ran lxd init, called the zfs cluster one time, and ran init second time and called the zfs cluster another name, i thought i had used the correct lxd stoarage delete commands but it seems like it was still looking for the previously named and deleted zfs cluster, so the end result lxd wont start.
Is there a way to update the config for lxd to not even have that the previous deleted zfs-pool-name in config or is there a some other fix for this issue?
also related when use some commands like ‘lxc list’ it just hangs, like no timeout or anything over hours.
