Hi all,
When i move a container to a new data store (zfs) at the verry end it fails with this error
Failed to deactivate zvol after 5m0s
What can I do about this? Tried 2 times now.
Hi all,
Hi @ckruijntjens,
Can you post the lxd storage ls and lxd move command syntax you are trying to use?
Regards.
HI,
I allredeay did it with lxc export and lxc import.
thanks for your help.
What does “zfs list” show and what version of lxd? Finally is the instance running?
I suspect you have the volume mounted elsewhere that lxd doesn’t know about that is preventing deactivation. Try rebooting to clear mounts.
Hi Thomas,
I alredeay moved everything. Now I have zfs pool for my lxd containers.
However now I am experiencing an even more slowdown with for example a apt-upgrade.
The zfs pool shows that all is healthy.
Any ideas?
Please show lxc storage show <pool> and sudo zfs list?
