Available Commands:
acl Manage network ACLs
attach Attach network interfaces to instances
attach-profile Attach network interfaces to profiles
create Create new networks
delete Delete networks
detach Detach network interfaces from instances
detach-profile Detach network interfaces from profiles
edit Edit network configurations as YAML
forward Manage network forwards
get Get values for network configuration keys
info Get runtime information on networks
list List available networks
list-leases List DHCP leases
load-balancer Manage network load balancers
peer Manage network peerings
rename Rename networks
set Set network configuration keys
show Show network configurations
unset Unset network configuration keys
zone Manage network zones
Global Flags:
–debug Show all debug messages
–force-local Force using the local unix socket
-h, --help Print help
–project Override the source project
-q, --quiet Don’t show progress information
–sub-commands Use with help or --help to view sub-commands
-v, --verbose Show all information messages
–version Print version number
Use “lxc network [command] --help” for more information about a command.
