Hello Friends:
Now that I recovered my Fedora-30 environment (… recalling that I had upgraded to Fedora-32 which broke LXC; so I reverted to Fedora-30), everything seems to be working, but for this: I can’t ping the default router from within the LXC container (whereas I could before). Actually, from the LXC container, I can’t ping any device on the bridge-to local network other than it’s HOST.
So I must have missed something in my reverting back to Fedora-30. I provide information below. Can anyone identify what I might be missing? Note that the included LXC container config file is the same as before (unchanged).
Any ideas? Please see below, and thank you!
What’s running on the HOST:
user@HOST$ sudo lxc-ls --fancy --running
NAME STATE AUTOSTART GROUPS IPV4 IPV6 UNPRIVILEGED
vps12 RUNNING 0 - 172.17.0.1, 192.168.0.192 - false
The bridge on the HOST:
user@HOST$ sudo brctl show
bridge name bridge id STP enabled interfaces
br0 8000.ac220b51b11d no eth0
veth2ECD1V
docker 8000.0242de098eba no
Configured interfaces on the HOST:
user@HOST$ sudo ifconfig -a
br0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.16 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::ae22:bff:fe51:b11d prefixlen 64 scopeid 0x20<link>
ether ac:22:0b:51:b1:1d txqueuelen 1000 (Ethernet)
RX packets 2048 bytes 224239 (218.9 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 1420 bytes 166366 (162.4 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:de:09:8e:ba txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
RX packets 2100 bytes 296608 (289.6 KiB)
RX errors 0 dropped 56 overruns 0 frame 0
TX packets 898 bytes 114072 (111.3 KiB)
device interrupt 18 memory 0xfb100000-fb120000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 2 bytes 190 (190.0 B)
TX packets 2 bytes 190 (190.0 B)
veth2ECD1V: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::fcfc:2eff:feb4:436b prefixlen 64 scopeid 0x20<link>
ether fe:fc:2e:b4:43:6b txqueuelen 1000 (Ethernet)
RX packets 476 bytes 72861 (71.1 KiB)
TX packets 619 bytes 64519 (63.0 KiB)
Network commands while SSH’ed into GUEST (vps12):
user@vps12$ ifconfig -a
ether 02:42:a1:25:79:10 txqueuelen 0 (Ethernet)
inet 192.168.0.192 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::2022:22ff:fe22:2212 prefixlen 64 scopeid 0x20<link>
ether 22:22:22:22:22:12 txqueuelen 1000 (Ethernet)
RX packets 680 bytes 72490 (70.7 KiB)
TX packets 518 bytes 80274 (78.3 KiB)
RX packets 18 bytes 1821 (1.7 KiB)
TX packets 18 bytes 1821 (1.7 KiB)
user@vps12$ netstat -rn
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
0.0.0.0 192.168.0.1 0.0.0.0 UG 0 0 0 eth0
172.17.0.0 0.0.0.0 255.255.0.0 U 0 0 0 docker0
192.168.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
Config file for vps12 LXC container:
lxc.uts.name = vps12
lxc.rootfs.path = dir:/var/lib/lxc/vps12/rootfs
lxc.mount.fstab = /var/lib/lxc/vps12/fstab
lxc.arch = x86_64
lxc.net.0.type = veth
lxc.net.0.link = br0
lxc.net.0.name = eth0
lxc.net.0.flags = up
lxc.net.0.ipv4.gateway = 192.168.0.1
lxc.net.0.ipv4.address = 192.168.0.192/24
lxc.net.0.hwaddr = 22:22:22:22:22:12
lxc.include = /usr/share/lxc/config/nesting.conf
# Set for dstorm CPU cores. If this LXC is copied elsewhere, modify for that CPU.
lxc.cgroup.cpuset.cpus = 0,1,2,3,4,5,6,7,8,9,10,11
lxc.cgroup.cpu.shares = 100
# Miscellaneous settings ...
lxc.tty.max = 4
lxc.pty.max = 1024
lxc.cap.drop = sys_module mac_admin mac_override sys_time
# cgroups ...
lxc.cgroup.devices.deny = a
# /dev/null and zero
lxc.cgroup.devices.allow = c 1:3 rwm
lxc.cgroup.devices.allow = c 1:5 rwm
# consoles ...
lxc.cgroup.devices.allow = c 5:1 rwm
lxc.cgroup.devices.allow = c 5:0 rwm
lxc.cgroup.devices.allow = c 4:0 rwm
lxc.cgroup.devices.allow = c 4:1 rwm
# /dev/{,u}random ...
lxc.cgroup.devices.allow = c 1:9 rwm
lxc.cgroup.devices.allow = c 1:8 rwm
lxc.cgroup.devices.allow = c 136:* rwm
lxc.cgroup.devices.allow = c 5:2 rwm
# rtc
lxc.cgroup.devices.allow = c 254:0 rm
linux.kernel_modules = ip_tables,ip6_tables,netlink_diag,nf_nat,overlay
raw.lxc = lxc.mount.auto=proc:rw sys:rw
lxc.mount.entry = /dev/kmsg dev/kmsg none defaults,bind,create=file
security.nesting = true
security.privileged = true
lxc.apparmor.profile = unconfined
lxc.cgroup.devices.allow = a
lxc.cap.drop =
