The template below is mostly useful for bug reports and support questions.
Feel… free to remove anything which doesn't apply to you and add more information where it makes sense.
# Required information
Linux OpenSuse 15
lxc-start --version
2.0.9
lxc-checkconfig
--- Namespaces ---
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled
--- Control groups ---
Cgroups: enabled
Cgroup v1 mount points:
/sys/fs/cgroup/systemd
/sys/fs/cgroup/cpu,cpuacct
/sys/fs/cgroup/perf_event
/sys/fs/cgroup/devices
/sys/fs/cgroup/cpuset
/sys/fs/cgroup/net_cls,net_prio
/sys/fs/cgroup/blkio
/sys/fs/cgroup/freezer
/sys/fs/cgroup/rdma
/sys/fs/cgroup/hugetlb
/sys/fs/cgroup/pids
/sys/fs/cgroup/memory
Cgroup v2 mount points:
/sys/fs/cgroup/unified
Cgroup v1 clone_children flag: enabled
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup cpuset: enabled
--- Misc ---
Veth pair device: enabled, not loaded
Macvlan: enabled, loaded
Vlan: enabled, not loaded
Bridges: enabled, loaded
Advanced netfilter: enabled, not loaded
CONFIG_NF_NAT_IPV4: enabled, loaded
CONFIG_NF_NAT_IPV6: enabled, loaded
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled, not loadedCONFIG_NETFILTER_XT_MATCH_COMMENT: enabled, not loaded
FUSE (for use with lxcfs): enabled, loaded
--- Checkpoint/Restore ---
checkpoint restore: enabled
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: enabled
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: enabled
CONFIG_NETLINK_DIAG: enabled
File capabilities: enabled
uname -a
Linux static 4.12.14-lp150.12.48-default
cat /proc/self/cgroup
12:memory:/user/lxc/0
11:pids:/user.slice/user-1000.slice/session-2.scope
10:hugetlb:/
9:rdma:/
8:freezer:/user/lxc/0
7:blkio:/user.slice
6:net_cls,net_prio:/
5:cpuset:/
4:devices:/user.slice
3:perf_event:/
2:cpu,cpuacct:/user.slice
1:name=systemd:/user/lxc/0
0::/user.slice/user-1000.slice/session-2.scope
cat /proc/1/mounts
sysfs /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0
proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0
devtmpfs /dev devtmpfs rw,nosuid,size=32858256k,nr_inodes=8214564,mode=755 0 0
securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0
tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
tmpfs /run tmpfs rw,nosuid,nodev,mode=755 0 0
tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/unified cgroup2 rw,nosuid,nodev,noexec,relatime 0 0
cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd 0 0
pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0
cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0
cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0
cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset,clone_children 0 0
cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0
cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0
cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0
cgroup /sys/fs/cgroup/rdma cgroup rw,nosuid,nodev,noexec,relatime,rdma 0 0
cgroup /sys/fs/cgroup/hugetlb cgroup rw,nosuid,nodev,noexec,relatime,hugetlb 0 0
cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0
cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
/dev/nvme0n1p3 / ext4 rw,relatime,data=ordered 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=666 0 0
debugfs /sys/kernel/debug debugfs rw,relatime 0 0
mqueue /dev/mqueue mqueue rw,relatime 0 0
hugetlbfs /dev/hugepages hugetlbfs rw,relatime 0 0
/dev/nvme1n1p1 /home ext4 rw,relatime,data=ordered 0 0
fusectl /sys/fs/fuse/connections fusectl rw,relatime 0 0
tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=6573276k,mode=700,uid=1000,gid=100 0 0
lxcfs /var/lib/lxcfs fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other 0 0
# Issue description
Am trying to limit cpu usage to 1 cpu, i think its called cpu mapping unlike what i was looking for which use `just use 1 cpu without specifying exactly which 1 to use` so in the container config file i added the following ;
`lxc.cgroup.cpuset.cpus = 0`
when starting the container i get the flowing error.
lxc-start -n my-cont -d -F
lxc-start: cgroups/cgfsng.c: lxc_cgroup_set_data: 1931 Failed to setup limits for the "cpuset" controller. The controller seems to be unused by "cgfsng" cgroup driver or not enabled on the cgroup hierarchy
lxc-start: cgroups/cgfsng.c: cgfsng_setup_limits: 1968 No such file or directory - Error setting cpuset.cpus to 0 for my-cont
lxc-start: start.c: lxc_spawn: 1356 Failed to setup cgroup limits for container "my-cont".
lxc-start: start.c: __lxc_start: 1530 Failed to spawn container "my-cont".
lxc-start: tools/lxc_start.c: main: 368 The container failed to start.
lxc-start: tools/lxc_start.c: main: 372 Additional information can be obtained by setting the --logfile and --logpriority options.
How do i resolve this please?
second question where do i find all possible configs of limiting resources? are they listed somewhere?
# Information to attach
findmnt | grep cgroup
│ ├─/sys/fs/cgroup tmpfs tmpfs ro,nosuid,nodev,noexec,mode=755
│ │ ├─/sys/fs/cgroup/unified cgroup cgroup2 rw,nosuid,nodev,noexec,relatime
│ │ ├─/sys/fs/cgroup/systemd cgroup cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
│ │ ├─/sys/fs/cgroup/cpu,cpuacct cgroup cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
│ │ ├─/sys/fs/cgroup/perf_event cgroup cgroup rw,nosuid,nodev,noexec,relatime,perf_event
│ │ ├─/sys/fs/cgroup/devices cgroup cgroup rw,nosuid,nodev,noexec,relatime,devices
│ │ ├─/sys/fs/cgroup/cpuset cgroup cgroup rw,nosuid,nodev,noexec,relatime,cpuset,clone_children
│ │ ├─/sys/fs/cgroup/net_cls,net_prio cgroup cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
│ │ ├─/sys/fs/cgroup/blkio cgroup cgroup rw,nosuid,nodev,noexec,relatime,blkio
│ │ ├─/sys/fs/cgroup/freezer cgroup cgroup rw,nosuid,nodev,noexec,relatime,freezer
│ │ ├─/sys/fs/cgroup/rdma cgroup cgroup rw,nosuid,nodev,noexec,relatime,rdma
│ │ ├─/sys/fs/cgroup/hugetlb cgroup cgroup rw,nosuid,nodev,noexec,relatime,hugetlb
│ │ ├─/sys/fs/cgroup/pids cgroup cgroup rw,nosuid,nodev,noexec,relatime,pids
│ │ └─/sys/fs/cgroup/memory cgroup cgroup rw,nosuid,nodev,noexec,relatime,memory
