After reading your post, I realized that I had misread my notes, so I was gettign at least one error due to a mistake on my part. After realize that, I thought I had the problem solved. Unfortunately not. Here are the steps I took.
First, I tried it the same way I did in 3.0.3:
:~$ printf "uid $(id -u) 1001 gid $(id -g) 1001" | lxc config set mycontainer raw.idmap -
Error: Failed to get ID map: invalid raw.idmap line uid 1000 1001 gid 1000 1001
Since that didn’t work, I tried using the input format as described in UID Mappings section here:
https://linuxcontainers.org/lxc/manpages/man5/lxc.container.conf.5.html
:~$ printf "u $(id -u) 1001 1" | lxc config set mycontainer raw.idmap -
Error: Failed to get ID map: invalid raw.idmap line u 1000 1001 1
Since that didn’t work, I tried it like this, still with no luck (notice lxc.idmap instead of raw.idmap):
:~$ printf "u $(id -u) 1001 1" | lxc config set mycontainer lxc.idmap -
Error: Invalid config: Unknown configuration key: lxc.idmap
Then I remembered that in 3.0.3, I created a new profile and set the config for that profile, then assigned it to the container. So I tried it that way with no luck.
lxc profile copy default NewProfile
:~$ printf "uid $(id -u) 1001 gid $(id -g) 1001" | lxc profile set NewProfile raw.idmap -
:~$ lxc profile assign mycontainer NewProfile
I tried it again with the other format, still no luck:
:~$ lxc profile assign nextcloudserver NewProfile
Here is the config for the container in question:
:~$ lxc config show nextcloudserver
image.architecture: x86_64
image.description: Ubuntu 18.04 LTS server (20181206)
image.os: ubuntu
image.release: bionic
volatile.base_image: 2996b81c600423fc1a71e821ad64f027c62a389756a76d42b4e44399b0c74ffa
volatile.eth0.hwaddr: 00:16:3e:10:07:50
volatile.idmap.base: "0"
volatile.idmap.next: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
bensdocuments:
path: /mnt/bensdocuments
source: /mnt/FreeNAS/MediaStoragePool/Documents/
debsfiles:
path: /mnt/debsdocuments
source: /mnt/FreeNAS/MediaStoragePool/DebsDocs/
pictures:
path: /mnt/FreeNasPictures
source: /mnt/FreeNAS/MediaStoragePool/Pictures/
