Lxc remote -> connection refused
I am trying to connect to a LXD remote from another machine. ufw is disabled. When I do: lxc remote add babylon 192.168.1.10:8443
I get this error:
Error: Get "https://192.168.1.10:8443": Unable to connect to: 192.168.1.10:8443 ([dial tcp 192.168.1.10:8443: connect: connection refused])
I run this on the server: lxc monitor --type=logging --pretty. Which gives me this output:
DEBUG  [2022-08-17T12:04:41Z] Heartbeat updating local raft members         members="[{{1 192.168.1.10:8443 voter} babylon}]"
DEBUG  [2022-08-17T12:04:41Z] Starting heartbeat round                      local="192.168.1.10:8443" mode=normal
DEBUG  [2022-08-17T12:04:41Z] Completed heartbeat round                     duration=4.091455ms local="192.168.1.10:8443"
sudo netstat -ltpn | grep lxd gives me this:
tcp        0      0 192.168.1.10:8443       0.0.0.0:*               LISTEN      3436/lxd
and curl 192.168.1.10:8443 gives me this:
curl: (7) Failed to connect to 192.168.1.10 port 8443 after 12 ms: Connection refused
lxc config show:
  cluster.https_address: 192.168.1.10:8443
  core.https_address: 192.168.1.10:8443
I have no added IPTABLES rules.
But why I cannot get to add this remote?
Where are you trying to connect from?
I am connecting in the same network from a macos m1 machine.
Does curl 192.168.1.10:8443 connect when run from the LXD host itself?
You’ve most likely got a firewall setup without knowing it.
What does sudo nft list ruleset and sudo iptables-save show?
As always, you are right. firewalld had a couple of rules added, and I was not aware. iptable chains are a mystery to me.
