Running Arch and AUR/LXD.
pacman -Q lxd lxcfs
lxd 4.19-1
lxcfs 4.0.11-1
lxc info --show-log --help
--show-log Show the instance's last 100 log lines?
# lxc info --show-log guard
Status: STOPPED
Type: container
Created: 2021/10/01 14:35 CEST
Last Used: 2021/10/22 19:36 CEST
Log:
lxc guard 20211022173651.121 ERROR start - start.c:core_scheduling:1572 - No such device - Failed to create new core scheduling domain
lxc guard 20211022173651.124 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:867 - Received container state "ABORTING" instead of "RUNNING"
lxc guard 20211022173651.149 ERROR start - start.c:__lxc_start:2068 - Failed to spawn container "guard"
lxc guard 20211022173651.150 WARN start - start.c:lxc_abort:1038 - No such process - Failed to send SIGKILL via pidfd 17 for process 2802
lxc 20211022173656.592 ERROR af_unix - af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Connection reset by peer - Failed to receive response
lxc 20211022173656.594 ERROR commands - commands.c:lxc_cmd_rsp_recv_fds:127 - Failed to receive file descriptors
Actually running the command gets me only 6 lines on a container that keeps failing.
Does the command actually give me the full log?
Does the command only give log for the latest instance start and not for all launch attempts?
Why is there a question mark in the --help line?
Also, unsure why trying to start any containers results in this error, LXD works in seemingly same configuration on another one of my servers and the container seems to be all there in /var/lib/lxd/storage-pools/default/containers/guard
