sudo lxc profile show "raw.lxc-lxc.apparmor.profile%20=%20unconfined%0Alxc.cgroup.devices.allow%20=%20a%0Alxc.mount.auto%20=%20proc:rw%20sys:ro%0Alxc.cap.drop%20="
Error: The remote "raw.lxc-lxc.apparmor.profile%20=%20unconfined%0Alxc.cgroup.devices.allow%20=%20a%0Alxc.mount.auto%20=%20proc" doesn't exist
Is there any way to run lxc profile show on multi-line profiles?
What you get there from accessing the Unix socket, is messed up profile names. There shouldn’t be any reference to raw.lxc-lxc.apparmor.profile... or ?project=default.
Now that’s one awful profile name and it looks like someone just put what was meant to go as profile config into the profile name, but the API and CLI seems to show it correctly
I expect you don’t use HTML escaping when using the CLI, try replacing %20 with space and %0A with newline.
It’s going to be horrendous to get right though. Also, the error saying “The remote … doesn’t exist” suggests that the colon within the name is being interpreted as a separator between remote and name, so you might need to prefix it all with local:. Maybe like this:
sudo lxc profile show "local:raw.lxc-lxc.apparmor.profile = unconfined
lxc.cgroup.devices.allow = a
lxc.mount.auto = proc:rw sys:ro
lxc.cap.drop ="
lxd/incus profile list --format=json may make it clearer exactly what you need to give.
I suspect, though, that profiles could do with better validation in their names! (Especially given that a container name can’t even contain a dot)
For containers it’s because we’re respecting some of the RFCs around hostnames, for everything else the main criteria is that we don’t allow slashes as that interferes with URLs, anything else is usually fine on our end (though clearly can lead to some confusion as shown here :)).
Using an FQDN in /etc/hostname works fine though. Having to give a container a fake name like foo-example-com and then patch up /etc/hostname and /etc/hosts afterwards, and/or set a custom property like user.fqdn with the real, globally-unique name, is tedious. However, I’m not going to argue that point here: it was argued a long time ago, and lost.
I can accept that it’s better to be overly-restrictive than overly-permissive with hostnames, and by the same logic I think it would be reasonable to restrict profile names, network names, image names etc. Maybe not quite as restrictive as hostnames, but in particular there are issues if you allow a colon. Leading/trailing spaces and embedded newlines clearly cause confusion too.
