I have been using non-systemd guests (gentoo) from a non-systemd host (gentoo) without problem.
Then I need to create a debian guest and I found out that the guest won’t start if /sys/fs/cgroup/systemd
is unmounted (which is the case on gentoo host).
After
# mount -t cgroup -o none,name=systemd systemd /sys/fs/cgroup/systemd
the debian guest could start.
But then no way to exec anything in non-systemd containers:
$ lxc exec guest bash
Error: Failed to retrieve PID of executing child process
$ unmount /sys/fs/cgroup/systemd
guest #
What can explain this and how can I fix the issue ?
