 | |
| default | ovn | YES | 10.254.30.1/24 | fd42:1a12:c9fd:7108::1/64 | | 2 | CREATED |
| ens19 | physical | NO | | | | 1 | |
| eth0 | physical | NO | | | | 0 | |
| lxdovn1 | bridge | NO | | | | 0 | |
Routing information:
default via 192.168.10.1 dev eth0 proto dhcp src 192.168.10.6 metric 100
8.8.8.8 via 192.168.10.1 dev eth0 proto dhcp src 192.168.10.6 metric 100
192.168.10.0/24 dev eth0 proto kernel scope link src 192.168.10.6 metric 100
192.168.10.1 dev eth0 proto dhcp scope link src 192.168.10.6 metric 100
Lxc default network info:
bridge.mtu: "1442"
ipv4.address: 10.254.30.1/24
ipv4.nat: "true"
ipv6.address: fd42:1a12:c9fd:7108::1/64
ipv6.nat: "true"
network: UPLINK
volatile.network.ipv4.address: 192.168.10.100
type: ovn
- /1.0/instances/u1
- /1.0/profiles/default
managed: true
status: Created
locations:
- cloud1
- cloud3
- cloud2
What in the world am I missing? I can’t ping that volatile IPv4 address.
