I want to set same ip for lxc forward and ipv4.nat.address?
But when is set in vm I can not see any port outside but ping is ok.
Please can you show the config you are using?
bridge.mtu: "1442"
ipv4.address: 192.168.5.1/24
ipv4.nat: "true"
ipv4.nat.address: XX.XX.61.138
ipv6.address: fd42:d745:d286:a33c::1/64
ipv6.nat: "true"
network: UPLINK
volatile.network.ipv4.address: 10.0.0.110
type: ovn
- /1.0/instances/**
managed: true
lxc network forward create ** XX.XX.61.138 target_address=192.168.5.2
when remove one of them 1) forward or 2) ipv4.nat.address wget google.com respond.
Interesting, I’ll try and recreate to see what is going on.
OK so I’ve gotten round to trying this now, and it seems to work on my system (using Ubuntu Jammy):
I’m using a physical network as the uplink but reusing the lxdbr0 as the uplink interface.
I’ve assigned a single IP from the lxdbr0 subnet for use ipv4.routes on the uplink network:
lxc network show uplink
ipv4.gateway: 10.21.203.1/24
ipv4.ovn.ranges: 10.21.203.21-10.21.203.30
ipv4.routes: 10.21.203.12/32
ovn.ingress_mode: routed
parent: lxdbr0
volatile.last_state.created: "false"
type: physical
I created an OVN network ontop of that:
lxc network create ovn1 --type=ovn network=uplink
Then set the NAT address:
lxc network set ovn1 ipv4.nat.address=10.21.203.12
lxc network show ovn1
bridge.mtu: "1500"
ipv4.address: 10.25.187.1/24
ipv4.nat: "true"
ipv4.nat.address: 10.21.203.12
ipv6.address: fd42:1a9d:35b8:690e::1/64
ipv6.nat: "true"
network: uplink
volatile.network.ipv4.address: 10.21.203.21
type: ovn
Then attached a new instance to the OVN network:
lxc launch images:ubuntu/jammy c1 -n ovn1
lxc ls
| c1 | RUNNING | 10.25.187.2 (eth0) | fd42:1a9d:35b8:690e:216:3eff:fe37:7ab5 (eth0) | CONTAINER | 0 |
lxc exec c1 -- ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=119 time=7.57 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=119 time=8.22 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=119 time=7.16 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=119 time=6.94 ms
Then to check NAT is working, ran tcpdump -i lxdbr0 -nn host 10.21.203.12:
sudo tcpdump -i lxdbr0 -nn host 10.21.203.12
tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
listening on lxdbr0, link-type EN10MB (Ethernet), snapshot length 262144 bytes
16:50:37.220141 IP 10.21.203.12 > 8.8.8.8: ICMP echo request, id 34945, seq 1, length 64
16:50:37.225976 IP 8.8.8.8 > 10.21.203.12: ICMP echo reply, id 34945, seq 1, length 64
16:50:38.221402 IP 10.21.203.12 > 8.8.8.8: ICMP echo request, id 34945, seq 2, length 64
16:50:38.227926 IP 8.8.8.8 > 10.21.203.12: ICMP echo reply, id 34945, seq 2, length 64
16:50:39.223341 IP 10.21.203.12 > 8.8.8.8: ICMP echo request, id 34945, seq 3, length 64
16:50:39.229147 IP 8.8.8.8 > 10.21.203.12: ICMP echo reply, id 34945, seq 3, length 64
16:50:40.224471 IP 10.21.203.12 > 8.8.8.8: ICMP echo request, id 34945, seq 4, length 64
16:50:40.230682 IP 8.8.8.8 > 10.21.203.12: ICMP echo reply, id 34945, seq 4, length 64
So NAT is working as expected.
Now lets add the forward and check NAT still working:
lxc network forward create ovn1 10.21.203.12 target_address=10.25.187.2
16:51:43.653895 IP 10.21.203.12 > 8.8.8.8: ICMP echo request, id 5757, seq 1, length 64
16:51:43.659671 IP 8.8.8.8 > 10.21.203.12: ICMP echo reply, id 5757, seq 1, length 64
16:51:44.655699 IP 10.21.203.12 > 8.8.8.8: ICMP echo request, id 5757, seq 2, length 64
16:51:44.662518 IP 8.8.8.8 > 10.21.203.12: ICMP echo reply, id 5757, seq 2, length 64
16:51:45.656124 IP 10.21.203.12 > 8.8.8.8: ICMP echo request, id 5757, seq 3, length 64
16:51:45.663108 IP 8.8.8.8 > 10.21.203.12: ICMP echo reply, id 5757, seq 3, length 64
16:51:46.657567 IP 10.21.203.12 > 8.8.8.8: ICMP echo request, id 5757, seq 4, length 64
16:51:46.664352 IP 8.8.8.8 > 10.21.203.12: ICMP echo reply, id 5757, seq 4, length 64
Lets check forward is working:
From uplink network:
ping 10.21.203.12
PING 10.21.203.12 (10.21.203.12) 56(84) bytes of data.
64 bytes from 10.21.203.12: icmp_seq=1 ttl=63 time=3.74 ms
64 bytes from 10.21.203.12: icmp_seq=2 ttl=63 time=0.405 ms
64 bytes from 10.21.203.12: icmp_seq=3 ttl=63 time=0.228 ms
Check TCP works:
lxc exec c1 -- apt install nginx
curl http://10.21.203.12
<!DOCTYPE html>
<html>
<head>
<title>Welcome to nginx!</title>
Lets check that another instance connected to the OVN network has its NAT working OK:
lxc launch images:ubuntu/jammy c2 -n ovn1
lxc exec c2 -- ping 8.8.8.8
64 bytes from 8.8.8.8: icmp_seq=1 ttl=119 time=7.04 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=119 time=7.12 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=119 time=5.81 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=119 time=5.98 ms
16:54:37.250531 IP 10.21.203.12 > 8.8.8.8: ICMP echo request, id 2498, seq 1, length 64
16:54:37.256446 IP 8.8.8.8 > 10.21.203.12: ICMP echo reply, id 2498, seq 1, length 64
16:54:38.251913 IP 10.21.203.12 > 8.8.8.8: ICMP echo request, id 2498, seq 2, length 64
16:54:38.257987 IP 8.8.8.8 > 10.21.203.12: ICMP echo reply, id 2498, seq 2, length 64
16:54:39.252461 IP 10.21.203.12 > 8.8.8.8: ICMP echo request, id 2498, seq 3, length 64
16:54:39.258083 IP 8.8.8.8 > 10.21.203.12: ICMP echo reply, id 2498, seq 3, length 64
16:54:40.253818 IP 10.21.203.12 > 8.8.8.8: ICMP echo request, id 2498, seq 4, length 64
16:54:40.259637 IP 8.8.8.8 > 10.21.203.12: ICMP echo reply, id 2498, seq 4, length 64
So seems to work OK using OVN version:
ovn-nbctl --version
ovn-nbctl 22.03.0
Open vSwitch Library 2.17.0
DB Schema 6.1.0
I am using ubuntu 20.04 is this reason?
and may you test lxc exec c1 – wget google.com ?
Is this a related bug to Broken TCP egress when same address is used for network NAT and forward (OVN) · Issue #9765 · lxc/lxd · GitHub
My lxd version is 5.5
I switched to ubuntu 22.04 and everything is ok.
