dmesg:
root@odroid:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.190-62 (root@builder_n2) (gcc version 7.4.0 (Ubuntu/Linaro 7.4.0-1ubuntu1~18.04.1) ) #1 SMP PREEMPT Tue Sep 10 01:00:59 -03 2019
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: Hardkernel ODROID-N2
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: reserved mem: __reserved_mem_alloc_size, start:0x0000000005000000, end:0x0000000005400000, len:4 MiB
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000005000000, size 4 MiB
[ 0.000000] OF: reserved mem: initialized node linux,secmon, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ed800000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node linux,ppmgr, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: __reserved_mem_alloc_size, start:0x000000007f800000, end:0x0000000080000000, len:8 MiB
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000007f800000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node linux,meson-fb, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000e5800000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node linux,ion-dev, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000e3000000, size 40 MiB
[ 0.000000] OF: reserved mem: initialized node linux,di_cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000cfc00000, size 308 MiB
[ 0.000000] OF: reserved mem: initialized node linux,codec_mm_cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node linux,codec_mm_reserved, compatible id amlogic, codec-mm-reserved
[ 0.000000] OF: reserved mem: invalid size property in ‘linux,galcore’ node.
[ 0.000000] cma: Reserved 8 MiB at 0x00000000cf400000
[ 0.000000] On node 0 totalpages: 972800
[ 0.000000] DMA zone: 15200 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 972800 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 22 pages/cpu s51992 r8192 d29928 u90112
[ 0.000000] pcpu-alloc: s51992 r8192 d29928 u90112 alloc=22*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 957600
[ 0.000000] Kernel command line: root=/dev/sdb2 rootwait rw console=ttyS0,115200n8 no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode= disablehpd=false cvbscable= overscan=100 monitor_onoff=false logo=osd0,loaded hdmitx=cec3f
[ 0.000000] vout: get hdmimode: 1080p60hz
[ 0.000000] vout: get cvbsmode: 576cvbs
[ 0.000000] [get_max_freq_a53] - max_freq : 1896000
[ 0.000000] [get_max_freq_a73] - max_freq : 1800000
[ 0.000000] hdmitx: voutmode : 0
[ 0.000000] fb: osd0
[ 0.000000] fb: loaded
[ 0.000000] hdmitx: HDMI hdmi_cec_func_config:0x3f
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3279628K/3891200K available (11772K kernel code, 1714K rwdata, 5272K rodata, 4864K init, 1352K bss, 103668K reserved, 507904K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8009080000 - 0xffffff8009c00000 ( 11776 KB)
[ 0.000000] .rodata : 0xffffff8009c00000 - 0xffffff800a130000 ( 5312 KB)
[ 0.000000] .init : 0xffffff800a130000 - 0xffffff800a5f0000 ( 4864 KB)
[ 0.000000] .data : 0xffffff800a5f0000 - 0xffffff800a79ca00 ( 1715 KB)
[ 0.000000] .bss : 0xffffff800a79ca00 - 0xffffff800a8eeb7c ( 1353 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03b60000 ( 59 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ed800000 ( 3800 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GPIO-INTC: support to detect double-edge trigger signal
[ 0.000000] g12a_aoclkc_init: register ao clk ok!
[ 0.000000] Meson chip version = RevA (29:A - 40:0)
[ 0.000000] meson_g12a_sdemmc_init: register amlogic sdemmc clk
[ 0.000000] meson_g12a_gpu_init: register meson gpu clk
[ 0.000000] meson_g12a_media_init: register meson media clk
[ 0.000000] meson_g12a_misc_init: register amlogic g12a misc clks
[ 0.000000] meson_g12a_misc_init: done.
[ 0.000000] g12a_clkc_init initialization complete
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000035] meson_bc_timer: mclk->mux_reg =ffffff800800c190,mclk->reg =ffffff800800e194
[ 0.000591] Console: colour dummy device 80x25
[ 0.000608] Calibrating delay loop (skipped), value calculated using timer frequency… 48.00 BogoMIPS (lpj=96000)
[ 0.000617] pid_max: default: 32768 minimum: 301
[ 0.000704] Security Framework initialized
[ 0.000712] SELinux: Initializing.
[ 0.000745] SELinux: Starting in permissive mode
[ 0.000774] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.000781] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.001369] ftrace: allocating 38459 entries in 151 pages
[ 0.067810] sched-energy: Sched-energy-costs installed from DT
[ 0.067822] CPU0: update cpu_capacity 631
[ 0.067833] ASID allocator initialised with 65536 entries
[ 0.099583] EFI services will not be available.
[ 0.147882] Detected VIPT I-cache on CPU1
[ 0.147928] CPU1: update cpu_capacity 631
[ 0.147930] CPU1: Booted secondary processor [410fd034]
[ 0.180410] Detected VIPT I-cache on CPU2
[ 0.180449] CPU2: update cpu_capacity 920
[ 0.180451] CPU2: Booted secondary processor [410fd092]
[ 0.211963] Detected VIPT I-cache on CPU3
[ 0.211985] CPU3: update cpu_capacity 920
[ 0.211987] CPU3: Booted secondary processor [410fd092]
[ 0.244022] Detected VIPT I-cache on CPU4
[ 0.244043] CPU4: update cpu_capacity 920
[ 0.244045] CPU4: Booted secondary processor [410fd092]
[ 0.276091] Detected VIPT I-cache on CPU5
[ 0.276113] CPU5: update cpu_capacity 920
[ 0.276115] CPU5: Booted secondary processor [410fd092]
[ 0.276193] Brought up 6 CPUs
[ 0.276232] SMP: Total of 6 processors activated.
[ 0.276240] CPU features: detected feature: 32-bit EL0 Support
[ 0.276358] CPU: All CPU(s) started at EL2
[ 0.276394] alternatives: patching kernel code
[ 0.277899] devtmpfs: initialized
[ 0.293083] DMI not present or invalid.
[ 0.293387] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.293408] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.308386] pinctrl core: initialized pinctrl subsystem
[ 0.309349] NET: Registered protocol family 16
[ 0.310708] schedtune: init normalization constants…
[ 0.310720] schedtune: CLUSTER[0-1] min_pwr: 0 max_pwr: 42
[ 0.310726] schedtune: CPU[0] min_pwr: 0 max_pwr: 279
[ 0.310731] schedtune: CPU[1] min_pwr: 0 max_pwr: 279
[ 0.310737] schedtune: CLUSTER[2-5] min_pwr: 0 max_pwr: 64
[ 0.310742] schedtune: CPU[2] min_pwr: 0 max_pwr: 759
[ 0.310747] schedtune: CPU[3] min_pwr: 0 max_pwr: 759
[ 0.310752] schedtune: CPU[4] min_pwr: 0 max_pwr: 759
[ 0.310757] schedtune: CPU[5] min_pwr: 0 max_pwr: 759
[ 0.310762] schedtune: SYSTEM min_pwr: 0 max_pwr: 3700
[ 0.310767] schedtune: using normalization constants mul: 459677581 sh1: 1 sh2: 11
[ 0.310771] schedtune: verify normalization constants…
[ 0.310776] schedtune: max_pwr/2^0: 3700 => norm_pwr: 1024
[ 0.310780] schedtune: max_pwr/2^1: 1850 => norm_pwr: 512
[ 0.310785] schedtune: max_pwr/2^2: 925 => norm_pwr: 256
[ 0.310789] schedtune: max_pwr/2^3: 462 => norm_pwr: 127
[ 0.310793] schedtune: max_pwr/2^4: 231 => norm_pwr: 63
[ 0.310797] schedtune: max_pwr/2^5: 115 => norm_pwr: 31
[ 0.310801] schedtune: configured to support global boosting only
[ 0.324160] cpuidle: using governor menu
[ 0.324263] register canvas platform driver
[ 0.324300] register rdma platform driver
[ 0.324357] aml_vdac_init: module init
[ 0.325611] vdso: 2 pages (1 code @ ffffff8009c07000, 1 data @ ffffff800a5f5000)
[ 0.325627] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.327098] DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.327313] clkmsr: clkmsr: driver init
[ 0.327319] codec_mm_module_init
[ 0.327345] media_configs_system_init
[ 0.327739] pstore: using zlib compression
[ 0.328260] console [pstore-1] enabled
[ 0.328266] pstore: Registered ramoops as persistent store backend
[ 0.328272] ramoops: attached 0x100000@0x7400000, ecc: 0/0
[ 0.330107] aml_iomap: amlogic iomap probe done
[ 0.330514] vpu: driver version: v20190329(8-g12b)
[ 0.330527] vpu: load vpu_clk: 666666667Hz(7)
[ 0.330711] vpu: clktree_init
[ 0.330785] vpu: vpu_probe OK
[ 0.335589] clkmsr: msr_clk_reg0=ffffff800837c004,msr_clk_reg2=ffffff800837e00c
[ 0.335607] clkmsr ffd18004.meson_clk_msr: failed to get msr ring reg0
[ 0.339654] aml_vdac_probe:probe start.cpu_id:6,name:meson-g12ab-vdac
[ 0.339911] aml_vdac_probe: ok
[ 0.340096] canvas_probe reg=00000000ff638000,size=2000
[ 0.340118] canvas maped reg_base =ffffff8008452000
[ 0.346582] rdma_probe,cpu_type:1, ver:0, len:8
[ 0.346827] rdma_register, rdma_table_addr ffffff8008475000 rdma_table_addr_phy cf600000 reg_buf ffffffc0ca220000
[ 0.346840] rdma_register success, handle 1 table_size 32768
[ 0.346846] set_rdma_handle video rdma handle = 1.
[ 0.347815] aml_snd_reg_map[0], reg:ff640000, size:2000
[ 0.347834] aml_snd_reg_map[1], reg:ff642000, size:2000
[ 0.347847] aml_snd_reg_map[2], reg:ff64a000, size:2000
[ 0.347858] aml_snd_reg_map[3], reg:ff656000, size:1800
[ 0.347878] aml_snd_reg_map[4], reg:ffd01000, size:1000
[ 0.347884] amlogic auge_snd_iomap probe done
[ 0.349611] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma
[ 0.349679] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma
[ 0.349685] codec_mm_probe ok
[ 0.350629] cvbs_out: cvbsout_probe, cpu_id:5,name:meson-g12b-cvbsout
[ 0.350641] cvbs_out: clk path:0
[ 0.350648] cvbs_out: cvbs trimming.1.v5: 0xa0, 0x0
[ 0.350751] vout: vout1: register server: cvbs_vout_server
[ 0.350757] cvbs_out: register cvbs module server ok
[ 0.350762] vout: vout2: register server: cvbs_vout2_server
[ 0.350767] cvbs_out: register cvbs module vout2 server ok
[ 0.350773] cvbs_out: chrdev devno 264241152 for disp
[ 0.350925] cvbs_out: create cdev cvbs
[ 0.350931] cvbs_out: cvbsout_probe OK
[ 0.461953] SCSI subsystem initialized
[ 0.462111] usbcore: registered new interface driver usbfs
[ 0.462148] usbcore: registered new interface driver hub
[ 0.462210] usbcore: registered new device driver usb
[ 0.462286] media: Linux media interface: v0.10
[ 0.462318] Linux video capture interface: v2.00
[ 0.462389] pps_core: LinuxPPS API ver. 1 registered
[ 0.462394] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.462414] PTP clock support registered
[ 0.462518] dmi: Firmware registration failed.
[ 0.462814] secmon: reserve_mem_size:0x300000
[ 0.462884] secmon secmon: assigned reserved memory node linux,secmon
[ 0.462891] secmon: clear_range:5100000 200000
[ 0.463067] secmon: get page:ffffffbf00140000, 5000
[ 0.463085] secmon: share in base: 0xffffffc0050fe000, share out base: 0xffffffc0050ff000
[ 0.463091] secmon: phy_in_base: 0x50fe000, phy_out_base: 0x50ff000
[ 0.463614] hdmitx: system: amhdmitx_probe start
[ 0.463620] hdmitx: system: Ver: 20181019
[ 0.463645] hdmitx: system: hdmitx_device.chip_type : 11
[ 0.463671] hdmitx: system: not find product desc
[ 0.463676] hdmitx: system: not find match pwr-ctl
[ 0.463705] hdmitx: system: not find drm_amhdmitx
[ 0.463724] hdmitx: system: hpd irq = 41
[ 0.463812] hdmitx: system: hdcp22_tx_skp failed to probe
[ 0.463819] hdmitx: system: hdcp22_tx_esm failed to probe
[ 0.464115] vout: vout1: register server: hdmitx_vout_server
[ 0.464124] vout: vout2: register server: hdmitx_vout2_server
[ 0.464441] hdmitx: hdmitx20: Mapped PHY: 0xffd00000
[ 0.464455] hdmitx: hdmitx20: Mapped PHY: 0xff634400
[ 0.464465] hdmitx: hdmitx20: Mapped PHY: 0xff900000
[ 0.464482] hdmitx: hdmitx20: Mapped PHY: 0xff800000
[ 0.464489] hdmitx: hdmitx20: Mapped PHY: 0xff63c000
[ 0.464494] hdmitx: hdmitx20: Mapped PHY: 0xffd00000
[ 0.464500] hdmitx: hdmitx20: Mapped PHY: 0xff608000
[ 0.464505] hdmitx: hdmitx20: Mapped PHY: 0xff600000
[ 0.464511] hdmitx: hdmitx20: Mapped PHY: 0xffe01000
[ 0.464521] hdmitx: hw: hdmitx_get_format:0x10
[ 0.464526] hdmitx: hw: P_HHI_HDMI_CLK_CNTL :0x100
[ 0.464530] hdmitx: hw: P_HHI_HDMI_PLL_CNTL :0x2b1504f7
[ 0.464771] hdmitx: hw: avmute set to 1
[ 0.464833] hdmitx: system: amhdmitx_probe end
[ 0.465323] vout: create vout attribute OK
[ 0.465435] vout: vout_fops_create OK
[ 0.465442] vout: vout1: register server: nulldisp_vout_server
[ 0.465467] cvbs_out: mode is 1,sync_duration_den=1,sync_duration_num=50
[ 0.465473] cvbs_out: SET cvbs mode: 576cvbs
[ 0.465489]
vdac_enable: on:0,module_sel:8
[ 0.465498] set_vmode_clk start
[ 0.465503] config g12a hdmi_pll
[ 0.465661] cvbs_set_vid2_clk
[ 0.465697] set_vmode_clk DONE
[ 0.465708] cvbs_out: cvbs_performance_enhancement
[ 0.465716] vout: init mode 576cvbs set ok
[ 0.465777] vout: aml_tvout_mode_monitor
[ 0.465789] vout: aml_vout_probe OK
[ 0.465922] chip type:0x29
[ 0.466211] Advanced Linux Sound Architecture Driver Initialized.
[ 0.466788] NetLabel: Initializing
[ 0.466795] NetLabel: domain hash size = 128
[ 0.466800] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.466838] NetLabel: unlabeled traffic allowed by default
[ 0.467918] clocksource: Switched to clocksource arch_sys_counter
[ 0.507242] VFS: Disk quotas dquot_6.6.0
[ 0.507296] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.513444] dtv_dmd:[amldtvdemod…]aml_dtvdemod_init.
[ 0.513782] NET: Registered protocol family 2
[ 0.514168] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.514349] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.514538] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.514589] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.514625] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.514766] NET: Registered protocol family 1
[ 0.516322] Unpacking initramfs…
[ 0.516337] Initramfs unpacking failed: junk in compressed archive
[ 0.519216] Freeing initrd memory: 8972K
[ 0.520347] hw perfevents: clusterb_enabled = 1
[ 0.520359] hw perfevents: cpumasks 0x3, 0x3c
[ 0.520383] hw perfevents: cluster A irq = 18
[ 0.520409] hw perfevents: cluster B irq = 19
[ 0.520458] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.521951] audit: initializing netlink subsys (disabled)
[ 0.521991] audit: type=2000 audit(0.472:1): initialized
[ 0.522476] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.528256] Registering sdcardfs 0.1
[ 0.528984] SELinux: Registering netfilter hooks
[ 0.531393] NET: Registered protocol family 38
[ 0.531405] Key type asymmetric registered
[ 0.531412] Asymmetric key parser ‘x509’ registered
[ 0.531532] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.531540] io scheduler noop registered (default)
[ 0.531545] io scheduler deadline registered
[ 0.531638] io scheduler cfq registered
[ 0.531954] pwm-gpio pwmgpio: 1 gpio pwms loaded
[ 0.532565] meson-pwm ff802000.pwm: pwm pinmux : can’t get pinctrl
[ 0.532765] meson-pwm ffd1b000.pwm: pwm pinmux : can’t get pinctrl
[ 0.533279] random: fast init done
[ 0.533311] random: crng init done
[ 0.533481] gpiomem-aml ff634000.gpiomem: Initialised: Registers at 0xff634000
[ 0.533563] [drm] Initialized
[ 0.533616] mali ffe40000.bifrost: Continuing without Mali regulator control
[ 0.533670] mali ffe40000.bifrost: max pp is 2
[ 0.533677] mali ffe40000.bifrost: set min pp to default 1
[ 0.533683] mali ffe40000.bifrost: min pp is 1
[ 0.533689] mali ffe40000.bifrost: min clk is 4
[ 0.533704] mali ffe40000.bifrost: hiu io source 0xffffff80084d8000
[ 0.533714] mali ffe40000.bifrost: hiu io source 0xffffff80084da000
[ 0.533720] mali ffe40000.bifrost: num of pp used most of time 1
[ 0.533727] mali ffe40000.bifrost: clock dvfs cfg table size is 6
[ 0.533749] mali ffe40000.bifrost: max clk set 4
[ 0.533754] mali ffe40000.bifrost: max clk is 4
[ 0.533760] mali ffe40000.bifrost: turbo clk set to 5
[ 0.533766] mali ffe40000.bifrost: turbo clk is 5
[ 0.533773] mali ffe40000.bifrost: default clk set to 4
[ 0.533778] mali ffe40000.bifrost: default clk is 4
[ 0.533787] mali ffe40000.bifrost: ====================0====================
clk_freq= 285714285, clk_parent=fclk_div7, voltage=1150, keep_count=5, threshod=<100 190>, clk_sample=285
[ 0.533798] mali ffe40000.bifrost: ====================1====================
clk_freq= 400000000, clk_parent=fclk_div5, voltage=1150, keep_count=5, threshod=<152 207>, clk_sample=400
[ 0.533807] mali ffe40000.bifrost: ====================2====================
clk_freq= 500000000, clk_parent=fclk_div4, voltage=1150, keep_count=5, threshod=<180 220>, clk_sample=500
[ 0.533817] mali ffe40000.bifrost: ====================3====================
clk_freq= 666666666, clk_parent=fclk_div3, voltage=1150, keep_count=5, threshod=<210 236>, clk_sample=666
[ 0.533826] mali ffe40000.bifrost: ====================4====================
clk_freq= 800000000, clk_parent=fclk_div2p5, voltage=1150, keep_count=5, threshod=<230 255>, clk_sample=800
[ 0.533835] mali ffe40000.bifrost: ====================5====================
[ 0.533843] mali ffe40000.bifrost: clock dvfs table size is 6
[ 0.533926] mali_plat=ffffff800a67d6d0
[ 0.534021] meson_gcooldev is null, no set min status
[ 0.534027] gpu cooling register okay with err=0
[ 0.534071] meson_gcooldev is null, no set min status
[ 0.534077] gpu core cooling register okay with err=0
[ 0.534100] shader_present=3, tiler_present=1, l2_present=1
[ 0.534188] Mali_pwr_on:gpu_irq : 200
[ 0.534391] mali ffe40000.bifrost: GPU identified as 0x2 arch 7.2.1 r0p0 status 0
[ 0.534693] mali ffe40000.bifrost: Using coherency mode 0 set from dtb
[ 0.535365] mali ffe40000.bifrost: Probed as mali0
[ 0.535595] Unable to detect cache hierarchy for CPU 0
[ 0.538802] loop: module loaded
[ 0.539071] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 0.539369] libphy: Fixed MDIO Bus: probed
[ 0.539872] REG0:Addr = ffffff80084de540
[ 0.539884] Not set cali_val for REG1
[ 0.540274] meson6-dwmac ff3f0000.ethernet: no reset control found
[ 0.540282] stmmac - user ID: 0x11, Synopsys ID: 0x37
[ 0.540287] Ring mode enabled
[ 0.540292] DMA HW capability register supported
[ 0.540297] Normal descriptors
[ 0.540302] RX Checksum Offload Engine supported
[ 0.540307] COE Type 2
[ 0.540311] TX Checksum insertion supported
[ 0.540315] Wake-Up On Lan supported
[ 0.540345] eth%d: device MAC address 00:1e:06:42:1b:88
[ 0.540349] Enable RX Mitigation via HW Watchdog Timer
[ 0.543252] libphy: stmmac: probed
[ 0.543260] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[ 0.543267] eth%d: PHY ID 001cc916 at 7 IRQ POLL (stmmac-0:07)
[ 0.544260] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.544268] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.544549] usbcore: registered new interface driver cdc_acm
[ 0.544555] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.544588] usbcore: registered new interface driver uas
[ 0.544628] usbcore: registered new interface driver usb-storage
[ 0.544689] usbcore: registered new interface driver usbserial
[ 0.544721] usbcore: registered new interface driver usbserial_generic
[ 0.544747] usbserial: USB Serial support registered for generic
[ 0.544973] mousedev: PS/2 mouse device common for all mice
[ 0.545153] i2c /dev entries driver
[ 0.545218] IR IRMP decoder handler initialized
[ 0.546884] lirc_helper: wakeupkey 0xffffffff, protocol 0x1
[ 0.548035] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.548276] hidraw: raw HID events driver © Jiri Kosina
[ 0.548463] usbcore: registered new interface driver usbhid
[ 0.548470] usbhid: USB HID core driver
[ 0.548820] value of voltage_tolerance 0
[ 0.549355] dvfs [meson_cpufreq_init] - cluster 0 freq 1992000
[ 0.549369] cpu cpu0: meson_cpufreq_init: CPU 0 initialized
[ 0.550193] value of voltage_tolerance 0
[ 0.550783] dvfs [meson_cpufreq_init] - cluster 1 freq 1908000
[ 0.550790] dvfs [meson_cpufreq_init] - cluster 1 freq 2004000
[ 0.550799] cpu cpu2: meson_cpufreq_init: CPU 2 initialized
[ 0.550819] cpufreq: cpufreq_online: CPU2: Running at unlisted freq: 999999 KHz
[ 0.552663] cpufreq: cpufreq_online: CPU2: Unlisted initial frequency changed to: 1000000 KHz
[ 0.554288] ff803000.serial: clock gate not found
[ 0.554310] meson_uart ff803000.serial: ==uart0 reg addr = ffffff80084f5000
[ 0.554332] ff803000.serial: ttyS0 at MMIO 0xff803000 (irq = 33, base_baud = 1500000) is a meson_uart
[ 0.554342] meson_uart ff803000.serial: ttyS0 use xtal(24M) 24000000 change 0 to 115200
[ 1.488367] cvbs_out: vdac open.1 = 0x8f6001, 0x0
[ 1.488370]
vdac_enable: on:1,module_sel:8
[ 2.687659] console [ttyS0] enabled
[ 2.691803] amlogic-new-usb2-v2 ffe09000.usb2phy: USB2 phy probe:phy_mem:0xffe09000, iomap phy_base:0xffffff80084f7000
[ 2.702299] amlogic-new-usb3-v2 ffe09080.usb3phy: USB3 phy probe:phy_mem:0xffe09080, iomap phy_base:0xffffff8008625080
[ 2.713899] gpio-keypad ff800000.gpio_keypad: failed to get gpio index from dts
[ 2.720423] gpio-keypad: probe of ff800000.gpio_keypad failed with error -22
[ 2.727747] efusekeynum: 1
[ 2.730482] efusekeyname: uuid offset: 0 size: 32
[ 2.736973] efuse efuse: probe OK!
[ 2.741152] ion_dev soc:ion_dev: assigned reserved memory node linux,ion-dev
[ 2.747809] ge2d: ge2d_init_module
[ 2.751266] ge2d: ge2d_dev major:236
[ 2.755006] ge2d: clock source clk_ge2d_gate ffffffc0c94b1140
[ 2.760817] ge2d: clock clk_ge2d source ffffffc0c94b1000
[ 2.766272] ge2d: clock source clk_vapb_0 ffffffc0c94b1f00
[ 2.771896] ge2d: ge2d init clock is 500000000 HZ, VPU clock is 666666656 HZ
[ 2.779146] ge2d: ge2d clock is 499 MHZ
[ 2.783079] ge2d: find address resource
[ 2.787067] ge2d: map io source 0x00000000ff940000,size=65536 to 0xffffff8008690000
[ 2.794861] ge2d: reserved mem init failed
[ 2.799108] ge2d: ge2d: pdev=ffffffc0ca274800, irq=45, clk=ffffffc0c94b1140
[ 2.806232] ge2d: ge2d start monitor
[ 2.809973] ge2d: ge2d workqueue monitor start
[ 2.810155] amvideom vsync irq: 46
[ 2.810460] amvideocap_probe,amvideocap
[ 2.810461] use cma buf.
[ 2.810558] fb: osd_init_module
[ 2.810692] fb: viu vsync irq: 46
[ 2.810697] fb: viu2 vsync irq: 55
[ 2.810740] 0x000000d8:Y=d8,U=0,V=0
[ 2.810741] 0x000000d9:Y=d9,U=0,V=0
[ 2.810742] 0x000000da:Y=da,U=0,V=0
[ 2.810744] 0x000000db:Y=db,U=0,V=0
[ 2.814581] fb: osd_rdma_init: rdma_table p=0xcf608000,op=0xcf608000 , v=0xffffff800862d000
[ 2.814595] rdma_register, rdma_table_addr ffffff800862f000 rdma_table_addr_phy cf609000 reg_buf ffffffc0ca38e000
[ 2.814596] rdma_register success, handle 2 table_size 4096
[ 2.814597] fb: osd_rdma_init:osd rdma handle = 2.
[ 2.814603] fb: mem_size: 0x800000
[ 2.814604] fb: mem_size: 0x4b80000
[ 2.814604] fb: mem_size: 0x100000
[ 2.814605] fb: mem_size: 0x100000
[ 2.814606] fb: mem_size: 0x800000
[ 2.814636] meson-fb meson-fb: assigned reserved memory node linux,meson-fb
[ 2.814637] fb: reserved memory base:0x000000007f800000, size:800000
[ 2.814704] fb: fb def : 720 576 720 1152 32
[ 2.814705] fb: init fbdev bpp is:32
[ 2.918804] fb: malloc_osd_memory, cma:ffffff800a8579c8
[ 2.918807] fb: malloc_osd_memory, 1288, base:0x000000007f800000, size:8388608
[ 2.918823] fb: use ion buffer for fb memory, fb_index=0
[ 2.942284] meson-fb meson-fb: create ion_client ffffffc0c9d58900, handle=ffffffc0ca382480
[ 2.942288] meson-fb meson-fb: ion memory(0): created fb at 0x00000000e5800000, size 75 MiB
[ 2.942291] fb: Frame buffer memory assigned at
[ 2.942291] fb: 0, phy: 0x00000000e5800000, vir:0xffffff800a8f4000, size=77312K
[ 2.942293] fb: logo_index=0,fb_index=0
[ 2.942295] fb: ---------------clear fb0 memory ffffff800a8f4000
[ 2.968969] fb: osd[0] canvas.idx =0x40
[ 2.968970] fb: osd[0] canvas.addr=0xe5800000
[ 2.968971] fb: osd[0] canvas.width=2880
[ 2.968972] fb: osd[0] canvas.height=576
[ 2.968972] fb: osd[0] frame.width=720
[ 2.968973] fb: osd[0] frame.height=576
[ 2.968974] fb: osd[0] out_addr_id =0x1
[ 2.968979] fb: outputmode changed to 576cvbs, reset osd0, (0, 0, 1919, 1079) -> (0, 0, 719, 575)
[ 2.983561] fb: osd_update_disp_axis_hw:pan_data(0,0,0,0)
[ 2.983563] fb: osd_update_disp_axis_hw:dispdata(0,0,719,575)
[ 3.023586] fb: osd[0] enable: 1 (swapper/0)
[ 3.106671] Console: switching to colour frame buffer device 90x36
[ 3.243615] fb: osd[0] enable: 1 (swapper/0)
[ 3.263915] fb: set osd0 reverse as NONE
[ 3.283615] fb: osd probe OK
[ 3.283740] hdmitx: hdcp: hdmitx_hdcp_init
[ 3.285592] vout: vout2: create vout2 attribute OK
[ 3.290296] vout: vout2: vout2_fops_create OK
[ 3.294721] vout: vout2: register server: nulldisp_vout2_server
[ 3.300799] vout: vout2: init mode null set ok
[ 3.305483] vout: vout2: clktree_init
[ 3.309236] vout: vout2: aml_vout2_probe OK
[ 3.313570] DI: di_module_init ok.
[ 3.317082] DI: di_module_init: major 509
[ 3.321386] deinterlace deinterlace: assigned reserved memory node linux,di_cma
[ 3.328700] DI: CMA size 0x2800000.
[ 3.332343] pre_irq:70
[ 3.334845] post_irq:71
[ 3.337446] DI: di_probe allocate rdma channel 0.
[ 3.342300] di_get_vpu_clkb: get clk vpu error.
[ 3.346980] DI: vpu clkb <334000000, 667000000>
[ 3.351675] DI:enable vpu clkb.
[ 3.354958] 0x000000dc:Y=dc,U=0,V=0
[ 3.358593] 0x000000dd:Y=dd,U=0,V=0
[ 3.362233] 0x000000de:Y=de,U=0,V=0
[ 3.365873] 0x000000df:Y=df,U=0,V=0
[ 3.369512] 0x000000e0:Y=e0,U=0,V=0
[ 3.373152] 0x000000e1:Y=e1,U=0,V=0
[ 3.376791] 0x000000e2:Y=e2,U=0,V=0
[ 3.380431] 0x000000e3:Y=e3,U=0,V=0
[ 3.384071] 0x000000f0:Y=f0,U=0,V=0
[ 3.387708] 0x000000f1:Y=f1,U=0,V=0
[ 3.391353] 0x000000f2:Y=f2,U=0,V=0
[ 3.394991] 0x000000f3:Y=f3,U=0,V=0
[ 3.398631] 0x000000f4:Y=f4,U=0,V=0
[ 3.402271] 0x000000f5:Y=f5,U=0,V=0
[ 3.405912] 0x000000f6:Y=f6,U=0,V=0
[ 3.409551] 0x000000f7:Y=f7,U=0,V=0
[ 3.413195] 0x000000f8:Y=f8,U=0,V=0
[ 3.416832] 0x000000f9:Y=f9,U=0,V=0
[ 3.420471] 0x000000fa:Y=fa,U=0,V=0
[ 3.424111] 0x000000fb:Y=fb,U=0,V=0
[ 3.427748] 0x000000fc:Y=fc,U=0,V=0
[ 3.431391] 0x000000fd:Y=fd,U=0,V=0
[ 3.435033] 0x000000fe:Y=fe,U=0,V=0
[ 3.438671] 0x000000ff:Y=ff,U=0,V=0
[ 3.442311] 0x0000003a:Y=3a,U=0,V=0
[ 3.445952] DI: support multi decoding 254~255~58.
[ 3.450973] DI: di_probe:Di use HRTIMER
[ 3.454933] di_probe:ok
[ 3.457510] vdin_drv_init: major 508
[ 3.461292] vdin_drv_init: vdin driver init done
[ 3.465976] [viuin…]viuin_init_module viuin module init
[ 3.471542] [viuin…]viuin_probe probe ok.
[ 3.475862] [RX]-hdmirx: hdmirx_init.
[ 3.479495] ESM HLD: Initializing…
[ 3.483275] tvin_afe: tvafe_drv_init: major 506
[ 3.488015] tvin_afe: tvafe_drv_init.
[ 3.491774] tvafe_vbi: vbi: vbi_init.
[ 3.495593] amlvid:info: amlvideo_init called
[ 3.499860] amlvid:info: amlvideo_create_instance called
[ 3.505324] amlvid:info: v4l2_dev.name=:amlvideo-000
[ 3.510495] amlvideo-000: V4L2 device registered as video10
[ 3.516158] amlvid:info: amlvideo_create_instance called
[ 3.521619] amlvid:info: v4l2_dev.name=:amlvideo-001
[ 3.526772] amlvideo-001: V4L2 device registered as video23
[ 3.532531] PPMGRDRV: warn: ppmgr module init func called
[ 3.538041] PPMGRDRV: err: ppmgr_driver_probe called
[ 3.543143] Reserved memory: failed to init DMA memory pool at 0x00000000ed800000, size 0 MiB
[ 3.551779] PPMGRDRV: info: ppmgr_dev major:504
[ 3.556715] ionvideo-000: V4L2 device registered as video13
[ 3.562230] ionvideo-001: V4L2 device registered as video14
[ 3.567955] ionvideo-002: V4L2 device registered as video15
[ 3.573664] ionvideo-003: V4L2 device registered as video16
[ 3.579381] ionvideo-004: V4L2 device registered as video17
[ 3.585104] ionvideo-005: V4L2 device registered as video18
[ 3.590822] ionvideo-006: V4L2 device registered as video19
[ 3.596542] ionvideo-007: V4L2 device registered as video20
[ 3.602268] ionvideo-008: V4L2 device registered as video21
[ 3.607934] ionvid: info: Video Technology Magazine Ion Video
[ 3.613833] ionvid: info: Capture Board ver 1.0 successfully loaded
[ 3.620385] videosync_create_instance dev_s ffffffc0c97e8400,dev_s->dev ffffffc0c9d61680
[ 3.628479] videosync_create_instance reg videosync.0
[ 3.633708] aml_vecm_init:module init
[ 3.633710] videosync_thread started
[ 3.641286]
VECM probe start
[ 3.646095] Can’t find wb_sel.
[ 3.649275] hdr:Can’t find cfg_en_osd_100.
[ 3.653611] Can’t find tx_op_color_primary.
[ 3.658026] amlogic, vecm
[ 3.660626] vlock dt support: 1
[ 3.663923] vlock dt new_fsm: 0
[ 3.667208] vlock dt hwver: 0
[ 3.670333] vlock dt phlock_en: 0
[ 3.673803] Can’t find vlock_en.
[ 3.677265] Can’t find vlock_mode.
[ 3.680906] Can’t find vlock_pll_m_limit.
[ 3.685155] Can’t find vlock_line_limit.
[ 3.689316] param_config vlock_en:1
[ 3.692959] vlock_status_init vlock_en:0
[ 3.697025] aml_vecm_probe: ok
[ 3.700301] reg base = ffffff8008637000
[ 3.704600] meson-mmc: mmc driver version: 3.02, 2017-05-15: New Emmc Host Controller
[ 3.712680] meson-mmc: >>>>>>>>hostbase ffffff8008683000, dmode
[ 3.718504] meson-mmc: actual_clock :400000, HHI_nand: 0x80
[ 3.724075] meson-mmc: [meson_mmc_clk_set_rate_v3] after clock: 0x1000033c
[ 3.767924] meson-mmc: meson_mmc_probe() : success!
[ 3.776611] meson-mmc: >>>>>>>>hostbase ffffff800868c000, dmode
[ 3.776820] meson-mmc: emmc: resp_timeout,vstat:0x9dbf0800,virqc:3fff
[ 3.776822] meson-mmc: emmc: err: wait for desc write back, bus_fsm:0x7
[ 3.776832] meson-mmc: meson_mmc_irq_thread_v3 600 emmc: cmd:1
[ 3.776834] meson-mmc: meson_mmc_irq_thread_v3() 616: set 1st retry!
[ 3.776835] meson-mmc: retry cmd 1 the 3-th time(s)
[ 3.784722] meson-mmc: emmc: resp_timeout,vstat:0xa1bf2800,virqc:3fff
[ 3.784724] meson-mmc: emmc: err: wait for irq service, bus_fsm:0x8
[ 3.784733] meson-mmc: meson_mmc_irq_thread_v3 600 emmc: cmd:1
[ 3.784734] meson-mmc: retry cmd 1 the 2-th time(s)
[ 3.791467] meson-mmc: emmc: resp_timeout,vstat:0x9dbf0800,virqc:3fff
[ 3.791468] meson-mmc: emmc: err: wait for desc write back, bus_fsm:0x7
[ 3.791477] meson-mmc: meson_mmc_irq_thread_v3 600 emmc: cmd:1
[ 3.791478] meson-mmc: retry cmd 1 the 1-th time(s)
[ 3.797449] meson-mmc: emmc: resp_timeout,vstat:0x9dbf0800,virqc:3fff
[ 3.797451] meson-mmc: emmc: err: wait for desc write back, bus_fsm:0x7
[ 3.797459] meson-mmc: meson_mmc_irq_thread_v3 600 emmc: cmd:1
[ 3.797460] meson-mmc: Command retried failed line:634, cmd:1
[ 3.803007] meson-mmc: actual_clock :0, HHI_nand: 0x80
[ 3.803008] meson-mmc: [meson_mmc_clk_set_rate_v3] after clock: 0x1000033c
[ 3.893905] meson-mmc: gpio_cd = 1ca
[ 3.935926] meson-mmc: meson_mmc_probe() : success!
[ 3.937060] amlogic mtd driver init
[ 3.940404] cectx ff80023c.aocec: cec driver date:Ver 2019/3/25
[ 3.947823] cectx ff80023c.aocec: compatible:amlogic, aocec-g12a
[ 3.953859] cectx ff80023c.aocec: cecb_ver:0x1
[ 3.958439] cectx ff80023c.aocec: line_reg:0x1
[ 3.963041] cectx ff80023c.aocec: line_bit:0x3
[ 3.967625] cectx ff80023c.aocec: ee_to_ao:0x1
[ 3.972283] input: cec_input as /devices/virtual/input/input0
[ 3.978174] cectx ff80023c.aocec: not find ‘port_num’
[ 3.983317] cectx ff80023c.aocec: using cec:1
[ 3.987829] cectx ff80023c.aocec: no hdmirx regs
[ 3.992589] cectx ff80023c.aocec: no hhi regs
[ 3.997095] cectx ff80023c.aocec: not find ‘output’
[ 4.003555] cectx ff80023c.aocec: irq cnt:2
[ 4.006574] cectx ff80023c.aocec: wakeup_reason:0x0
[ 4.011520] cectx ff80023c.aocec: cev val1: 0x0;val2: 0x0
[ 4.017030] cectx ff80023c.aocec: aml_cec_probe success end
[ 4.022853] unifykey: storage in base: 0xffffffc005000000
[ 4.028293] unifykey: storage out base: 0xffffffc005040000
[ 4.033925] unifykey: storage block base: 0xffffffc005080000
[ 4.039730] unifykey: probe done!
[ 4.043323] unifykey: aml_unifykeys_init done!
[ 4.047819] meson ts init
[ 4.050588] tsensor id: 0
[ 4.053400] tsensor trim info: 0xfa000050!
[ 4.057587] tsensor hireboot: 0xc0ff2a40
[ 4.061688] meson ts init
[ 4.064443] tsensor id: 1
[ 4.067239] tsensor trim info: 0xfa00000f!
[ 4.071452] tsensor hireboot: 0xc0ff2a80
[ 4.075584] audio_dsp: [dsp]register dsp to char divece(257)
[ 4.081412] amaudio: amaudio: driver amaudio init!
[ 4.086427] amaudio: amaudio_init - amaudio: driver amaudio succuess!
[ 4.093050] sysled: module init
[ 4.096255] meson_wdt ffd0f0d0.watchdog: start watchdog
[ 4.101530] meson_wdt ffd0f0d0.watchdog: creat work queue for watch dog
[ 4.108383] meson_wdt ffd0f0d0.watchdog: AML Watchdog Timer probed done
[ 4.115365] meson-saradc ff809000.saradc: set delay per tick to <1ms> by default.
[ 4.122676] meson-saradc ff809000.saradc: set ticks per period to <1> by default.
[ 4.130742] dmc_monitor_probe
[ 4.133745] defendkey ff630218.defendkey: Reserved memory is not enough!
[ 4.140292] defendkey: probe of ff630218.defendkey failed with error -22
[ 4.147371] usbcore: registered new interface driver snd-usb-audio
[ 4.153951] aml_codec_T9015 ff632000.t9015: aml_T9015_audio_codec_probe
[ 4.160241] T9015 acodec used by auge, tdmout:2
[ 4.165426] Error: Driver ‘spdif-dit’ is already registered, aborting…
[ 4.171900] asoc debug: aml_audio_controller_probe-116
[ 4.177690] asoc-aml-card auge_sound: aml_card_probe, parse error -517
[ 4.183689] aml_card_probe error ret:-517
[ 4.187986] aml_tdm_platform_probe, tdm ID = 2, lane_cnt = 4
[ 4.193663] TDM id 2 i2s2hdmi:0
[ 4.196949] snd_tdm ff642000.audiobus:tdmc: lane_mask_out = 1, lane_oe_mask_out = 0
[ 4.204883] snd_tdm ff642000.audiobus:tdmc: aml_tdm_get_pins error!
[ 4.211160] No channel mask node Channel_Mask
[ 4.215915] aml_spdif_platform_probe, spdif ID = 0
[ 4.216083] SPDIF id 0 asrc_id:0 auto_asrc:0
[ 4.216139] spdifout_play_with_zerodata, spdif id:0 enable:0
[ 4.216142] spdif_a fifo ctrl, frddr:0 type:3, 32 bits, chmask 0x3, swap 0x10
[ 4.216145] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[ 4.216150] hdmitx: audio: aout notify format CT_PCM
[ 4.220782] spdif_a is set to enable
[ 4.220787] aml_spdif_platform_probe, register soc platform
[ 4.226516] aml_spdif_platform_probe, spdif ID = 1
[ 4.226556] spdifout_play_with_zerodata, spdif id:1 enable:0
[ 4.226558] spdif_b fifo ctrl, frddr:0 type:3, 32 bits, chmask 0x3, swap 0x10
[ 4.226561] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[ 4.226565] spdif_b is set to enable
[ 4.226568] aml_spdif_platform_probe, register soc platform
[ 4.232476] audio_ddr_mngr: 0, irqs toddr 34, frddr 37
[ 4.237509] audio_ddr_mngr: 1, irqs toddr 35, frddr 38
[ 4.242792] audio_ddr_mngr: 2, irqs toddr 36, frddr 39
[ 4.248196] audiolocker_platform_probe
[ 4.252583] Register vad
[ 4.254785] Netfilter messages via NETLINK v0.30.
[ 4.259587] Initializing XFRM netlink socket
[ 4.263945] NET: Registered protocol family 17
[ 4.268550] Key type dns_resolver registered
[ 4.273416] Registered swp emulation handler
[ 4.277379] Registered cp15_barrier emulation handler
[ 4.282575] Registered setend emulation handler
[ 4.287491] registered taskstats version 1
[ 4.499964] aml_dai_spdif_probe
[ 4.499988] aml_dai_spdif_probe
[ 4.500939] set normal 512 fs /4 fs
[ 4.500960] set spdifout clk:6144000, mpll:24576000
[ 4.500961] get spdifout clk:6143997, mpll:24575987
[ 4.500966] aml_dai_set_spdif_fmt , fmt 0x4010
[ 4.501017] aml_spdif_new spdif_b, clk continuous:1
[ 4.501019] spdifout_play_with_zerodata_free, spdif id:1
[ 4.501172] asoc-aml-card auge_sound: dit-hifi <-> SPDIF-B mapping ok
[ 4.507548] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[ 4.507550] aml_dai_set_tdm_slot(), txmask(0x3), rxmask(0x3)
[ 4.507551] lanes_out_cnt(1), lanes_in_cnt(1)
[ 4.507552] lanes_oe_out_cnt(0), lanes_oe_in_cnt(0)
[ 4.507553] lanes_lb_cnt(0)
[ 4.507554] slots(2), slot_width(32)
[ 4.507559] asoc aml_dai_set_tdm_fmt, 0x4011, ffffffc0ca3a5818, id(2), clksel(2)
[ 4.507563] master_mode(1), binv(1), finv(1) out_skew(2), in_skew(3)
[ 4.514271] asoc-aml-card auge_sound: T9015-audio-hifi <-> TDM-C mapping ok
[ 4.521136] set normal 512 fs /4 fs
[ 4.521147] set spdifout clk:6144000, mpll:24576000
[ 4.521148] get spdifout clk:6143997, mpll:24575987
[ 4.521150] aml_dai_set_spdif_fmt , fmt 0x4010
[ 4.521178] aml_spdif_new spdif_a, clk continuous:1
[ 4.521179] spdifout_play_with_zerodata_free, spdif id:0
[ 4.521307] asoc-aml-card auge_sound: dit-hifi <-> SPDIF mapping ok
[ 4.528081] snd_card_add_kcontrols card:ffffffc002c2b818
[ 4.533011] effect_v2 is not init
[ 4.536474] Not init vad
[ 4.536476] Failed to add VAD controls
[ 4.540382] eq/drc v1 function enable
[ 4.571950] add line-out mute controls
[ 4.572275] dwc3 ff500000.dwc3: Configuration mismatch. dr_mode forced to host
[ 4.580188] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.583232] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 4.591035] usb: xhci: determined sg_tablesize: 4294967295
[ 4.596663] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x20010010
[ 4.605348] xhci-hcd xhci-hcd.0.auto: irq 23, io mem 0xff500000
[ 4.611462] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.618330] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.625699] usb usb1: Product: xHCI Host Controller
[ 4.630722] usb usb1: Manufacturer: Linux 4.9.190-62 xhci-hcd
[ 4.636615] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 4.641835] hub 1-0:1.0: USB hub found
[ 4.645558] hub 1-0:1.0: 2 ports detected
[ 4.649835] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.655340] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 4.663136] usb: xhci: determined sg_tablesize: 4294967295
[ 4.668622] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 4.676862] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.683766] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.691128] usb usb2: Product: xHCI Host Controller
[ 4.696156] usb usb2: Manufacturer: Linux 4.9.190-62 xhci-hcd
[ 4.702048] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 4.707243] hub 2-0:1.0: USB hub found
[ 4.710986] hub 2-0:1.0: 1 port detected
[ 4.715272] hctosys: unable to open rtc device (rtc0)
[ 4.720413] dwc_otg ff400000.dwc2_a: dwc_otg_driver_probe(ffffffc0ca234000)
[ 4.720425] dwc_otg: usb0: type: 2 speed: 0, config: 0, dma: 0, id: 0, phy: ffe09000, ctrl: 0
[ 4.728919] dwc_otg ff400000.dwc2_a: base=0xffffff8008d00000
[ 4.728922] dwc_otg ff400000.dwc2_a: dwc_otg_device=0xffffffc0c958ae00
[ 4.829031] dwc_otg: Core Release: 3.30a
[ 4.829049] dwc_otg: Setting default values for core params
[ 4.833206] dwc_otg: curmode: 0, host_only: 0
[ 4.837715] dwc_otg ff400000.dwc2_a: DMA config: BURST_DEFAULT
[ 4.849839] dwc_otg: Using Buffer DMA mode
[ 4.849856] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1
[ 4.853749] dwc_otg: Working on port type = SLAVE
[ 4.858627] dwc_otg: Dedicated Tx FIFOs mode
[ 4.863898] meson_cdev probe
[ 4.866098] meson_cdev index: 0
[ 4.869428] meson_cdev index: 1
[ 4.872710] thermal: no cluster id, cpucore as one cooldev
[ 4.878290] meson_cdev index: 2
[ 4.881579] cpucore_cooling_register, max_cpu_core_num:6
[ 4.887030] cpucore_cooling_register, clutser[1] core num:4
[ 4.892761] cpucore_cooling_register, clutser[0] core num:2
[ 4.898527] meson_cdev index: 3
[ 4.901780] meson_cdev index: 4
[ 4.905079] find tzd id: 0
[ 4.908013] find tzd id: 0
[ 4.910846] find tzd id: 0
[ 4.913683] meson_cdev probe done
[ 4.917168] gxbb_pm: enter meson_pm_probe!
[ 4.919946] amlogic-new-usb2-v2 ffe09000.usb2phy: —Set port(0) tuning for host cf(xhci_hub_control)–
[ 4.930894] gxbb_pm: meson_pm_probe done
[ 4.935138] ALSA device list:
[ 4.938077] #0: AML-AUGESOUND
[ 4.941448] meson_uart ff803000.serial: ttyS0 use xtal(24M) 24000000 change 115200 to 115200
[ 4.979920] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 5.122261] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610
[ 5.123488] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.130775] usb 1-1: Product: USB2.1 Hub
[ 5.134848] usb 1-1: Manufacturer: GenesysLogic
[ 5.148811] hub 1-1:1.0: USB hub found
[ 5.149063] hub 1-1:1.0: 4 ports detected
[ 5.240026] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 5.262553] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620
[ 5.263774] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.271065] usb 2-1: Product: USB3.1 Hub
[ 5.275131] usb 2-1: Manufacturer: GenesysLogic
[ 5.292801] hub 2-1:1.0: USB hub found
[ 5.293096] hub 2-1:1.0: 4 ports detected
[ 5.583949] usb 2-1.2: new SuperSpeed USB device number 3 using xhci-hcd
[ 5.604716] usb 2-1.2: New USB device found, idVendor=174c, idProduct=55aa
[ 5.606116] usb 2-1.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 5.613581] usb 2-1.2: Product: ASMT1051
[ 5.617647] usb 2-1.2: Manufacturer: asmedia
[ 5.622068] usb 2-1.2: SerialNumber: 123456797C7A
[ 5.633687] scsi host0: uas
[ 5.638425] scsi 0:0:0:0: Direct-Access asmedia ASMT1051 0 PQ: 0 ANSI: 6
[ 5.680695] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 5.680832] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 5.688920] sd 0:0:0:0: [sda] Write Protect is off
[ 5.693123] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 5.693298] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 5.702447] xhci-hcd xhci-hcd.0.auto: ERROR Transfer event for disabled endpoint or incorrect stream ring
[ 5.711999] xhci-hcd xhci-hcd.0.auto: @00000000cf6129f0 00000000 00000000 1b000000 03038001
[ 5.720573] usb 2-1.3: new SuperSpeed USB device number 4 using xhci-hcd
[ 5.720625] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 5.727877] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.756715] usb 2-1.3: New USB device found, idVendor=174c, idProduct=55aa
[ 5.758112] usb 2-1.3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 5.765572] usb 2-1.3: Product: ASMT1051
[ 5.769643] usb 2-1.3: Manufacturer: asmedia
[ 5.774062] usb 2-1.3: SerialNumber: 123456796365
[ 5.782438] scsi host1: uas
[ 5.787173] scsi 1:0:0:0: Direct-Access asmedia ASMT1051 0 PQ: 0 ANSI: 6
[ 5.848605] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 5.848672] sd 1:0:0:0: [sdb] 234455040 512-byte logical blocks: (120 GB/112 GiB)
[ 5.856793] sd 1:0:0:0: [sdb] Write Protect is off
[ 5.861042] usb 2-1.4: new SuperSpeed USB device number 5 using xhci-hcd
[ 5.861052] sd 1:0:0:0: [sdb] Mode Sense: 43 00 00 00
[ 5.861286] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 5.861398] xhci-hcd xhci-hcd.0.auto: ERROR Transfer event for disabled endpoint or incorrect stream ring
[ 5.861402] xhci-hcd xhci-hcd.0.auto: @00000000cf612310 00000000 00000000 1b000000 04038000
[ 5.861529] sd 1:0:0:0: [sdb] Optimal transfer size 33553920 bytes
[ 5.863338] sdb: sdb1 sdb2
[ 5.865080] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 5.928726] usb 2-1.4: New USB device found, idVendor=174c, idProduct=55aa
[ 5.930120] usb 2-1.4: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 5.937587] usb 2-1.4: Product: ASM105x
[ 5.941563] usb 2-1.4: Manufacturer: ASMT
[ 5.945722] usb 2-1.4: SerialNumber: 12345678AB73
[ 5.954884] scsi host2: uas
[ 5.959531] scsi 2:0:0:0: Direct-Access ASMT ASM105x 0 PQ: 0 ANSI: 6
[ 5.992653] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 5.992669] sd 2:0:0:0: [sdc] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 6.000668] sd 2:0:0:0: [sdc] Write Protect is off
[ 6.005084] sd 2:0:0:0: [sdc] Mode Sense: 43 00 00 00
[ 6.005268] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 6.014391] xhci-hcd xhci-hcd.0.auto: ERROR Transfer event for disabled endpoint or incorrect stream ring
[ 6.023955] xhci-hcd xhci-hcd.0.auto: @00000000cf612b70 00000000 00000000 1b000000 05038000
[ 6.032601] sd 2:0:0:0: [sdc] Optimal transfer size 33553920 bytes
[ 6.045801] sd 2:0:0:0: [sdc] Attached SCSI disk
[ 11.211915] vout: aml_tvout_mode_work: monitor_timeout
[ 13.591923] prepare_namespace() wait -1
[ 13.592475] EXT4-fs (sdb2): couldn’t mount as ext3 due to feature incompatibilities
[ 14.554201] EXT4-fs (sdb2): recovery complete
[ 14.555040] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null)
[ 14.560963] VFS: Mounted root (ext4 filesystem) on device 8:18.
[ 14.569779] devtmpfs: mounted
[ 14.571349] Freeing unused kernel memory: 4864K
[ 14.709619] systemd[1]: System time before build time, advancing clock.
[ 14.774167] NET: Registered protocol family 10
[ 14.781611] ip_tables: © 2000-2006 Netfilter Core Team
[ 14.785095] cgroup: cgroup2: unknown option “nsdelegate”
[ 14.797812] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 14.814311] systemd[1]: Detected architecture arm64.
[ 14.832586] systemd[1]: Set hostname to .
[ 14.958538] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 14.970172] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 15.132662] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 15.152553] systemd[1]: Created slice User and Session Slice.
[ 15.168082] systemd[1]: Reached target Remote File Systems.
[ 15.184218] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 15.204033] systemd[1]: Reached target Paths.
[ 15.510289] EXT4-fs (sdb2): re-mounted. Opts: errors=remount-ro
[ 15.537076] register clk_set_setting cpu[41]
[ 15.542414] Registered firmware driver success.
[ 15.545636] Try to load video/h264_multi.bin …
[ 15.552470] firmware_codec firmware_vdec: Direct firmware load for video/h264_multi.bin failed with error -2
[ 15.560014] Error : -2 can’t load the video/h264_multi.bin.
[ 15.565746] get data from fsys fail.
[ 15.569461] invaild file type.
[ 15.572898] Try to load video/h264.bin …
[ 15.577016] firmware_codec firmware_vdec: Direct firmware load for video/h264.bin failed with error -2
[ 15.586448] Error : -2 can’t load the video/h264.bin.
[ 15.591641] get data from fsys fail.
[ 15.591642] invaild file type.
[ 15.591885] Try to load video/h265.bin …
[ 15.591915] firmware_codec firmware_vdec: Direct firmware load for video/h265.bin failed with error -2
[ 15.591917] Error : -2 can’t load the video/h265.bin.
[ 15.591918] get data from fsys fail.
[ 15.591918] invaild file type.
[ 15.592174] Try to load video/h264_enc.bin …
[ 15.593106] load firmware size : 76288, Name : video/h264_enc.bin.
[ 15.593112] start to parse fw package.
[ 15.593116] the package has 0 fws totally.
[ 15.593117] the fw pack ver v0.0.0 is too lower.
[ 15.593118] it may work abnormally so need to be update in time.
[ 15.593488] Try to load video/video_ucode.bin …
[ 15.597424] load firmware size : 768768, Name : video/video_ucode.bin.
[ 15.597462] start to parse fw package.
[ 15.597466] the package has 35 fws totally.
[ 15.597590] the fw gxl_h264_multi.bin is not match.
[ 15.597734] the fw gxl_vp9.bin is not match.
[ 15.597818] the fw gxl_avs.bin is not match.
[ 15.597997] the fw gxl_hevc.bin is not match.
[ 15.598061] the fw gxl_vc1.bin is not match.
[ 15.598157] the fw gxl_h264.bin is not match.
[ 15.598717] the fw gxl_h264_mvc.bin is not match.
[ 15.610688] Amlogic A/V streaming port init
[ 15.611638] get gate demux control ok ffffffc002fc68c0
[ 15.611646] get gate parser_top control ok ffffffc002fc67c0
[ 15.611665] get gate vdec control ok ffffffc002fc66c0
[ 15.611668] get gate clk_81 control failed (null)
[ 15.611691] get gate clk_vdec_mux control ok ffffffc002fc65c0
[ 15.611717] get gate clk_hcodec_mux control ok ffffffc002fc6500
[ 15.611747] get gate clk_hevc_mux control ok ffffffc002fc6400
[ 15.611780] get gate clk_hevcb_mux control ok ffffffc002fc6380
[ 15.611794] get gate ahbarb0 control ok ffffffc002fc6240
[ 15.611796] get gate asyncfifo control failed (null)
[ 15.614001] amvdec_avs module init
[ 15.616251] amvdec_h264 module init
[ 15.621229] ammvdec_h264 module init
[ 15.626593] amvdec_h265 module init
[ 15.634767] amvdec_mmpeg4 module init
[ 15.638165] amvdec_vc1 module init
[ 15.641674] amvdec_vp9 module init
[ 16.101573] systemd-journald[1968]: Received request to flush runtime journal from PID 1
[ 16.106378] systemd-journald[1968]: File /var/log/journal/e00bd6223a7245d0aa6e19e0ab12a024/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 16.366935] Registered IR keymap rc-empty
[ 16.367082] input: meson-ir as /devices/platform/ff808040.meson-ir/rc/rc0/input1
[ 16.367205] rc rc0: meson-ir as /devices/platform/ff808040.meson-ir/rc/rc0
[ 16.370024] meson-ir ff808040.meson-ir: AO_RTI_PIN_MUX : 0x100011
[ 16.370033] meson-ir ff808040.meson-ir: receiver initialized
[ 16.372720] Fine tdm clk setting range (0~2000000), 12287994
[ 16.372989] Fine spdif sysclk setting range(0~2000000), 6143997
[ 16.376664] lirc_dev: IR Remote Control driver registered, major 499
[ 16.377790] rc rc0: lirc_dev: driver ir-lirc-codec (meson-ir) registered at minor = 0
[ 16.377792] IR LIRC bridge handler initialized
[ 16.379685] out of value, fixed it
[ 16.383270] id=0 set inskew=0
[ 16.383388] AED req_sel0 module:TDMOUT_B
[ 16.383444] spk_mute_set: mute flag = 0
[ 16.467653] ionvid: dbg: ionvideo open
[ 16.467731] ionvid: dbg: ionvideo open
[ 16.467765] ionvid: dbg: vidioc_close!!!
[ 16.467771] ionvid: dbg: vidioc_close
[ 16.467809] ionvid: dbg: ionvideo open
[ 16.467816] ionvid: dbg: vidioc_close!!!
[ 16.467821] ionvid: dbg: vidioc_close
[ 16.468054] ionvid: dbg: vidioc_close!!!
[ 16.468065] ionvid: dbg: vidioc_close
[ 16.473241] ionvid: dbg: ionvideo open
[ 16.473616] ionvid: dbg: vidioc_close!!!
[ 16.473624] ionvid: dbg: vidioc_close
[ 16.475767] ionvid: dbg: ionvideo open
[ 16.475882] ionvid: dbg: vidioc_close!!!
[ 16.475887] ionvid: dbg: vidioc_close
[ 16.476977] ionvid: dbg: ionvideo open
[ 16.477096] ionvid: dbg: vidioc_close!!!
[ 16.477102] ionvid: dbg: vidioc_close
[ 16.478673] ionvid: dbg: ionvideo open
[ 16.478858] ionvid: dbg: vidioc_close!!!
[ 16.478872] ionvid: dbg: vidioc_close
[ 16.479875] ionvid: dbg: ionvideo open
[ 16.480031] ionvid: dbg: vidioc_close!!!
[ 16.480038] ionvid: dbg: vidioc_close
[ 16.480954] ionvid: dbg: ionvideo open
[ 16.481302] rtc-pcf8563 3-0051: low voltage detected, date/time is not reliable.
[ 16.483642] ionvid: dbg: vidioc_close!!!
[ 16.483652] ionvid: dbg: vidioc_close
[ 16.483978] rtc-pcf8563 3-0051: rtc core: registered rtc-pcf8563 as rtc0
[ 16.488201] xor: measuring software checksum speed
[ 16.527950] 8regs : 6078.000 MB/sec
[ 16.567960] 8regs_prefetch: 5099.000 MB/sec
[ 16.607926] 32regs : 6952.000 MB/sec
[ 16.647915] 32regs_prefetch: 6794.000 MB/sec
[ 16.647920] xor: using function: 32regs (6952.000 MB/sec)
[ 16.723991] raid6: int64x1 gen() 888 MB/s
[ 16.791960] raid6: int64x1 xor() 815 MB/s
[ 16.859947] raid6: int64x2 gen() 1379 MB/s
[ 16.927916] raid6: int64x2 xor() 1098 MB/s
[ 16.995915] raid6: int64x4 gen() 1847 MB/s
[ 17.063926] raid6: int64x4 xor() 1269 MB/s
[ 17.131941] raid6: int64x8 gen() 1853 MB/s
[ 17.199935] raid6: int64x8 xor() 1277 MB/s
[ 17.267921] raid6: neonx1 gen() 2255 MB/s
[ 17.335928] raid6: neonx1 xor() 1350 MB/s
[ 17.403933] raid6: neonx2 gen() 2653 MB/s
[ 17.471940] raid6: neonx2 xor() 2029 MB/s
[ 17.539928] raid6: neonx4 gen() 3333 MB/s
[ 17.607923] raid6: neonx4 xor() 2610 MB/s
[ 17.675932] raid6: neonx8 gen() 3792 MB/s
[ 17.743914] raid6: neonx8 xor() 2781 MB/s
[ 17.743916] raid6: using algorithm neonx8 gen() 3792 MB/s
[ 17.743918] raid6: … xor() 2781 MB/s, rmw enabled
[ 17.743919] raid6: using intx1 recovery algorithm
[ 17.787059] Btrfs loaded, crc32c=crc32c-generic, assert=on
[ 17.787106] BTRFS: selftest: sectorsize: 4096 nodesize: 4096
[ 17.787107] BTRFS: selftest: Running btrfs free space cache tests
[ 17.787115] BTRFS: selftest: Running extent only tests
[ 17.787123] BTRFS: selftest: Running bitmap only tests
[ 17.787131] BTRFS: selftest: Running bitmap and extent tests
[ 17.787140] BTRFS: selftest: Running space stealing from bitmap to extent
[ 17.787528] BTRFS: selftest: Free space cache tests finished
[ 17.787529] BTRFS: selftest: Running extent buffer operation tests
[ 17.787530] BTRFS: selftest: Running btrfs_split_item tests
[ 17.787555] BTRFS: selftest: Running extent I/O tests
[ 17.787556] BTRFS: selftest: Running find delalloc tests
[ 17.884969] BTRFS: selftest: Running extent buffer bitmap tests
[ 17.947397] BTRFS: selftest: Extent I/O tests finished
[ 17.947400] BTRFS: selftest: Running btrfs_get_extent tests
[ 17.947487] BTRFS: selftest: Running hole first btrfs_get_extent test
[ 17.947500] BTRFS: selftest: Running outstanding_extents tests
[ 17.947526] BTRFS: selftest: Running qgroup tests
[ 17.947527] BTRFS: selftest: Qgroup basic add
[ 17.947556] BTRFS: selftest: Qgroup multiple refs test
[ 17.947594] BTRFS: selftest: Running free space tree tests
[ 17.973233] BTRFS: selftest: sectorsize: 4096 nodesize: 8192
[ 17.973234] BTRFS: selftest: Running btrfs free space cache tests
[ 17.973239] BTRFS: selftest: Running extent only tests
[ 17.973246] BTRFS: selftest: Running bitmap only tests
[ 17.973254] BTRFS: selftest: Running bitmap and extent tests
[ 17.973263] BTRFS: selftest: Running space stealing from bitmap to extent
[ 17.973646] BTRFS: selftest: Free space cache tests finished
[ 17.973647] BTRFS: selftest: Running extent buffer operation tests
[ 17.973648] BTRFS: selftest: Running btrfs_split_item tests
[ 17.973660] BTRFS: selftest: Running extent I/O tests
[ 17.973661] BTRFS: selftest: Running find delalloc tests
[ 18.070893] BTRFS: selftest: Running extent buffer bitmap tests
[ 18.133325] BTRFS: selftest: Extent I/O tests finished
[ 18.133328] BTRFS: selftest: Running btrfs_get_extent tests
[ 18.133417] BTRFS: selftest: Running hole first btrfs_get_extent test
[ 18.133431] BTRFS: selftest: Running outstanding_extents tests
[ 18.133457] BTRFS: selftest: Running qgroup tests
[ 18.133459] BTRFS: selftest: Qgroup basic add
[ 18.133487] BTRFS: selftest: Qgroup multiple refs test
[ 18.133527] BTRFS: selftest: Running free space tree tests
[ 18.159173] BTRFS: selftest: sectorsize: 4096 nodesize: 16384
[ 18.159174] BTRFS: selftest: Running btrfs free space cache tests
[ 18.159178] BTRFS: selftest: Running extent only tests
[ 18.159186] BTRFS: selftest: Running bitmap only tests
[ 18.159194] BTRFS: selftest: Running bitmap and extent tests
[ 18.159203] BTRFS: selftest: Running space stealing from bitmap to extent
[ 18.159586] BTRFS: selftest: Free space cache tests finished
[ 18.159587] BTRFS: selftest: Running extent buffer operation tests
[ 18.159588] BTRFS: selftest: Running btrfs_split_item tests
[ 18.159600] BTRFS: selftest: Running extent I/O tests
[ 18.159601] BTRFS: selftest: Running find delalloc tests
[ 18.257057] BTRFS: selftest: Running extent buffer bitmap tests
[ 18.319466] BTRFS: selftest: Extent I/O tests finished
[ 18.319469] BTRFS: selftest: Running btrfs_get_extent tests
[ 18.319558] BTRFS: selftest: Running hole first btrfs_get_extent test
[ 18.319572] BTRFS: selftest: Running outstanding_extents tests
[ 18.319597] BTRFS: selftest: Running qgroup tests
[ 18.319599] BTRFS: selftest: Qgroup basic add
[ 18.319627] BTRFS: selftest: Qgroup multiple refs test
[ 18.319666] BTRFS: selftest: Running free space tree tests
[ 18.345346] BTRFS: selftest: sectorsize: 4096 nodesize: 32768
[ 18.345348] BTRFS: selftest: Running btrfs free space cache tests
[ 18.345352] BTRFS: selftest: Running extent only tests
[ 18.345360] BTRFS: selftest: Running bitmap only tests
[ 18.345369] BTRFS: selftest: Running bitmap and extent tests
[ 18.345379] BTRFS: selftest: Running space stealing from bitmap to extent
[ 18.345762] BTRFS: selftest: Free space cache tests finished
[ 18.345763] BTRFS: selftest: Running extent buffer operation tests
[ 18.345764] BTRFS: selftest: Running btrfs_split_item tests
[ 18.345778] BTRFS: selftest: Running extent I/O tests
[ 18.345779] BTRFS: selftest: Running find delalloc tests
[ 18.442966] BTRFS: selftest: Running extent buffer bitmap tests
[ 18.505376] BTRFS: selftest: Extent I/O tests finished
[ 18.505379] BTRFS: selftest: Running btrfs_get_extent tests
[ 18.505469] BTRFS: selftest: Running hole first btrfs_get_extent test
[ 18.505485] BTRFS: selftest: Running outstanding_extents tests
[ 18.505512] BTRFS: selftest: Running qgroup tests
[ 18.505513] BTRFS: selftest: Qgroup basic add
[ 18.505541] BTRFS: selftest: Qgroup multiple refs test
[ 18.505581] BTRFS: selftest: Running free space tree tests
[ 18.531285] BTRFS: selftest: sectorsize: 4096 nodesize: 65536
[ 18.531287] BTRFS: selftest: Running btrfs free space cache tests
[ 18.531291] BTRFS: selftest: Running extent only tests
[ 18.531298] BTRFS: selftest: Running bitmap only tests
[ 18.531307] BTRFS: selftest: Running bitmap and extent tests
[ 18.531316] BTRFS: selftest: Running space stealing from bitmap to extent
[ 18.531700] BTRFS: selftest: Free space cache tests finished
[ 18.531701] BTRFS: selftest: Running extent buffer operation tests
[ 18.531703] BTRFS: selftest: Running btrfs_split_item tests
[ 18.531718] BTRFS: selftest: Running extent I/O tests
[ 18.531719] BTRFS: selftest: Running find delalloc tests
[ 18.629060] BTRFS: selftest: Running extent buffer bitmap tests
[ 18.691465] BTRFS: selftest: Extent I/O tests finished
[ 18.691467] BTRFS: selftest: Running btrfs_get_extent tests
[ 18.691558] BTRFS: selftest: Running hole first btrfs_get_extent test
[ 18.691575] BTRFS: selftest: Running outstanding_extents tests
[ 18.691603] BTRFS: selftest: Running qgroup tests
[ 18.691604] BTRFS: selftest: Qgroup basic add
[ 18.691633] BTRFS: selftest: Qgroup multiple refs test
[ 18.691676] BTRFS: selftest: Running free space tree tests
[ 18.756282] BTRFS: device label btrfspool devid 1 transid 36 /dev/sdc
[ 18.816925] device-mapper: uevent: version 1.0.3
[ 18.818703] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 18.943237] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 19.510013] xhci-hcd xhci-hcd.0.auto: ERROR Transfer event for disabled endpoint or incorrect stream ring
[ 19.514111] xhci-hcd xhci-hcd.0.auto: @00000000cf612220 00000000 00000000 1b000000 04048001
[ 20.182118] Fine tdm clk setting range (0~2000000), 12287994
[ 20.182454] Fine spdif sysclk setting range(0~2000000), 6143997
[ 20.188749] out of value, fixed it
[ 20.192065] id=0 set inskew=0
[ 20.192166] AED req_sel0 module:TDMOUT_B
[ 20.192218] spk_mute_set: mute flag = 0
[ 20.673280] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 20.771426] meson6-dwmac ff3f0000.ethernet eth0: fail to init PTP.
[ 20.771886] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 24.844235] meson6-dwmac ff3f0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 24.844258] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 25.340476] cgroup: new mount options do not match the existing superblock, will be ignored
[ 25.374083] fuse init (API version 7.26)
[ 25.734539] meson_uart ff803000.serial: ttyS0 use xtal(24M) 24000000 change 115200 to 115200
[ 26.651433] device-mapper: thin: Data device (dm-1) discard unsupported: Disabling discard passdown.
[ 27.049146] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 27.137092] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 27.594341] ip6_tables: © 2000-2006 Netfilter Core Team
[ 28.269216] BTRFS info (device sdc): disk space caching is enabled
[ 28.269221] BTRFS info (device sdc): has skinny extents
[ 28.273423] BTRFS info (device sdc): detected SSD devices, enabling SSD mode
[ 28.319399] Unable to handle kernel NULL pointer dereference at virtual address 00000044
[ 28.322240] pgd = ffffffc0b1954000
[ 28.326797] [0000000000000044] *pgd=00000000b1971003, *pud=00000000b1971003, *pmd=0000000000000000
[ 28.334669] Internal error: Oops: 96000006 [#1] PREEMPT SMP
[ 28.340387] Modules linked in: macvlan ip6t_MASQUERADE nf_nat_masquerade_ipv6 ip6table_nat nf_conntrack_ipv6 nf_defrag_ipv6 nf_nat_ipv6 ip6table_filter ip6_tables ipt_MASQUERADE nf_nat_masquerade_ipv4 xt_CHECKSUM xt_comment xt_tcpudp iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_mangle iptable_filter bridge stp llc fuse dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio cpufreq_ondemand cpufreq_powersave cpufreq_userspace cpufreq_conservative squashfs dm_mod btrfs raid6_pq xor rtc_pcf8563 i2c_meson_master ir_lirc_codec lirc_dev meson_ir sch_fq_codel amvdec_vp9 amvdec_vc1 amvdec_real amvdec_mmpeg4 amvdec_mpeg4 amvdec_mpeg12 amvdec_mmjpeg amvdec_mjpeg amvdec_h265 amvdec_h264mvc amvdec_mh264 amvdec_h264 amvdec_avs stream_input decoder_common firmware media_clock
[ 28.411191] ip_tables x_tables ipv6
[ 28.413448] CPU: 2 PID: 4416 Comm: lxd Not tainted 4.9.190-62 #1
[ 28.419599] Hardware name: Hardkernel ODROID-N2 (DT)
[ 28.424713] task: ffffffc0c9d1d400 task.stack: ffffffc0b19b0000
[ 28.430786] PC is at __do_page_cache_readahead+0x4c/0x298
[ 28.436328] LR is at ondemand_readahead+0x118/0x278
[ 28.441353] pc : [] lr : [] pstate: 20000145
[ 28.448891] sp : ffffffc0b19b3300
[ 28.452358] x29: ffffffc0b19b3300 x28: ffffffc0b1df8bb8
[ 28.457818] x27: 0000000000000041 x26: 0000000000000000
[ 28.463278] x25: 0000000000000080 x24: 0000000000000400
[ 28.468738] x23: 000000000000003f x22: 0000000000000000
[ 28.474198] x21: 0000000000001300 x20: 0000000000000000
[ 28.479658] x19: 0000000000000000 x18: 0000000000001800
[ 28.485118] x17: 0000000000001400 x16: ffffff8009f41d6a
[ 28.490578] x15: 0000000000001c00 x14: 0000000000001000
[ 28.496040] x13: 0000000000000c00 x12: 0000000000000800
[ 28.501499] x11: 0000000000000400 x10: 0000000000000010
[ 28.506964] x9 : 0000000000000000 x8 : ffffffc0b1b5c440
[ 28.512418] x7 : 0000000000000000 x6 : 000000000000003f
[ 28.517878] x5 : 000000000000003f x4 : 0000000000000041
[ 28.523338] x3 : 0000000000001300 x2 : 0000000000000000
[ 28.528798] x1 : ffffffc0b1df8a50 x0 : 0000000002420048
[ 28.534259]
SP: 0xffffffc0b19b3280:
[ 28.539544] 3280 00000000 00000000 0000003f 00000000 00000400 00000000 00000080 00000000
[ 28.547864] 32a0 00000000 00000000 00000041 00000000 b1df8bb8 ffffffc0 b19b3300 ffffffc0
[ 28.556184] 32c0 091cdcf8 ffffff80 b19b3300 ffffffc0 091cd994 ffffff80 20000145 00000000
[ 28.564504] 32e0 00000022 00000000 00000023 00000000 ffffffff 0000007f 01ef78fc ffffff80
[ 28.572824] 3300 b19b33d0 ffffffc0 091cdcf8 ffffff80 b1b5c400 ffffffc0 00000000 00000000
[ 28.581144] 3320 b1df8bb8 ffffffc0 00000000 00000000 0000003f 00000000 00000400 00000000
[ 28.589464] 3340 00000000 00000000 00000024 00000000 0000007f 00000000 000026b5 00000000
[ 28.597784] 3360 ffffffff 00000040 00000000 00000000 b19b33a0 ffffffc0 090d68f8 ffffff80
[ 28.606105]
X1: 0xffffffc0b1df89d0:
[ 28.611391] 89d0 00000000 00000000 00000024 00000000 00000000 00000000 0000001b 00000000
[ 28.619711] 89f0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 28.628031] 8a10 b1df8a10 ffffffc0 b1df8a10 ffffffc0 00000000 00000000 00000000 00000000
[ 28.636351] 8a30 b1df8a30 ffffffc0 b1df8a30 ffffffc0 00000000 00000000 00000000 00000000
[ 28.644671] 8a50 00088180 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 28.652991] 8a70 01fb3840 ffffff80 c5b0b800 ffffffc0 b1df8bb8 ffffffc0 b2092b40 ffffffc0
[ 28.661311] 8a90 00000100 00000000 00000001 00000000 00040000 00000000 00000000 00000000
[ 28.669631] 8ab0 00000000 00000000 00000000 00000000 00000000 00000000 5d9b762b 00000000
[ 28.677952]
X8: 0xffffffc0b1b5c3c0:
[ 28.683238] c3c0 b1b5cd40 ffffffc0 b1989080 ffffffc0 00000000 00000000 00000000 00000000
[ 28.691558] c3e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 28.699877] c400 00000000 00000000 00000080 00000041 00000400 00000000 ffffffff ffffffff
[ 28.708198] c420 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 28.716518] c440 b1b5cb00 ffffffc0 00000000 00000000 7500002a 0000e07d 00000028 00000000
[ 28.724838] c460 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 28.733158] c480 b1b5c4c0 ffffffc0 00000000 00000000 3c000028 0000c02c 00000008 00000000
[ 28.741477] c4a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 28.749801]
X28: 0xffffffc0b1df8b38:
[ 28.755171] 8b38 caf5d4e8 ffffffc0 b1df8b40 ffffffc0 b1df8b40 ffffffc0 b1df8b50 ffffffc0
[ 28.763491] 8b58 b1df8b50 ffffffc0 b1df8730 ffffffc0 c5b0be08 ffffffc0 b1df8b70 ffffffc0
[ 28.771811] 8b78 b1df8b70 ffffffc0 00000000 00000000 00000000 00000000 0000001f 00000000
[ 28.780131] 8b98 00000002 00000000 00000000 00000000 01fb3f58 ffffff80 00000000 00000000
[ 28.788451] 8bb8 b1df8a50 ffffffc0 02180020 00000000 00000000 00000000 00000000 00000000
[ 28.796771] 8bd8 00000000 00000000 00000000 00000000 b1df8be8 ffffffc0 b1df8be8 ffffffc0
[ 28.805091] 8bf8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 28.813411] 8c18 00000000 00000000 01fb3770 ffffff80 00000000 00000000 00000000 02420048
[ 28.821731]
X29: 0xffffffc0b19b3280:
[ 28.827104] 3280 00000000 00000000 0000003f 00000000 00000400 00000000 00000080 00000000
[ 28.835424] 32a0 00000000 00000000 00000041 00000000 b1df8bb8 ffffffc0 b19b3300 ffffffc0
[ 28.843744] 32c0 091cdcf8 ffffff80 b19b3300 ffffffc0 091cd994 ffffff80 20000145 00000000
[ 28.852064] 32e0 00000022 00000000 00000023 00000000 ffffffff 0000007f 01ef78fc ffffff80
[ 28.860384] 3300 b19b33d0 ffffffc0 091cdcf8 ffffff80 b1b5c400 ffffffc0 00000000 00000000
[ 28.868704] 3320 b1df8bb8 ffffffc0 00000000 00000000 0000003f 00000000 00000400 00000000
[ 28.877024] 3340 00000000 00000000 00000024 00000000 0000007f 00000000 000026b5 00000000
[ 28.885344] 3360 ffffffff 00000040 00000000 00000000 b19b33a0 ffffffc0 090d68f8 ffffff80
[ 28.895313] Process lxd (pid: 4416, stack limit = 0xffffffc0b19b0000)
[ 28.901899] Stack: (0xffffffc0b19b3300 to 0xffffffc0b19b4000)
[ 28.907794] 3300: ffffffc0b19b33d0 ffffff80091cdcf8 ffffffc0b1b5c400 0000000000000000
[ 28.915766] 3320: ffffffc0b1df8bb8 0000000000000000 000000000000003f 0000000000000400
[ 28.923739] 3340: 0000000000000000 0000000000000024 000000000000007f 00000000000026b5
[ 28.931712] 3360: 00000040ffffffff 0000000000000000 ffffffc0b19b33a0 ffffff80090d68f8
[ 28.939686] 3380: ffffff8009f293b8 0000000000000189 0000000000000000 ffffffc0b19b34ff
[ 28.947659] 33a0: ffffffc0b19b33d0 ffffff8009214f7c ffffffc0b19b33e0 ffffff80090d68f8
[ 28.955632] 33c0: ffffff8009f293b8 0000000000000189 ffffffc0b19b3430 ffffff80091ce0b8
[ 28.963605] 33e0: 0000000000000000 ffffffc0b1b5c400 ffffffc0b1df8bb8 0000000000000000
[ 28.971579] 3400: 000000000000003f 0000000001400000 ffffffc0c2901800 ffffff8001f6fccc
[ 28.979552] 3420: ffffffc0b19b34e8 0000000000000000 ffffffc0b19b3470 ffffff8001f6fcfc
[ 28.987526] 3440: ffffffc0b19b34e8 ffffffc0b1b5c400 ffffffc0b1df8a50 ffffff800a853da0
[ 28.995499] 3460: ffffffc0c5b09000 ffffffc0b1b5c400 ffffffc0b19b3560 ffffff8001f702a4
[ 29.003472] 3480: ffffffc0c4174400 0000000000000000 ffffffc0c4174440 ffffffc0b1a99150
[ 29.011446] 34a0: ffffffc0c1d20000 ffffffc0c2901800 0000000003f2c000 ffffffc0b1df8a50
[ 29.019419] 34c0: ffffffc0c1ff1590 0000000000000000 ffffffc0c4174440 0000000000000001
[ 29.027392] 34e0: ffffffc0b19b3500 ffffffc0b19b34e8 ffffffc0b19b34e8 f500000000000140
[ 29.035365] 3500: 00ffffffffffffff 0000000001400000 0000000000000000 0000000000000000
[ 29.043339] 3520: 0000000000000000 ffffffc0c5957600 ffffffc0c5b09000 ffffffc0b1df8a50
[ 29.051312] 3540: 0000000000000000 0000004000000000 0000000000000000 0000000000000001
[ 29.059285] 3560: ffffffc0b19b35b0 ffffff8001f00190 0000000000000000 ffffffc0c4174400
[ 29.067259] 3580: ffffffc0c4174440 ffffffc0c1d20b1c ffffffc0c1ff1540 ffffffc0c1d20000
[ 29.075232] 35a0: ffffffc0c1ff1578 ffffffc0c1ff1550 ffffffc0b19b3640 ffffff8001f0f8f8
[ 29.083205] 35c0: ffffffc0c4174400 ffffffc0c1d20b18 0000000000000004 ffffffc0c1d20b1c
[ 29.091179] 35e0: 0000000000000000 ffffffc0c4174e00 0000000000004000 ffffffc0c9c3e000
[ 29.099152] 3600: 0000000000000001 0000000000000000 ffffffc0b19b3640 0000000000000000
[ 29.107126] 3620: ffffffc0c9d1d400 ffffff80090fa6b8 ffffffc0b19b3630 ffffffc0b19b3630
[ 29.115099] 3640: ffffffc0b19b3720 ffffff8001f106a8 0000000000004000 ffffffc0b20ad000
[ 29.123072] 3660: 0000000000000000 0000000000000004 0000000000000000 0000000000000000
[ 29.131045] 3680: 0000000000004000 ffffffc0b19b382f 0000000000000001 0000000000004000
[ 29.139019] 36a0: 0000000000004000 ffffffc0c4174e00 0000000000000001 0000000000000001
[ 29.146992] 36c0: ffffffc0b20ad000 0000000000004000 ffffffc0c4174ed0 ffffffc0b19b382f
[ 29.154966] 36e0: 0000000400000004 ffffffc0c41744c4 0000000000000004 0000000100000000
[ 29.162939] 3700: 0000000000000000 0000000001400000 0000000000000000 0000000000200000
[ 29.170912] 3720: ffffffc0b19b37a0 ffffff8001f108d0 ffffffc0b20ad000 0000000000004000
[ 29.178885] 3740: 0000000000000000 ffffffc0b1d63000 0000000000000000 0000000000000000
[ 29.186859] 3760: 0000000000000000 0000000000000109 ffffffc0c1d20000 ffffffc0c1d20180
[ 29.194832] 3780: 0000000000000000 ffffffc0c1d20000 0000000000000000 0000000000000019
[ 29.202806] 37a0: ffffffc0b19b3840 ffffff8001ef5f1c ffffffc0b20ad000 ffffffc0b1b1a000
[ 29.210779] 37c0: ffffffc0b1d63000 0000000000000000 0000000000000000 0000000000000000
[ 29.218752] 37e0: ffffffc0b20ad200 ffffffc0b19b39d0 ffffffc0b19b38cf 0000000000000000
[ 29.226726] 3800: 0000000000000000 0000000200000000 ffffffc0b19b38cf 0000000000000161
[ 29.234699] 3820: ffffffc0b20ad000 00ffffc0b1b1a000 a800000000000000 0000000000000000
[ 29.242672] 3840: ffffffc0b19b38e0 ffffff8001ef6468 ffffffc0b1b1a000 ffffffc0b1d63000
[ 29.250646] 3860: ffffffc0b20ad000 ffffffc0b19b39d0 0000000000000000 0000000000000000
[ 29.258619] 3880: 0000000000000000 ffffffc0b1d63000 0000000000000000 ffffffc0b1a990e0
[ 29.266592] 38a0: ffffffc0b19b3910 0000000001ef55f0 ffffffc0b1b1a000 0000000000000000
[ 29.274566] 38c0: ffffffc0b19b38e0 00ffff8000000000 0100000000000001 0000000000000000
[ 29.282539] 38e0: ffffffc0b19b3930 ffffff8001ef9c58 0000000000000002 ffffffc0b20ad000
[ 29.290512] 3900: 00000040ffffffff ffffffc0b19b3a7f 00000000ffffffff 0000000000000019
[ 29.298485] 3920: 0000000000000003 ffffffc0b20ad000 ffffffc0b19b39f0 ffffff8001efbabc
[ 29.306459] 3940: 0000000000000000 ffffffc0b19b3a78 ffffffc0b1a990e0 ffffffc0b20ad000
[ 29.314432] 3960: ffffffc0b19b3a7f 0000000000000019 0000000000000001 ffffffc0b1d63000
[ 29.322405] 3980: 0000000000000000 0000000000000000 ffffff8009f293b8 0000000000000189
[ 29.330379] 39a0: 0000000000000000 0000000100000001 0000000000000001 0000000100000001
[ 29.338352] 39c0: 0000000002408040 0000000302408040 ffffffc0b1b1a000 ffffff8009214cc0
[ 29.346326] 39e0: ffffffc0b19b3a30 ffffff8001ef51dc ffffffc0b19b3a40 ffffff8001f61d3c
[ 29.354299] 3a00: ffffffc0b1a990e0 ffffffc0b1d63000 ffffffc0b20ad000 ffffffc0b1df8620
[ 29.362272] 3a20: 0000000000000001 0000000000000001 ffffffc0b1d63000 0000000000000c02
[ 29.370246] 3a40: ffffffc0b19b3a90 ffffff8001f29bc4 ffffffc0b20ad000 ffffffc0b1df8430
[ 29.378219] 3a60: ffffffc0b1df8550 ffffffc0b1df8620 ffffffc0b20ad3f8 fbffff8000000000
[ 29.386192] 3a80: 30ffffffffffffff 0000000000008d56 ffffffc0b19b3ae0 ffffff8001f2f6a8
[ 29.394166] 3aa0: ffffffc0b1df8620 0000000000000000 ffffffc0b19b3be0 ffffffc0b1df8430
[ 29.402139] 3ac0: ffffffc0b1d63000 0000000000000000 ffffffc0b20ad000 0000000000000000
[ 29.410112] 3ae0: ffffffc0b19b3b40 ffffff800924e61c 000000000000a068 ffffffc0b1df8620
[ 29.418086] 3b00: ffffffc0b19b3be0 0000000000000000 ffffffc0b1c00600 0000000000000000
[ 29.426059] 3b20: ffffffc0b2085de0 0000000000000000 0000000000000000 ffffffc0c1fb4200
[ 29.434032] 3b40: ffffffc0b19b3ba0 ffffff800922982c 0000000000000000 ffffffc0b1c00600
[ 29.442005] 3b60: 0000000000000000 ffffffc0c1fb4200 ffffffc0b2085de0 0000000000000200
[ 29.449979] 3b80: 0000000000000001 ffffffc0b19b3d48 0000000000000040 ffffff8009229338
[ 29.457952] 3ba0: ffffffc0b19b3c30 ffffff800923e41c ffffffc0b1df8620 ffffffc0c1fb4210
[ 29.465926] 3bc0: ffffffc0c1fb4200 ffffffc0b1d58900 0000000000000006 ffffffc0b1d58900
[ 29.473899] 3be0: 000000000000a068 0000000000000200 0000000000000000 000000005d9b7634
[ 29.481872] 3c00: 00000000063c8adc 000000005d9b7634 00000000063c8adc 000000005d9b7634
[ 29.489846] 3c20: 00000000063c8adc ffffffc0c1fb4200 ffffffc0b19b3d10 ffffff800923fca0
[ 29.497819] 3c40: 00000000ffffff9c ffffffc0b19b3d48 ffffffc0b19b3e7c 0000000000000001
[ 29.505792] 3c60: 0000000020000000 0000000000000015 0000000000000123 0000000000000038
[ 29.513766] 3c80: ffffff8009c02000 ffffffc0c9d1d400 ffffffc0b19b3d60 ffffffc0b1c00600
[ 29.521739] 3ca0: ffffffc0000081b6 ffffffc0b1dc8620 ffffffc000000000 ffffffff00020242
[ 29.529712] 3cc0: ffffffc0b19b3d00 0000000600000041 ffffffc0b19b3d00 0000000000000002
[ 29.537686] 3ce0: ffffffc0b1df8620 ffffffc0b2085de0 ffffffc0b1c00600 0000000000010001
[ 29.545659] 3d00: ffffffc0b19b3d00 ffffffc0b19b3d00 ffffffc0b19b3e20 ffffff800922adc4
[ 29.553632] 3d20: 000000000000001c 00000000ffffff9c ffffffc0c5b04000 00000000000a0242
[ 29.561606] 3d40: ffffffc0b19b3db0 ffffffc0b2085de0 ffffffc0b1c00600 0000000bedbf0d4a
[ 29.569579] 3d60: ffffffc0c5b0404a 0000000000000000 ffffffc0c611fe40 ffffffc0b1df8620
[ 29.577552] 3d80: 0000000000000301 00000000000029a6 0000000100000000 ffffffc0b19b3da0
[ 29.585526] 3da0: ffffffc0b0f0eaa0 ffffffc0b1cfb3c0 ffffff80092390f8 ffffffbf02c6eac0
[ 29.593499] 3dc0: ffffffc0c5b0404a 0000000000000002 ffffffc0c5b04000 00000000000a0242
[ 29.601472] 3de0: 0000000020000000 0000000000000015 0000000000000123 0000000000000038
[ 29.609445] 3e00: ffffffc0c5b04000 0000000000000000 ffffffc0b1d4aa78 ffffff9c00000002
[ 29.617419] 3e20: ffffffc0b19b3e90 ffffff800922af2c ffffffffffffff9c 0000004000657380
[ 29.625392] 3e40: 0000000000080242 00000000000001b6 ffffffc0b19b3e90 0000000000000108
[ 29.633366] 3e60: ffff41ed00000036 000f424000000001 00000000000f4240 0002024200000082
[ 29.641339] 3e80: 000000065d9b81b6 0000000100000300 0000000000000000 ffffff80090839c0
[ 29.649312] 3ea0: ffffffffffffff05 00000040c512f000 ffffffffffffffff 00000000004bb8d8
[ 29.657286] 3ec0: ffffffffffffff9c 0000004000657380 0000000000080242 00000000000001b6
[ 29.665259] 3ee0: 0000000000000000 0000000000000000 0000000000000001 0000000000000020
[ 29.673232] 3f00: 0000000000000038 0000004000657380 6e6961746e6f632f 616e732f7261762f
[ 29.681205] 3f20: 6f632f64786c2f70 0055555555555555 00000000000000f5 0000000000000000
[ 29.689179] 3f40: 0000000000000038 0000000000000008 0000000000000a03 0000000000000008
[ 29.697152] 3f60: 0000000000000004 0000000000000001 0000000000000061 0000000000000201
[ 29.705126] 3f80: 0000000000000190 0000000000000000 00000000011bac58 0000000001c934b8
[ 29.713099] 3fa0: 0000004000000180 00000040004b8578 00000000004bb8b8 00000040004b8580
[ 29.721072] 3fc0: 00000000004bb8d8 0000000020000000 ffffffffffffff9c 0000000000000038
[ 29.729046] 3fe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 29.737018] Call trace:
[ 29.739619] Exception stack(0xffffffc0b19b3130 to 0xffffffc0b19b3260)
[ 29.746205] 3120: 0000000000000000 0000007fffffffff
[ 29.754179] 3140: ffffffc0b19b3300 ffffff80091cd994 ffffffc0c9480240 0000000000000007
[ 29.762152] 3160: 0000000000000005 0000000000000005 ffffffc0b1b5c9c0 00000000000001c0
[ 29.770126] 3180: ffffffc0b19b3190 ffffff800943b460 ffffffc0b19b31c0 ffffff80090edeb0
[ 29.778099] 31a0: ffffffc0b19b31c0 ffffff80090edb74 0000000000000000 ffffff80090ee8f4
[ 29.786072] 31c0: ffffffc0b19b3330 ffffff80090ef5c0 0000000002420048 ffffffc0b1df8a50
[ 29.794045] 31e0: 0000000000000000 0000000000001300 0000000000000041 000000000000003f
[ 29.802019] 3200: 000000000000003f 0000000000000000 ffffffc0b1b5c440 0000000000000000
[ 29.809992] 3220: 0000000000000010 0000000000000400 0000000000000800 0000000000000c00
[ 29.817965] 3240: 0000000000001000 0000000000001c00 ffffff8009f41d6a 0000000000001400
[ 29.825945] [] __do_page_cache_readahead+0x4c/0x298
[ 29.832527] [] ondemand_readahead+0x118/0x278
[ 29.838594] [] page_cache_sync_readahead+0x60/0xa0
[ 29.845188] [] __load_free_space_cache+0x214/0x680 [btrfs]
[ 29.852373] [] load_free_space_cache+0x13c/0x1f0 [btrfs]
[ 29.859389] [] cache_block_group+0x178/0x3d8 [btrfs]
[ 29.866063] [] find_free_extent+0x2c0/0xfc8 [btrfs]
[ 29.872649] [] btrfs_reserve_extent+0xa8/0x1a0 [btrfs]
[ 29.879496] [] btrfs_alloc_tree_block+0x130/0x3f0 [btrfs]
[ 29.886601] [] __btrfs_cow_block+0x114/0x4f8 [btrfs]
[ 29.893275] [] btrfs_cow_block+0xd0/0x250 [btrfs]
[ 29.899688] [] btrfs_search_slot+0x1c8/0x960 [btrfs]
[ 29.906362] [] btrfs_insert_empty_items+0x8c/0xf0 [btrfs]
[ 29.913472] [] btrfs_insert_orphan_item+0x64/0x90 [btrfs]
[ 29.920578] [] btrfs_orphan_add+0xd4/0x268 [btrfs]
[ 29.927078] [] btrfs_setattr+0x118/0x3a0 [btrfs]
[ 29.933322] [] notify_change2+0x3ec/0x418
[ 29.939040] [] do_truncate2+0x8c/0xd0
[ 29.944414] [] path_openat+0xe0c/0x13e0
[ 29.949959] [] do_filp_open+0x70/0xe8
[ 29.955333] [] do_sys_open+0x174/0x258
[ 29.960792] [] SyS_openat+0x3c/0x50
[ 29.965994] [] el0_svc_naked+0x34/0x38
[ 29.971454] Code: f9400381 52826003 b9407f80 52826015 (b9404662)
[ 29.977694] —[ end trace 458ecbe767d7df94 ]—
[ 64.523923] fb: mem_free_work, free memory: addr:800000
[ 611.319544] fb: osd[0] enable: 0 (kworker/0:1)
