Hello, i am using LXC 3.0.0 and LXCFS 3.0.0 compiled from sources on an Ubuntu 16 server
Distributor ID:
Description:
Ubuntu 16.04.3 LTS
Release:
16.04
Codename:
xenial
lxc-ls --version output is 3.0.0
i have 4 containers working perfectly, the problem is that when i execute lxc-ls , lxc-top from my LXC server
sometimes these 2 commands stop responding and produce no output.
i still can access my containers with ssh from another computer.
Anybody has the same problem? is there any solution?
Hi
I cannot reproduce the error situation that leads the commands lxc-fs and/or lxc-top to stop responding
but of course i could send you the output of dmesg.
Looks good. lxc.prlimit.[limit name] is another set of resource restrictions you can apply, yes. You should check whether it makes sense for your use-case and what you’d like to limit though.
