Ok.
I know.
This is very weird and very likely to have nothing to do with lxc/lxd at all.
I am asking here exactly because it is very strange and insight from knowledgeable people could make the difference.
I am trying to write a python script to automatize container handling.
It generally works quite well but there’s ONE command that hangs completely if/when used under PyCharm (it works perfectly fine if run from the command line).
this minimal example:
import subprocess
image = 'images:ubuntu/bionic'
name = 'name'
r = subprocess.run(['lxc', 'launch', image, name])
print(r)
never prints anything (if and only if run under PyCharm!) and the container is not created at all.
What kind of PyCharm bug could justify such a behavior?
Other commands (e.g.: lxc list
, lxc exec ...
, lxc stop ...
and even lxc delete ...
) seem to work without problems; What’s so special in lxc launch ...
Many Thanks in Advance
