johnmaher
(John Maher)
January 13, 2023, 2:45pm
1
I am experiencing something similar to this:
Most of the containers are fine, but I seem to have some phantom snapshots. Example case:
lxc snapshot collabora
Gives me error:
Error: Create instance snapshot: Error inserting volume "collabora/snap3" for project "default" in pool "default" of type "containers" into database "Insert volume snapshot: UNIQUE constraint failed: storage_volumes_snapshots.storage_volume_id, storage_volumes_snapshots.name"
If I do
lxc info collabora
I get this, no snap3 listed
But I don’t understand enough to fix the problem, so any help would be appreciated.
I just migrated from apt lxd 3.0.3 to snap lxd 5.0.1 using the following:
sudo snap install lxd --channel=4.0
sudo lxd.migrate
sudo snap refresh lxd --channel=5.0
Everything seemed to work fine. But I now get this when I try to delete a snapshot:
$ lxc delete pitemp/now
Error: Instance snapshot record count doesn't match instance snapshot volume record count
According to lxc info pitemp, the snapshot appears to have been deleted.
Now when I try to create a snapshot using the same name I get this:
$ lxc snapshot pitemp now
Error: Create instance snapshot: Error inserting volume "pitemp/now" for project "default" in pool "default" of type "containers" into database "Insert volume snapshot: UNIQUE constraint failed: storage_volumes_snapshots.storage_volume_id, storage_volumes_snapshots.name"
And it does not create the snapshop.
If I try to create a new snapshop with a different name I get this:
lxc snapshot pitemp now2
I’m kinda dead in the water for snapshots. I welcome any guidance. Thanks.
johnmaher
(John Maher)
January 13, 2023, 3:10pm
2
I should also provide this info, which is mentioned in the link I provided, but I don’t know how to understand it:
$ lxc info pitemp
Snapshots:
| NAME | TAKEN AT | EXPIRES AT | STATEFUL |
| current | 2023/01/09 01:09 EST | | NO |
| pre-trim-database | 2021/11/29 14:37 EST | | NO |
And this:
$ lxc storage show default | grep pitemp
- /1.0/instances/pitemp
- /1.0/instances/pitemp/snapshots/current
- /1.0/instances/pitemp/snapshots/now
- /1.0/instances/pitemp/snapshots/pre-trim-database
tomp
(Thomas Parrott)
January 13, 2023, 3:28pm
3
Please can you also show lxc storage volume list default. Thanks
johnmaher
(John Maher)
January 13, 2023, 3:50pm
4
Hi Thomas.
| TYPE | NAME | DESCRIPTION | CONTENT-TYPE | USED BY |
| container | pitemp | | filesystem | 1 |
| container (snapshot) | pitemp/current | | filesystem | 1 |
| container (snapshot) | pitemp/current | Auto repaired | filesystem | 1 |
| container (snapshot) | pitemp/now | Auto repaired | filesystem | 1 |
| container (snapshot) | pitemp/now | | filesystem | 1 |
| container (snapshot) | pitemp/pre-trim-database | | filesystem | 1 |
| container (snapshot) | pitemp/pre-trim-database | Auto repaired | filesystem | 1 |
johnmaher
(John Maher)
January 13, 2023, 5:23pm
5
Here’s a summary of what I’m seeing:
Snapshots:
$ lxc info pitemp | grep '^|'
$ lxc storage show default | grep "pitemp/snapshots"
$ lxc storage volume list default | grep "TYPE\|pitemp"
$ lxd sql global 'select storage_volumes.name, storage_volumes_snapshots.* from storage_volumes_snapshots join storage_volumes on storage_volumes_snapshots.storage_volume_id = storage_volumes.id' | grep "pitemp"
| pitemp | 43705 | 21134 | pre-trim-database | Auto repaired | 0001-01-01T00:00:00Z |
| pitemp | 43706 | 21134 | now | Auto repaired | 0001-01-01T00:00:00Z |
| pitemp | 43707 | 21134 | current | Auto repaired | 0001-01-01T00:00:00Z |
I’m fine with removing all of the snapshots just to get the system working again, but I’ve only ever done that with the command lxc delete [container]/[snapshot]. Running that command seems to leave plenty of other records and files still in place. I don’t know how to proceed.
johnmaher
(John Maher)
January 13, 2023, 8:13pm
6
So, on a development server I did a similar migrate (lxd.migrate) after installing the snap version of LXD and it too had the snapshot problem. I did the following and it seems to have fixed the issue (for that container), however there seems to be cruft left on the server.
First, I deleted every snapshot of the container using:
lxc delete pitemp/[snapshot]
Then, using the IDs in this command . . .
. . . I ran the following for every snapshot of the container:
lxd sql global 'delete from storage_volumes_snapshots where id = [id_number]'
After doing this, snapshots and general behavior of the containers were restored.
However, I still see evidence of the snapshots using these commands, and, unfortuantely, I don’t understand the significance of these or if there is a problem that these show up. Of course, I would rather the snapshots completely went away.
- /1.0/instances/pitemp/snapshots/backup20221114
- /1.0/instances/pitemp/snapshots/backup20221115
| container (snapshot) | pitemp/backup20221114 | | filesystem | 1 |
| container (snapshot) | pitemp/backup20221115 | | filesystem | 1 |
I welcome any help. Thanks.
tomp
(Thomas Parrott)
January 16, 2023, 8:31am
7
So I can see duplicate volume records for each snapshot, so that is the problem.
Please show lxd sql global 'select * from storage_volumes' and we can craft a SQL statement to just delete the duplicate records.
tomp
(Thomas Parrott)
January 16, 2023, 8:33am
8
Really you should have just removed the duplicate records from storage_volumes and then done lxc delete pitemp/[snapshot] as that would have then removed the instance snapshot record, remaining storage volume record, and the actual snapshot on disk.
johnmaher
(John Maher)
January 17, 2023, 1:11pm
9
Thomas, here is the output you requested. Thank you for the help.
$ lxd sql global 'select * from storage_volumes'
| id | name | storage_pool_id | node_id | type | description | project_id | content_type |
| 1 | haproxy | 1 | 1 | 0 | | 1 | 0 |
| 2 | web-chem | 1 | 1 | 0 | | 1 | 0 |
| 4 | web-biochem | 1 | 1 | 0 | | 1 | 0 |
| 5 | web-chem/20190614_1449_pre_timezone_change | 1 | 1 | 0 | | 1 | 0 |
| 6 | template | 1 | 1 | 0 | | 1 | 0 |
| 8 | template/current | 1 | 1 | 0 | | 1 | 0 |
| 9 | lecturedemos | 1 | 1 | 0 | | 1 | 0 |
| 10 | samson | 1 | 1 | 0 | | 1 | 0 |
| 11 | xtal | 1 | 1 | 0 | | 1 | 0 |
| 12 | rt4-3-3 | 1 | 1 | 0 | | 1 | 0 |
| 20 | barnes | 1 | 1 | 0 | | 1 | 0 |
| 21 | bmbbooking | 1 | 1 | 0 | | 1 | 0 |
| 22 | btp | 1 | 1 | 0 | | 1 | 0 |
| 23 | cbi | 1 | 1 | 0 | | 1 | 0 |
| 24 | chembooking | 1 | 1 | 0 | | 1 | 0 |
| 25 | cyclone | 1 | 1 | 0 | | 1 | 0 |
| 26 | dokuwiki | 1 | 1 | 0 | | 1 | 0 |
| 27 | eexambooking | 1 | 1 | 0 | | 1 | 0 |
| 43 | elements | 1 | 1 | 0 | | 1 | 0 |
| 44 | franklin | 1 | 1 | 0 | | 1 | 0 |
| 45 | gca | 1 | 1 | 0 | | 1 | 0 |
| 46 | genchem | 1 | 1 | 0 | | 1 | 0 |
| 47 | growthchambers | 1 | 1 | 0 | | 1 | 0 |
| 48 | hardylab | 1 | 1 | 0 | | 1 | 0 |
| 49 | high-pressure | 1 | 1 | 0 | | 1 | 0 |
| 50 | isbbooking | 1 | 1 | 0 | | 1 | 0 |
| 51 | isbinstruments | 1 | 1 | 0 | | 1 | 0 |
| 52 | it | 1 | 1 | 0 | | 1 | 0 |
| 53 | itwiki | 1 | 1 | 0 | | 1 | 0 |
| 54 | martinlab | 1 | 1 | 0 | | 1 | 0 |
| 55 | people | 1 | 1 | 0 | | 1 | 0 |
| 56 | redirected-sites | 1 | 1 | 0 | | 1 | 0 |
| 57 | sites | 1 | 1 | 0 | | 1 | 0 |
| 58 | skouta | 1 | 1 | 0 | | 1 | 0 |
| 59 | welab | 1 | 1 | 0 | | 1 | 0 |
| 60 | wptest | 1 | 1 | 0 | | 1 | 0 |
| 61 | athena | 1 | 1 | 0 | | 1 | 0 |
| 157 | haproxy-norton | 1 | 1 | 0 | | 1 | 0 |
| 2286 | bmbdept | 1 | 1 | 0 | | 1 | 0 |
| 2287 | a6d9a1f348a923af25f79586bdfba6f3020f16707b7807979a10c955695eb73a | 1 | 1 | 1 | | 1 | 0 |
| 2454 | franklin/pre_group_import | 1 | 1 | 0 | | 1 | 0 |
| 2548 | rt4-3-3/20191022_1342_pre-rt4-fetchmail-mod | 1 | 1 | 0 | | 1 | 0 |
| 2657 | rt4-3-3/20191028_1559_pre-install-getmail | 1 | 1 | 0 | | 1 | 0 |
| 2659 | rt4-3-3/20191028_1628_post-install-and-config-getmail | 1 | 1 | 0 | | 1 | 0 |
| 2787 | blahblah | 1 | 1 | 0 | | 1 | 0 |
| 2789 | blahblah/backup20191103 | 1 | 1 | 0 | | 1 | 0 |
| 2790 | blahblah/backup20191102 | 1 | 1 | 0 | | 1 | 0 |
| 2791 | blahblah/backup20191101 | 1 | 1 | 0 | | 1 | 0 |
| 2792 | blahblah/backup20191031 | 1 | 1 | 0 | | 1 | 0 |
| 2793 | blahblah/backup20191030 | 1 | 1 | 0 | | 1 | 0 |
| 2794 | blahblah/backup20191029 | 1 | 1 | 0 | | 1 | 0 |
| 2795 | blahblah/backup20191028 | 1 | 1 | 0 | | 1 | 0 |
| 2800 | blahblah/backup20191104 | 1 | 1 | 0 | | 1 | 0 |
| 5100 | bmbbooking/pre_mic_cal | 1 | 1 | 0 | | 1 | 0 |
| 6187 | elements-dev | 1 | 1 | 0 | | 1 | 0 |
| 6772 | c20-04 | 1 | 1 | 0 | | 1 | 0 |
| 7674 | athena-backup | 1 | 1 | 0 | | 1 | 0 |
| 7675 | athena-backup/pre_LAM_upgrade | 1 | 1 | 0 | | 1 | 0 |
| 7676 | athena-backup/current | 1 | 1 | 0 | | 1 | 0 |
| 8826 | apps-chem | 1 | 1 | 0 | | 1 | 0 |
| 9617 | c20-04/current | 1 | 1 | 0 | | 1 | 0 |
| 9631 | template-c20-04 | 1 | 1 | 0 | | 1 | 0 |
| 9634 | hammer | 1 | 1 | 0 | | 1 | 0 |
| 10399 | hammer/pre_labs_domain | 1 | 1 | 0 | | 1 | 0 |
| 10479 | chat | 1 | 1 | 0 | | 1 | 0 |
| 10480 | chat/orig_and_patched | 1 | 1 | 0 | | 1 | 0 |
| 10481 | chat/post_RocketChat_install | 1 | 1 | 0 | | 1 | 0 |
| 10521 | chat/pre_caddy_config | 1 | 1 | 0 | | 1 | 0 |
| 10523 | chat/pre_rocket_chat_config | 1 | 1 | 0 | | 1 | 0 |
| 10913 | xtal/current | 1 | 1 | 0 | | 1 | 0 |
| 11220 | apps-chem/link_error | 1 | 1 | 0 | | 1 | 0 |
| 12308 | apps-chem/500_error | 1 | 1 | 0 | | 1 | 0 |
| 12388 | bmbdept/pre_data_ingestion | 1 | 1 | 0 | | 1 | 0 |
| 12807 | cbi/pre_upload_limit_change | 1 | 1 | 0 | | 1 | 0 |
| 13151 | cbi/pre_updates | 1 | 1 | 0 | | 1 | 0 |
| 13152 | elements/pre_updates | 1 | 1 | 0 | | 1 | 0 |
| 13458 | web-biochem/current | 1 | 1 | 0 | | 1 | 0 |
| 13459 | web-chem/current | 1 | 1 | 0 | | 1 | 0 |
| 13460 | haproxy/pre_rt_cert_update | 1 | 1 | 0 | | 1 | 0 |
| 14361 | template-c20-04/current | 1 | 1 | 0 | | 1 | 0 |
| 14362 | apps-biochem | 1 | 1 | 0 | | 1 | 0 |
| 14363 | 50aaf0ac9542a398fcceab0e55c4dc64857844b634b180d73e5912c1342228f7 | 1 | 1 | 1 | | 1 | 0 |
| 14810 | gca/backup20201207 | 1 | 1 | 0 | | 1 | 0 |
| 14847 | gca/backup20201208 | 1 | 1 | 0 | | 1 | 0 |
| 14884 | gca/backup20201209 | 1 | 1 | 0 | | 1 | 0 |
| 14921 | gca/backup20201210 | 1 | 1 | 0 | | 1 | 0 |
| 14958 | gca/backup20201211 | 1 | 1 | 0 | | 1 | 0 |
| 14995 | gca/backup20201212 | 1 | 1 | 0 | | 1 | 0 |
| 15032 | gca/backup20201213 | 1 | 1 | 0 | | 1 | 0 |
| 15069 | gca/backup20201214 | 1 | 1 | 0 | | 1 | 0 |
| 15106 | gca/backup20201215 | 1 | 1 | 0 | | 1 | 0 |
| 15143 | gca/backup20201216 | 1 | 1 | 0 | | 1 | 0 |
| 15180 | gca/backup20201217 | 1 | 1 | 0 | | 1 | 0 |
| 15217 | gca/backup20201218 | 1 | 1 | 0 | | 1 | 0 |
| 15254 | gca/backup20201219 | 1 | 1 | 0 | | 1 | 0 |
| 15291 | gca/backup20201220 | 1 | 1 | 0 | | 1 | 0 |
| 15328 | gca/backup20201221 | 1 | 1 | 0 | | 1 | 0 |
| 15399 | chat/pre3.9.3Upgrade | 1 | 1 | 0 | | 1 | 0 |
| 15940 | mahertest | 1 | 1 | 0 | | 1 | 0 |
| 17166 | btp/pre_update | 1 | 1 | 0 | | 1 | 0 |
| 17167 | btp/post_update | 1 | 1 | 0 | | 1 | 0 |
| 17575 | btp/pre_slider_plugin | 1 | 1 | 0 | | 1 | 0 |
| 17576 | btp/post_slider_plugin | 1 | 1 | 0 | | 1 | 0 |
| 18095 | btp/pre_update_20210305 | 1 | 1 | 0 | | 1 | 0 |
| 18096 | cbi/pre_update_20210305 | 1 | 1 | 0 | | 1 | 0 |
| 18097 | elements/pre_update_20210305 | 1 | 1 | 0 | | 1 | 0 |
| 18875 | athena/pre-LAM-new-cert | 1 | 1 | 0 | | 1 | 0 |
| 18876 | athena/pre-LAM-new-cert2 | 1 | 1 | 0 | | 1 | 0 |
| 21134 | pitemp | 1 | 1 | 0 | | 1 | 0 |
| 22385 | mahertest/current | 1 | 1 | 0 | | 1 | 0 |
| 22389 | walshsrv | 1 | 1 | 0 | | 1 | 0 |
| 22732 | athena/pre-LAM7.6-upgrade | 1 | 1 | 0 | | 1 | 0 |
| 23873 | btp/preupdate_20210806 | 1 | 1 | 0 | | 1 | 0 |
| 23874 | elements/preupdate_20210806 | 1 | 1 | 0 | | 1 | 0 |
| 26536 | idea | 1 | 1 | 0 | | 1 | 0 |
| 26537 | idea/pre-privacyidea-install | 1 | 1 | 0 | | 1 | 0 |
| 26730 | bmbbooking/pre-mrbs-upgrade | 1 | 1 | 0 | | 1 | 0 |
| 26731 | chembooking/pre-mrbs-upgrade | 1 | 1 | 0 | | 1 | 0 |
| 26771 | idea/pre-virtualenv-install | 1 | 1 | 0 | | 1 | 0 |
| 26772 | idea/2-pre-database-install | 1 | 1 | 0 | | 1 | 0 |
| 26777 | idea/3-post-configuration | 1 | 1 | 0 | | 1 | 0 |
| 26934 | idea/4-pre-web-config | 1 | 1 | 0 | | 1 | 0 |
| 26935 | idea/post-apt-PI-install-with-failure | 1 | 1 | 0 | | 1 | 0 |
| 26936 | idea/pre-privacyidea-apache2-install | 1 | 1 | 0 | | 1 | 0 |
| 26937 | idea/post-privacyidea-apache2-install | 1 | 1 | 0 | | 1 | 0 |
| 27055 | idea/post-privacyidea-initial-config | 1 | 1 | 0 | | 1 | 0 |
| 27563 | chienbrowser | 1 | 1 | 0 | | 1 | 0 |
| 27565 | chienbrowser/pre_shiny_update | 1 | 1 | 0 | | 1 | 0 |
| 27806 | idea/pre-webui-login-diable | 1 | 1 | 0 | | 1 | 0 |
| 27807 | idea/post-webui-add-networks | 1 | 1 | 0 | | 1 | 0 |
| 27888 | rt5 | 1 | 1 | 0 | | 1 | 0 |
| 27927 | rt5/current | 1 | 1 | 0 | | 1 | 0 |
| 28086 | rt4-3-3/pre-getmail-install | 1 | 1 | 0 | | 1 | 0 |
| 28321 | pitemp/pre-trim-database | 1 | 1 | 0 | | 1 | 0 |
| 28977 | franklin/current | 1 | 1 | 0 | | 1 | 0 |
| 28985 | franklin/pre-update-of-papercut | 1 | 1 | 0 | | 1 | 0 |
| 29215 | dokuwiki/pre-2fa-plugin | 1 | 1 | 0 | | 1 | 0 |
| 29710 | athena/pre-LAM-7.8-upgrade | 1 | 1 | 0 | | 1 | 0 |
| 30240 | chat/current | 1 | 1 | 0 | | 1 | 0 |
| 32345 | athena/pre-new-cert | 1 | 1 | 0 | | 1 | 0 |
| 36488 | athena/pre-LAM-8.0.1-upgrade | 1 | 1 | 0 | | 1 | 0 |
| 37667 | athena/pre-ldapadmins-change | 1 | 1 | 0 | | 1 | 0 |
| 39130 | apps-chem/current | 1 | 1 | 0 | | 1 | 0 |
| 39927 | container-2204 | 1 | 1 | 0 | | 1 | 0 |
| 40043 | container-2204/temp | 1 | 1 | 0 | | 1 | 0 |
| 40044 | duchenelab | 1 | 1 | 0 | | 1 | 0 |
| 40045 | 12aafd73c6466e8a6da20e180fb3c02454d54a508e99584078ca00f1df74082a | 1 | 1 | 1 | | 1 | 0 |
| 40085 | duchenelab/pre-mysql-config | 1 | 1 | 0 | | 1 | 0 |
| 40086 | duchenelab/pre-wordpress-install-script | 1 | 1 | 0 | | 1 | 0 |
| 40126 | duchenelab/pre-ldap-plugin-install | 1 | 1 | 0 | | 1 | 0 |
| 40127 | duchenelab/post-ldap-pre-2fa | 1 | 1 | 0 | | 1 | 0 |
| 40128 | idea/20221005_1151 | 1 | 1 | 0 | | 1 | 0 |
| 40129 | duchenelab/pre-ssh-update-config | 1 | 1 | 0 | | 1 | 0 |
| 40208 | duchenelab/pre-revert | 1 | 1 | 0 | | 1 | 0 |
| 40959 | it/backup20221027 | 1 | 1 | 0 | | 1 | 0 |
| 40960 | itwiki/backup20221027 | 1 | 1 | 0 | | 1 | 0 |
| 40998 | it/backup20221028 | 1 | 1 | 0 | | 1 | 0 |
| 40999 | itwiki/backup20221028 | 1 | 1 | 0 | | 1 | 0 |
| 41037 | it/backup20221029 | 1 | 1 | 0 | | 1 | 0 |
| 41038 | itwiki/backup20221029 | 1 | 1 | 0 | | 1 | 0 |
| 41076 | it/backup20221030 | 1 | 1 | 0 | | 1 | 0 |
| 41077 | itwiki/backup20221030 | 1 | 1 | 0 | | 1 | 0 |
| 41115 | it/backup20221031 | 1 | 1 | 0 | | 1 | 0 |
| 41116 | itwiki/backup20221031 | 1 | 1 | 0 | | 1 | 0 |
| 41154 | it/backup20221101 | 1 | 1 | 0 | | 1 | 0 |
| 41155 | itwiki/backup20221101 | 1 | 1 | 0 | | 1 | 0 |
| 41193 | it/backup20221102 | 1 | 1 | 0 | | 1 | 0 |
| 41194 | itwiki/backup20221102 | 1 | 1 | 0 | | 1 | 0 |
| 41231 | it/backup20221103 | 1 | 1 | 0 | | 1 | 0 |
| 41232 | itwiki/backup20221103 | 1 | 1 | 0 | | 1 | 0 |
| 41269 | it/backup20221104 | 1 | 1 | 0 | | 1 | 0 |
| 41270 | itwiki/backup20221104 | 1 | 1 | 0 | | 1 | 0 |
| 41307 | it/backup20221105 | 1 | 1 | 0 | | 1 | 0 |
| 41308 | itwiki/backup20221105 | 1 | 1 | 0 | | 1 | 0 |
| 41345 | it/backup20221106 | 1 | 1 | 0 | | 1 | 0 |
| 41346 | itwiki/backup20221106 | 1 | 1 | 0 | | 1 | 0 |
| 41383 | it/backup20221107 | 1 | 1 | 0 | | 1 | 0 |
| 41384 | itwiki/backup20221107 | 1 | 1 | 0 | | 1 | 0 |
| 41414 | elements-dev/backup20221108 | 1 | 1 | 0 | | 1 | 0 |
| 41421 | it/backup20221108 | 1 | 1 | 0 | | 1 | 0 |
| 41422 | itwiki/backup20221108 | 1 | 1 | 0 | | 1 | 0 |
| 41429 | wptest/backup20221108 | 1 | 1 | 0 | | 1 | 0 |
| 41453 | elements-dev/backup20221109 | 1 | 1 | 0 | | 1 | 0 |
| 41454 | genchem/backup20221109 | 1 | 1 | 0 | | 1 | 0 |
| 41455 | growthchambers/backup20221109 | 1 | 1 | 0 | | 1 | 0 |
| 41456 | hardylab/backup20221109 | 1 | 1 | 0 | | 1 | 0 |
| 41457 | high-pressure/backup20221109 | 1 | 1 | 0 | | 1 | 0 |
| 41458 | isbbooking/backup20221109 | 1 | 1 | 0 | | 1 | 0 |
| 41460 | it/backup20221109 | 1 | 1 | 0 | | 1 | 0 |
| 41461 | itwiki/backup20221109 | 1 | 1 | 0 | | 1 | 0 |
| 41466 | skouta/backup20221109 | 1 | 1 | 0 | | 1 | 0 |
| 41468 | wptest/backup20221109 | 1 | 1 | 0 | | 1 | 0 |
| 41492 | elements-dev/backup20221110 | 1 | 1 | 0 | | 1 | 0 |
| 41493 | genchem/backup20221110 | 1 | 1 | 0 | | 1 | 0 |
| 41494 | growthchambers/backup20221110 | 1 | 1 | 0 | | 1 | 0 |
| 41495 | hardylab/backup20221110 | 1 | 1 | 0 | | 1 | 0 |
| 41496 | high-pressure/backup20221110 | 1 | 1 | 0 | | 1 | 0 |
| 41497 | isbbooking/backup20221110 | 1 | 1 | 0 | | 1 | 0 |
| 41499 | it/backup20221110 | 1 | 1 | 0 | | 1 | 0 |
| 41500 | itwiki/backup20221110 | 1 | 1 | 0 | | 1 | 0 |
| 41505 | skouta/backup20221110 | 1 | 1 | 0 | | 1 | 0 |
| 41507 | wptest/backup20221110 | 1 | 1 | 0 | | 1 | 0 |
| 41531 | elements-dev/backup20221111 | 1 | 1 | 0 | | 1 | 0 |
| 41532 | genchem/backup20221111 | 1 | 1 | 0 | | 1 | 0 |
| 41533 | growthchambers/backup20221111 | 1 | 1 | 0 | | 1 | 0 |
| 41534 | hardylab/backup20221111 | 1 | 1 | 0 | | 1 | 0 |
| 41535 | high-pressure/backup20221111 | 1 | 1 | 0 | | 1 | 0 |
| 41536 | isbbooking/backup20221111 | 1 | 1 | 0 | | 1 | 0 |
| 41542 | skouta/backup20221111 | 1 | 1 | 0 | | 1 | 0 |
| 41544 | wptest/backup20221111 | 1 | 1 | 0 | | 1 | 0 |
| 41568 | elements-dev/backup20221112 | 1 | 1 | 0 | | 1 | 0 |
| 41569 | genchem/backup20221112 | 1 | 1 | 0 | | 1 | 0 |
| 41570 | growthchambers/backup20221112 | 1 | 1 | 0 | | 1 | 0 |
| 41571 | hardylab/backup20221112 | 1 | 1 | 0 | | 1 | 0 |
| 41572 | high-pressure/backup20221112 | 1 | 1 | 0 | | 1 | 0 |
| 41573 | isbbooking/backup20221112 | 1 | 1 | 0 | | 1 | 0 |
| 41579 | skouta/backup20221112 | 1 | 1 | 0 | | 1 | 0 |
| 41581 | wptest/backup20221112 | 1 | 1 | 0 | | 1 | 0 |
| 41605 | elements-dev/backup20221113 | 1 | 1 | 0 | | 1 | 0 |
| 41606 | genchem/backup20221113 | 1 | 1 | 0 | | 1 | 0 |
| 41607 | growthchambers/backup20221113 | 1 | 1 | 0 | | 1 | 0 |
| 41608 | hardylab/backup20221113 | 1 | 1 | 0 | | 1 | 0 |
| 41609 | high-pressure/backup20221113 | 1 | 1 | 0 | | 1 | 0 |
| 41610 | isbbooking/backup20221113 | 1 | 1 | 0 | | 1 | 0 |
| 41616 | skouta/backup20221113 | 1 | 1 | 0 | | 1 | 0 |
| 41618 | wptest/backup20221113 | 1 | 1 | 0 | | 1 | 0 |
| 41642 | elements-dev/backup20221114 | 1 | 1 | 0 | | 1 | 0 |
| 41643 | genchem/backup20221114 | 1 | 1 | 0 | | 1 | 0 |
| 41644 | growthchambers/backup20221114 | 1 | 1 | 0 | | 1 | 0 |
| 41645 | hardylab/backup20221114 | 1 | 1 | 0 | | 1 | 0 |
| 41646 | high-pressure/backup20221114 | 1 | 1 | 0 | | 1 | 0 |
| 41647 | isbbooking/backup20221114 | 1 | 1 | 0 | | 1 | 0 |
| 41648 | isbinstruments/backup20221114 | 1 | 1 | 0 | | 1 | 0 |
| 41649 | martinlab/backup20221114 | 1 | 1 | 0 | | 1 | 0 |
| 41650 | people/backup20221114 | 1 | 1 | 0 | | 1 | 0 |
| 41651 | redirected-sites/backup20221114 | 1 | 1 | 0 | | 1 | 0 |
| 41652 | sites/backup20221114 | 1 | 1 | 0 | | 1 | 0 |
| 41653 | skouta/backup20221114 | 1 | 1 | 0 | | 1 | 0 |
| 41654 | welab/backup20221114 | 1 | 1 | 0 | | 1 | 0 |
| 41655 | wptest/backup20221114 | 1 | 1 | 0 | | 1 | 0 |
| 41679 | elements-dev/backup20221115 | 1 | 1 | 0 | | 1 | 0 |
| 41680 | genchem/backup20221115 | 1 | 1 | 0 | | 1 | 0 |
| 41681 | growthchambers/backup20221115 | 1 | 1 | 0 | | 1 | 0 |
| 41682 | hardylab/backup20221115 | 1 | 1 | 0 | | 1 | 0 |
| 41683 | high-pressure/backup20221115 | 1 | 1 | 0 | | 1 | 0 |
| 41684 | isbbooking/backup20221115 | 1 | 1 | 0 | | 1 | 0 |
| 41685 | isbinstruments/backup20221115 | 1 | 1 | 0 | | 1 | 0 |
| 41686 | martinlab/backup20221115 | 1 | 1 | 0 | | 1 | 0 |
| 41687 | people/backup20221115 | 1 | 1 | 0 | | 1 | 0 |
| 41688 | redirected-sites/backup20221115 | 1 | 1 | 0 | | 1 | 0 |
| 41689 | sites/backup20221115 | 1 | 1 | 0 | | 1 | 0 |
| 41690 | skouta/backup20221115 | 1 | 1 | 0 | | 1 | 0 |
| 41691 | welab/backup20221115 | 1 | 1 | 0 | | 1 | 0 |
| 41692 | wptest/backup20221115 | 1 | 1 | 0 | | 1 | 0 |
| 41723 | container-2204/now | 1 | 1 | 0 | | 1 | 0 |
| 41738 | elements-dev/backup20221116 | 1 | 1 | 0 | | 1 | 0 |
| 41739 | genchem/backup20221116 | 1 | 1 | 0 | | 1 | 0 |
| 41740 | growthchambers/backup20221116 | 1 | 1 | 0 | | 1 | 0 |
| 41741 | hardylab/backup20221116 | 1 | 1 | 0 | | 1 | 0 |
| 41742 | high-pressure/backup20221116 | 1 | 1 | 0 | | 1 | 0 |
| 41743 | isbbooking/backup20221116 | 1 | 1 | 0 | | 1 | 0 |
| 41744 | isbinstruments/backup20221116 | 1 | 1 | 0 | | 1 | 0 |
| 41745 | martinlab/backup20221116 | 1 | 1 | 0 | | 1 | 0 |
| 41746 | people/backup20221116 | 1 | 1 | 0 | | 1 | 0 |
| 41747 | redirected-sites/backup20221116 | 1 | 1 | 0 | | 1 | 0 |
| 41748 | sites/backup20221116 | 1 | 1 | 0 | | 1 | 0 |
| 41749 | skouta/backup20221116 | 1 | 1 | 0 | | 1 | 0 |
| 41750 | welab/backup20221116 | 1 | 1 | 0 | | 1 | 0 |
| 41751 | wptest/backup20221116 | 1 | 1 | 0 | | 1 | 0 |
| 41775 | elements-dev/backup20221117 | 1 | 1 | 0 | | 1 | 0 |
| 41776 | genchem/backup20221117 | 1 | 1 | 0 | | 1 | 0 |
| 41777 | growthchambers/backup20221117 | 1 | 1 | 0 | | 1 | 0 |
| 41778 | hardylab/backup20221117 | 1 | 1 | 0 | | 1 | 0 |
| 41779 | high-pressure/backup20221117 | 1 | 1 | 0 | | 1 | 0 |
| 41780 | isbbooking/backup20221117 | 1 | 1 | 0 | | 1 | 0 |
| 41781 | isbinstruments/backup20221117 | 1 | 1 | 0 | | 1 | 0 |
| 41782 | martinlab/backup20221117 | 1 | 1 | 0 | | 1 | 0 |
| 41783 | people/backup20221117 | 1 | 1 | 0 | | 1 | 0 |
| 41784 | redirected-sites/backup20221117 | 1 | 1 | 0 | | 1 | 0 |
| 41785 | sites/backup20221117 | 1 | 1 | 0 | | 1 | 0 |
| 41786 | skouta/backup20221117 | 1 | 1 | 0 | | 1 | 0 |
| 41787 | welab/backup20221117 | 1 | 1 | 0 | | 1 | 0 |
| 41788 | wptest/backup20221117 | 1 | 1 | 0 | | 1 | 0 |
| 41812 | elements-dev/backup20221118 | 1 | 1 | 0 | | 1 | 0 |
| 41813 | genchem/backup20221118 | 1 | 1 | 0 | | 1 | 0 |
| 41814 | growthchambers/backup20221118 | 1 | 1 | 0 | | 1 | 0 |
| 41815 | hardylab/backup20221118 | 1 | 1 | 0 | | 1 | 0 |
| 41816 | high-pressure/backup20221118 | 1 | 1 | 0 | | 1 | 0 |
| 41817 | isbbooking/backup20221118 | 1 | 1 | 0 | | 1 | 0 |
| 41818 | isbinstruments/backup20221118 | 1 | 1 | 0 | | 1 | 0 |
| 41819 | martinlab/backup20221118 | 1 | 1 | 0 | | 1 | 0 |
| 41820 | people/backup20221118 | 1 | 1 | 0 | | 1 | 0 |
| 41821 | redirected-sites/backup20221118 | 1 | 1 | 0 | | 1 | 0 |
| 41822 | sites/backup20221118 | 1 | 1 | 0 | | 1 | 0 |
| 41823 | skouta/backup20221118 | 1 | 1 | 0 | | 1 | 0 |
| 41824 | welab/backup20221118 | 1 | 1 | 0 | | 1 | 0 |
| 41825 | wptest/backup20221118 | 1 | 1 | 0 | | 1 | 0 |
| 41872 | elements-dev/backup20221119 | 1 | 1 | 0 | | 1 | 0 |
| 41873 | genchem/backup20221119 | 1 | 1 | 0 | | 1 | 0 |
| 41874 | growthchambers/backup20221119 | 1 | 1 | 0 | | 1 | 0 |
| 41875 | hardylab/backup20221119 | 1 | 1 | 0 | | 1 | 0 |
| 41876 | high-pressure/backup20221119 | 1 | 1 | 0 | | 1 | 0 |
| 41877 | isbbooking/backup20221119 | 1 | 1 | 0 | | 1 | 0 |
| 41878 | isbinstruments/backup20221119 | 1 | 1 | 0 | | 1 | 0 |
| 41879 | martinlab/backup20221119 | 1 | 1 | 0 | | 1 | 0 |
| 41880 | people/backup20221119 | 1 | 1 | 0 | | 1 | 0 |
| 41881 | redirected-sites/backup20221119 | 1 | 1 | 0 | | 1 | 0 |
| 41882 | sites/backup20221119 | 1 | 1 | 0 | | 1 | 0 |
| 41883 | skouta/backup20221119 | 1 | 1 | 0 | | 1 | 0 |
| 41884 | welab/backup20221119 | 1 | 1 | 0 | | 1 | 0 |
| 41885 | wptest/backup20221119 | 1 | 1 | 0 | | 1 | 0 |
| 41932 | elements-dev/backup20221120 | 1 | 1 | 0 | | 1 | 0 |
| 41933 | genchem/backup20221120 | 1 | 1 | 0 | | 1 | 0 |
| 41934 | growthchambers/backup20221120 | 1 | 1 | 0 | | 1 | 0 |
| 41935 | hardylab/backup20221120 | 1 | 1 | 0 | | 1 | 0 |
| 41936 | high-pressure/backup20221120 | 1 | 1 | 0 | | 1 | 0 |
| 41937 | isbbooking/backup20221120 | 1 | 1 | 0 | | 1 | 0 |
| 41938 | isbinstruments/backup20221120 | 1 | 1 | 0 | | 1 | 0 |
| 41939 | martinlab/backup20221120 | 1 | 1 | 0 | | 1 | 0 |
| 41940 | people/backup20221120 | 1 | 1 | 0 | | 1 | 0 |
| 41941 | redirected-sites/backup20221120 | 1 | 1 | 0 | | 1 | 0 |
| 41942 | sites/backup20221120 | 1 | 1 | 0 | | 1 | 0 |
| 41943 | skouta/backup20221120 | 1 | 1 | 0 | | 1 | 0 |
| 41944 | welab/backup20221120 | 1 | 1 | 0 | | 1 | 0 |
| 41945 | wptest/backup20221120 | 1 | 1 | 0 | | 1 | 0 |
| 41992 | elements-dev/backup20221121 | 1 | 1 | 0 | | 1 | 0 |
| 41993 | genchem/backup20221121 | 1 | 1 | 0 | | 1 | 0 |
| 41994 | growthchambers/backup20221121 | 1 | 1 | 0 | | 1 | 0 |
| 41995 | hardylab/backup20221121 | 1 | 1 | 0 | | 1 | 0 |
| 41996 | high-pressure/backup20221121 | 1 | 1 | 0 | | 1 | 0 |
| 41997 | isbbooking/backup20221121 | 1 | 1 | 0 | | 1 | 0 |
| 41998 | isbinstruments/backup20221121 | 1 | 1 | 0 | | 1 | 0 |
| 41999 | martinlab/backup20221121 | 1 | 1 | 0 | | 1 | 0 |
| 42000 | people/backup20221121 | 1 | 1 | 0 | | 1 | 0 |
| 42001 | redirected-sites/backup20221121 | 1 | 1 | 0 | | 1 | 0 |
| 42002 | sites/backup20221121 | 1 | 1 | 0 | | 1 | 0 |
| 42003 | skouta/backup20221121 | 1 | 1 | 0 | | 1 | 0 |
| 42004 | welab/backup20221121 | 1 | 1 | 0 | | 1 | 0 |
| 42005 | wptest/backup20221121 | 1 | 1 | 0 | | 1 | 0 |
| 42052 | elements-dev/backup20221122 | 1 | 1 | 0 | | 1 | 0 |
| 42053 | genchem/backup20221122 | 1 | 1 | 0 | | 1 | 0 |
| 42054 | growthchambers/backup20221122 | 1 | 1 | 0 | | 1 | 0 |
| 42055 | hardylab/backup20221122 | 1 | 1 | 0 | | 1 | 0 |
| 42056 | high-pressure/backup20221122 | 1 | 1 | 0 | | 1 | 0 |
| 42057 | isbbooking/backup20221122 | 1 | 1 | 0 | | 1 | 0 |
| 42058 | isbinstruments/backup20221122 | 1 | 1 | 0 | | 1 | 0 |
| 42059 | martinlab/backup20221122 | 1 | 1 | 0 | | 1 | 0 |
| 42060 | people/backup20221122 | 1 | 1 | 0 | | 1 | 0 |
| 42061 | redirected-sites/backup20221122 | 1 | 1 | 0 | | 1 | 0 |
| 42062 | sites/backup20221122 | 1 | 1 | 0 | | 1 | 0 |
| 42063 | skouta/backup20221122 | 1 | 1 | 0 | | 1 | 0 |
| 42064 | welab/backup20221122 | 1 | 1 | 0 | | 1 | 0 |
| 42065 | wptest/backup20221122 | 1 | 1 | 0 | | 1 | 0 |
| 42110 | haproxy-trixie | 1 | 1 | 0 | | 1 | 0 |
| 42113 | genchem/backup20221123 | 1 | 1 | 0 | | 1 | 0 |
| 42114 | growthchambers/backup20221123 | 1 | 1 | 0 | | 1 | 0 |
| 42115 | hardylab/backup20221123 | 1 | 1 | 0 | | 1 | 0 |
| 42116 | high-pressure/backup20221123 | 1 | 1 | 0 | | 1 | 0 |
| 42117 | isbbooking/backup20221123 | 1 | 1 | 0 | | 1 | 0 |
| 42118 | isbinstruments/backup20221123 | 1 | 1 | 0 | | 1 | 0 |
| 42119 | martinlab/backup20221123 | 1 | 1 | 0 | | 1 | 0 |
| 42120 | people/backup20221123 | 1 | 1 | 0 | | 1 | 0 |
| 42121 | redirected-sites/backup20221123 | 1 | 1 | 0 | | 1 | 0 |
| 42122 | sites/backup20221123 | 1 | 1 | 0 | | 1 | 0 |
| 42123 | skouta/backup20221123 | 1 | 1 | 0 | | 1 | 0 |
| 42124 | welab/backup20221123 | 1 | 1 | 0 | | 1 | 0 |
| 42171 | isbinstruments/backup20221124 | 1 | 1 | 0 | | 1 | 0 |
| 42172 | martinlab/backup20221124 | 1 | 1 | 0 | | 1 | 0 |
| 42173 | people/backup20221124 | 1 | 1 | 0 | | 1 | 0 |
| 42174 | redirected-sites/backup20221124 | 1 | 1 | 0 | | 1 | 0 |
| 42175 | sites/backup20221124 | 1 | 1 | 0 | | 1 | 0 |
| 42176 | welab/backup20221124 | 1 | 1 | 0 | | 1 | 0 |
| 42223 | isbinstruments/backup20221125 | 1 | 1 | 0 | | 1 | 0 |
| 42224 | martinlab/backup20221125 | 1 | 1 | 0 | | 1 | 0 |
| 42225 | people/backup20221125 | 1 | 1 | 0 | | 1 | 0 |
| 42226 | redirected-sites/backup20221125 | 1 | 1 | 0 | | 1 | 0 |
| 42227 | sites/backup20221125 | 1 | 1 | 0 | | 1 | 0 |
| 42228 | welab/backup20221125 | 1 | 1 | 0 | | 1 | 0 |
| 42275 | isbinstruments/backup20221126 | 1 | 1 | 0 | | 1 | 0 |
| 42276 | martinlab/backup20221126 | 1 | 1 | 0 | | 1 | 0 |
| 42277 | people/backup20221126 | 1 | 1 | 0 | | 1 | 0 |
| 42278 | redirected-sites/backup20221126 | 1 | 1 | 0 | | 1 | 0 |
| 42279 | sites/backup20221126 | 1 | 1 | 0 | | 1 | 0 |
| 42280 | welab/backup20221126 | 1 | 1 | 0 | | 1 | 0 |
| 42327 | isbinstruments/backup20221127 | 1 | 1 | 0 | | 1 | 0 |
| 42328 | martinlab/backup20221127 | 1 | 1 | 0 | | 1 | 0 |
| 42329 | people/backup20221127 | 1 | 1 | 0 | | 1 | 0 |
| 42330 | redirected-sites/backup20221127 | 1 | 1 | 0 | | 1 | 0 |
| 42331 | sites/backup20221127 | 1 | 1 | 0 | | 1 | 0 |
| 42332 | welab/backup20221127 | 1 | 1 | 0 | | 1 | 0 |
| 42379 | isbinstruments/backup20221128 | 1 | 1 | 0 | | 1 | 0 |
| 42380 | martinlab/backup20221128 | 1 | 1 | 0 | | 1 | 0 |
| 42381 | people/backup20221128 | 1 | 1 | 0 | | 1 | 0 |
| 42382 | redirected-sites/backup20221128 | 1 | 1 | 0 | | 1 | 0 |
| 42383 | sites/backup20221128 | 1 | 1 | 0 | | 1 | 0 |
| 42384 | welab/backup20221128 | 1 | 1 | 0 | | 1 | 0 |
| 42429 | wptest-20221128 | 1 | 1 | 0 | | 1 | 0 |
| 42454 | haproxy-trixie-20221129 | 1 | 1 | 0 | | 1 | 0 |
| 42576 | bmbdept/current | 1 | 1 | 0 | | 1 | 0 |
| 42581 | container-2204/current | 1 | 1 | 0 | | 1 | 0 |
| 43214 | cyclone/current | 1 | 1 | 0 | | 1 | 0 |
| 43226 | cyclone/now | 1 | 1 | 0 | | 1 | 0 |
| 43227 | apps-biochem/now | 1 | 1 | 0 | | 1 | 0 |
| 43229 | barnes/now | 1 | 1 | 0 | | 1 | 0 |
| 43230 | bmbbooking/now | 1 | 1 | 0 | | 1 | 0 |
| 43231 | btp/now | 1 | 1 | 0 | | 1 | 0 |
| 43232 | cbi/now | 1 | 1 | 0 | | 1 | 0 |
| 43233 | chembooking/now | 1 | 1 | 0 | | 1 | 0 |
| 43234 | chienbrowser/now | 1 | 1 | 0 | | 1 | 0 |
| 43235 | dokuwiki/now | 1 | 1 | 0 | | 1 | 0 |
| 43236 | duchenelab/now | 1 | 1 | 0 | | 1 | 0 |
| 43237 | eexambooking/now | 1 | 1 | 0 | | 1 | 0 |
| 43238 | elements/now | 1 | 1 | 0 | | 1 | 0 |
| 43239 | hammer/now | 1 | 1 | 0 | | 1 | 0 |
| 43240 | haproxy/now | 1 | 1 | 0 | | 1 | 0 |
| 43242 | lecturedemos/now | 1 | 1 | 0 | | 1 | 0 |
| 43243 | pitemp/now | 1 | 1 | 0 | | 1 | 0 |
| 43244 | rt4-3-3/now | 1 | 1 | 0 | | 1 | 0 |
| 43245 | samson/now | 1 | 1 | 0 | | 1 | 0 |
| 43246 | walshsrv/now | 1 | 1 | 0 | | 1 | 0 |
| 43328 | haproxy/current | 1 | 1 | 0 | | 1 | 0 |
| 43329 | apps-biochem/current | 1 | 1 | 0 | | 1 | 0 |
| 43330 | athena/current | 1 | 1 | 0 | | 1 | 0 |
| 43331 | barnes/current | 1 | 1 | 0 | | 1 | 0 |
| 43332 | bmbbooking/current | 1 | 1 | 0 | | 1 | 0 |
| 43333 | btp/current | 1 | 1 | 0 | | 1 | 0 |
| 43334 | cbi/current | 1 | 1 | 0 | | 1 | 0 |
| 43335 | chembooking/current | 1 | 1 | 0 | | 1 | 0 |
| 43336 | chienbrowser/current | 1 | 1 | 0 | | 1 | 0 |
| 43337 | dokuwiki/current | 1 | 1 | 0 | | 1 | 0 |
| 43338 | duchenelab/current | 1 | 1 | 0 | | 1 | 0 |
| 43339 | eexambooking/current | 1 | 1 | 0 | | 1 | 0 |
| 43340 | elements/current | 1 | 1 | 0 | | 1 | 0 |
| 43341 | hammer/current | 1 | 1 | 0 | | 1 | 0 |
| 43342 | idea/current | 1 | 1 | 0 | | 1 | 0 |
| 43343 | lecturedemos/current | 1 | 1 | 0 | | 1 | 0 |
| 43344 | pitemp/current | 1 | 1 | 0 | | 1 | 0 |
| 43345 | rt4-3-3/current | 1 | 1 | 0 | | 1 | 0 |
| 43346 | samson/current | 1 | 1 | 0 | | 1 | 0 |
| 43347 | walshsrv/current | 1 | 1 | 0 | | 1 | 0 |
| 43348 | athena/now | 1 | 1 | 0 | | 1 | 0 |
| 43349 | idea/now | 1 | 1 | 0 | | 1 | 0 |
tomp
(Thomas Parrott)
January 17, 2023, 1:37pm
10
johnmaher:
pitemp
There doesn’t appear to be any duplicates for pitemp now, what is the current issue now after you deleted the duplicates?
johnmaher
(John Maher)
January 17, 2023, 2:01pm
11
I’m sorry, I think I’m confusing the issue by initially being selected for one container (tried to simplify).
Trying to create a snapshot has these results:
The following sequence of commands shows missing snapshots (that may not be the right terminology) and just general inconsistencies.
It also appears that every one of my containers has duplicate records, but I honestly don’t know how to interpret all of this.
tomp
(Thomas Parrott)
January 17, 2023, 2:09pm
12
Yes that is because there is already a volume snapshot DB record called now for pitemp with an ID of 43243. But not, seemingly, an instance snapshot DB record for the same name (normally there are 2 DB records per instance snapshot).
Are you happy to delete all snapshot records for pitemp?
tomp
(Thomas Parrott)
January 17, 2023, 2:11pm
13
What does lxc info pitemp and lxc config show pitemp --expanded show?
Also what does lxc storage show <pool> show?
johnmaher
(John Maher)
January 17, 2023, 2:27pm
14
I’m assuming that you’re only asking about the snapshots in lxc info pitemp, but please let me know if I’m wrong.
$ lxc info pitemp
Snapshots:
$ lxc config show pitemp --expanded
boot.autostart: "true"
volatile.base_image: 50aaf0ac9542a398fcceab0e55c4dc64857844b634b180d73e5912c1342228f7
volatile.eth0.host_name: vethd986c669
volatile.eth0.hwaddr: 00:16:3e:4c:78:12
volatile.idmap.base: "0"
volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":100000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":100000,"Nsid":0,"Maprange":65536}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":100000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":100000,"Nsid":0,"Maprange":65536}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":false,"Hostid":100000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":100000,"Nsid":0,"Maprange":65536}]'
volatile.uuid: 2acf5db7-0e71-47a6-8ebd-8e4930868147
nictype: bridged
parent: lxdbr0
pool: default
johnmaher
(John Maher)
January 17, 2023, 2:34pm
15
Yes, I’m fine with getting rid of all snapshots, but I don’t know how to do that.
tomp
(Thomas Parrott)
16
tomp:
Please show output of that command so I can see the pool config.
johnmaher
(John Maher)
January 17, 2023, 2:35pm
17
I hope this is better.
source: /var/snap/lxd/common/lxd/storage-pools/default
volatile.initial_source: /var/lib/lxd/storage-pools/default
driver: btrfs
- /1.0/images/12aafd73c6466e8a6da20e180fb3c02454d54a508e99584078ca00f1df74082a
- /1.0/images/50aaf0ac9542a398fcceab0e55c4dc64857844b634b180d73e5912c1342228f7
- /1.0/images/a6d9a1f348a923af25f79586bdfba6f3020f16707b7807979a10c955695eb73a
- /1.0/instances/apps-biochem
- /1.0/instances/apps-biochem/snapshots/current
- /1.0/instances/apps-biochem/snapshots/now
- /1.0/instances/apps-chem
- /1.0/instances/apps-chem/snapshots/500_error
- /1.0/instances/apps-chem/snapshots/current
- /1.0/instances/apps-chem/snapshots/link_error
- /1.0/instances/athena
- /1.0/instances/athena-backup
- /1.0/instances/athena-backup/snapshots/current
- /1.0/instances/athena-backup/snapshots/pre_LAM_upgrade
- /1.0/instances/athena/snapshots/current
- /1.0/instances/athena/snapshots/now
- /1.0/instances/athena/snapshots/pre-LAM-7.8-upgrade
- /1.0/instances/athena/snapshots/pre-LAM-8.0.1-upgrade
- /1.0/instances/athena/snapshots/pre-LAM-new-cert
- /1.0/instances/athena/snapshots/pre-LAM-new-cert2
- /1.0/instances/athena/snapshots/pre-LAM7.6-upgrade
- /1.0/instances/athena/snapshots/pre-ldapadmins-change
- /1.0/instances/athena/snapshots/pre-new-cert
- /1.0/instances/barnes
- /1.0/instances/barnes/snapshots/current
- /1.0/instances/barnes/snapshots/now
- /1.0/instances/blahblah
- /1.0/instances/blahblah/snapshots/backup20191028
- /1.0/instances/blahblah/snapshots/backup20191029
- /1.0/instances/blahblah/snapshots/backup20191030
- /1.0/instances/blahblah/snapshots/backup20191031
- /1.0/instances/blahblah/snapshots/backup20191101
- /1.0/instances/blahblah/snapshots/backup20191102
- /1.0/instances/blahblah/snapshots/backup20191103
- /1.0/instances/blahblah/snapshots/backup20191104
- /1.0/instances/bmbbooking
- /1.0/instances/bmbbooking/snapshots/current
- /1.0/instances/bmbbooking/snapshots/now
- /1.0/instances/bmbbooking/snapshots/pre-mrbs-upgrade
- /1.0/instances/bmbbooking/snapshots/pre_mic_cal
- /1.0/instances/bmbdept
- /1.0/instances/bmbdept/snapshots/current
- /1.0/instances/bmbdept/snapshots/pre_data_ingestion
- /1.0/instances/btp
- /1.0/instances/btp/snapshots/current
- /1.0/instances/btp/snapshots/now
- /1.0/instances/btp/snapshots/post_slider_plugin
- /1.0/instances/btp/snapshots/post_update
- /1.0/instances/btp/snapshots/pre_slider_plugin
- /1.0/instances/btp/snapshots/pre_update
- /1.0/instances/btp/snapshots/pre_update_20210305
- /1.0/instances/btp/snapshots/preupdate_20210806
- /1.0/instances/c20-04
- /1.0/instances/c20-04/snapshots/current
- /1.0/instances/cbi
- /1.0/instances/cbi/snapshots/current
- /1.0/instances/cbi/snapshots/now
- /1.0/instances/cbi/snapshots/pre_update_20210305
- /1.0/instances/cbi/snapshots/pre_updates
- /1.0/instances/cbi/snapshots/pre_upload_limit_change
- /1.0/instances/chat
- /1.0/instances/chat/snapshots/current
- /1.0/instances/chat/snapshots/orig_and_patched
- /1.0/instances/chat/snapshots/post_RocketChat_install
- /1.0/instances/chat/snapshots/pre3.9.3Upgrade
- /1.0/instances/chat/snapshots/pre_caddy_config
- /1.0/instances/chat/snapshots/pre_rocket_chat_config
- /1.0/instances/chembooking
- /1.0/instances/chembooking/snapshots/current
- /1.0/instances/chembooking/snapshots/now
- /1.0/instances/chembooking/snapshots/pre-mrbs-upgrade
- /1.0/instances/chienbrowser
- /1.0/instances/chienbrowser/snapshots/current
- /1.0/instances/chienbrowser/snapshots/now
- /1.0/instances/chienbrowser/snapshots/pre_shiny_update
- /1.0/instances/container-2204
- /1.0/instances/container-2204/snapshots/current
- /1.0/instances/container-2204/snapshots/now
- /1.0/instances/container-2204/snapshots/temp
- /1.0/instances/cyclone
- /1.0/instances/cyclone/snapshots/current
- /1.0/instances/cyclone/snapshots/now
- /1.0/instances/dokuwiki
- /1.0/instances/dokuwiki/snapshots/current
- /1.0/instances/dokuwiki/snapshots/now
- /1.0/instances/dokuwiki/snapshots/pre-2fa-plugin
- /1.0/instances/duchenelab
- /1.0/instances/duchenelab/snapshots/current
- /1.0/instances/duchenelab/snapshots/now
- /1.0/instances/duchenelab/snapshots/post-ldap-pre-2fa
- /1.0/instances/duchenelab/snapshots/pre-ldap-plugin-install
- /1.0/instances/duchenelab/snapshots/pre-mysql-config
- /1.0/instances/duchenelab/snapshots/pre-revert
- /1.0/instances/duchenelab/snapshots/pre-ssh-update-config
- /1.0/instances/duchenelab/snapshots/pre-wordpress-install-script
- /1.0/instances/eexambooking
- /1.0/instances/eexambooking/snapshots/current
- /1.0/instances/eexambooking/snapshots/now
- /1.0/instances/elements
- /1.0/instances/elements-dev
- /1.0/instances/elements-dev/snapshots/backup20221108
- /1.0/instances/elements-dev/snapshots/backup20221109
- /1.0/instances/elements-dev/snapshots/backup20221110
- /1.0/instances/elements-dev/snapshots/backup20221111
- /1.0/instances/elements-dev/snapshots/backup20221112
- /1.0/instances/elements-dev/snapshots/backup20221113
- /1.0/instances/elements-dev/snapshots/backup20221114
- /1.0/instances/elements-dev/snapshots/backup20221115
- /1.0/instances/elements-dev/snapshots/backup20221116
- /1.0/instances/elements-dev/snapshots/backup20221117
- /1.0/instances/elements-dev/snapshots/backup20221118
- /1.0/instances/elements-dev/snapshots/backup20221119
- /1.0/instances/elements-dev/snapshots/backup20221120
- /1.0/instances/elements-dev/snapshots/backup20221121
- /1.0/instances/elements-dev/snapshots/backup20221122
- /1.0/instances/elements/snapshots/current
- /1.0/instances/elements/snapshots/now
- /1.0/instances/elements/snapshots/pre_update_20210305
- /1.0/instances/elements/snapshots/pre_updates
- /1.0/instances/elements/snapshots/preupdate_20210806
- /1.0/instances/franklin
- /1.0/instances/franklin/snapshots/current
- /1.0/instances/franklin/snapshots/pre-update-of-papercut
- /1.0/instances/franklin/snapshots/pre_group_import
- /1.0/instances/gca
- /1.0/instances/gca/snapshots/backup20201207
- /1.0/instances/gca/snapshots/backup20201208
- /1.0/instances/gca/snapshots/backup20201209
- /1.0/instances/gca/snapshots/backup20201210
- /1.0/instances/gca/snapshots/backup20201211
- /1.0/instances/gca/snapshots/backup20201212
- /1.0/instances/gca/snapshots/backup20201213
- /1.0/instances/gca/snapshots/backup20201214
- /1.0/instances/gca/snapshots/backup20201215
- /1.0/instances/gca/snapshots/backup20201216
- /1.0/instances/gca/snapshots/backup20201217
- /1.0/instances/gca/snapshots/backup20201218
- /1.0/instances/gca/snapshots/backup20201219
- /1.0/instances/gca/snapshots/backup20201220
- /1.0/instances/gca/snapshots/backup20201221
- /1.0/instances/genchem
- /1.0/instances/genchem/snapshots/backup20221109
- /1.0/instances/genchem/snapshots/backup20221110
- /1.0/instances/genchem/snapshots/backup20221111
- /1.0/instances/genchem/snapshots/backup20221112
- /1.0/instances/genchem/snapshots/backup20221113
- /1.0/instances/genchem/snapshots/backup20221114
- /1.0/instances/genchem/snapshots/backup20221115
- /1.0/instances/genchem/snapshots/backup20221116
- /1.0/instances/genchem/snapshots/backup20221117
- /1.0/instances/genchem/snapshots/backup20221118
- /1.0/instances/genchem/snapshots/backup20221119
- /1.0/instances/genchem/snapshots/backup20221120
- /1.0/instances/genchem/snapshots/backup20221121
- /1.0/instances/genchem/snapshots/backup20221122
- /1.0/instances/genchem/snapshots/backup20221123
- /1.0/instances/growthchambers
- /1.0/instances/growthchambers/snapshots/backup20221109
- /1.0/instances/growthchambers/snapshots/backup20221110
- /1.0/instances/growthchambers/snapshots/backup20221111
- /1.0/instances/growthchambers/snapshots/backup20221112
- /1.0/instances/growthchambers/snapshots/backup20221113
- /1.0/instances/growthchambers/snapshots/backup20221114
- /1.0/instances/growthchambers/snapshots/backup20221115
- /1.0/instances/growthchambers/snapshots/backup20221116
- /1.0/instances/growthchambers/snapshots/backup20221117
- /1.0/instances/growthchambers/snapshots/backup20221118
- /1.0/instances/growthchambers/snapshots/backup20221119
- /1.0/instances/growthchambers/snapshots/backup20221120
- /1.0/instances/growthchambers/snapshots/backup20221121
- /1.0/instances/growthchambers/snapshots/backup20221122
- /1.0/instances/growthchambers/snapshots/backup20221123
- /1.0/instances/hammer
- /1.0/instances/hammer/snapshots/current
- /1.0/instances/hammer/snapshots/now
- /1.0/instances/hammer/snapshots/pre_labs_domain
- /1.0/instances/haproxy
- /1.0/instances/haproxy-norton
- /1.0/instances/haproxy-trixie
- /1.0/instances/haproxy-trixie-20221129
- /1.0/instances/haproxy/snapshots/current
- /1.0/instances/haproxy/snapshots/now
- /1.0/instances/haproxy/snapshots/pre_rt_cert_update
- /1.0/instances/hardylab
- /1.0/instances/hardylab/snapshots/backup20221109
- /1.0/instances/hardylab/snapshots/backup20221110
- /1.0/instances/hardylab/snapshots/backup20221111
- /1.0/instances/hardylab/snapshots/backup20221112
- /1.0/instances/hardylab/snapshots/backup20221113
- /1.0/instances/hardylab/snapshots/backup20221114
- /1.0/instances/hardylab/snapshots/backup20221115
- /1.0/instances/hardylab/snapshots/backup20221116
- /1.0/instances/hardylab/snapshots/backup20221117
- /1.0/instances/hardylab/snapshots/backup20221118
- /1.0/instances/hardylab/snapshots/backup20221119
- /1.0/instances/hardylab/snapshots/backup20221120
- /1.0/instances/hardylab/snapshots/backup20221121
- /1.0/instances/hardylab/snapshots/backup20221122
- /1.0/instances/hardylab/snapshots/backup20221123
- /1.0/instances/high-pressure
- /1.0/instances/high-pressure/snapshots/backup20221109
- /1.0/instances/high-pressure/snapshots/backup20221110
- /1.0/instances/high-pressure/snapshots/backup20221111
- /1.0/instances/high-pressure/snapshots/backup20221112
- /1.0/instances/high-pressure/snapshots/backup20221113
- /1.0/instances/high-pressure/snapshots/backup20221114
- /1.0/instances/high-pressure/snapshots/backup20221115
- /1.0/instances/high-pressure/snapshots/backup20221116
- /1.0/instances/high-pressure/snapshots/backup20221117
- /1.0/instances/high-pressure/snapshots/backup20221118
- /1.0/instances/high-pressure/snapshots/backup20221119
- /1.0/instances/high-pressure/snapshots/backup20221120
- /1.0/instances/high-pressure/snapshots/backup20221121
- /1.0/instances/high-pressure/snapshots/backup20221122
- /1.0/instances/high-pressure/snapshots/backup20221123
- /1.0/instances/idea
- /1.0/instances/idea/snapshots/2-pre-database-install
- /1.0/instances/idea/snapshots/20221005_1151
- /1.0/instances/idea/snapshots/3-post-configuration
- /1.0/instances/idea/snapshots/4-pre-web-config
- /1.0/instances/idea/snapshots/current
- /1.0/instances/idea/snapshots/now
- /1.0/instances/idea/snapshots/post-apt-PI-install-with-failure
- /1.0/instances/idea/snapshots/post-privacyidea-apache2-install
- /1.0/instances/idea/snapshots/post-privacyidea-initial-config
- /1.0/instances/idea/snapshots/post-webui-add-networks
- /1.0/instances/idea/snapshots/pre-privacyidea-apache2-install
- /1.0/instances/idea/snapshots/pre-privacyidea-install
- /1.0/instances/idea/snapshots/pre-virtualenv-install
- /1.0/instances/idea/snapshots/pre-webui-login-diable
- /1.0/instances/isbbooking
- /1.0/instances/isbbooking/snapshots/backup20221109
- /1.0/instances/isbbooking/snapshots/backup20221110
- /1.0/instances/isbbooking/snapshots/backup20221111
- /1.0/instances/isbbooking/snapshots/backup20221112
- /1.0/instances/isbbooking/snapshots/backup20221113
- /1.0/instances/isbbooking/snapshots/backup20221114
- /1.0/instances/isbbooking/snapshots/backup20221115
- /1.0/instances/isbbooking/snapshots/backup20221116
- /1.0/instances/isbbooking/snapshots/backup20221117
- /1.0/instances/isbbooking/snapshots/backup20221118
- /1.0/instances/isbbooking/snapshots/backup20221119
- /1.0/instances/isbbooking/snapshots/backup20221120
- /1.0/instances/isbbooking/snapshots/backup20221121
- /1.0/instances/isbbooking/snapshots/backup20221122
- /1.0/instances/isbbooking/snapshots/backup20221123
- /1.0/instances/isbinstruments
- /1.0/instances/isbinstruments/snapshots/backup20221114
- /1.0/instances/isbinstruments/snapshots/backup20221115
- /1.0/instances/isbinstruments/snapshots/backup20221116
- /1.0/instances/isbinstruments/snapshots/backup20221117
- /1.0/instances/isbinstruments/snapshots/backup20221118
- /1.0/instances/isbinstruments/snapshots/backup20221119
- /1.0/instances/isbinstruments/snapshots/backup20221120
- /1.0/instances/isbinstruments/snapshots/backup20221121
- /1.0/instances/isbinstruments/snapshots/backup20221122
- /1.0/instances/isbinstruments/snapshots/backup20221123
- /1.0/instances/isbinstruments/snapshots/backup20221124
- /1.0/instances/isbinstruments/snapshots/backup20221125
- /1.0/instances/isbinstruments/snapshots/backup20221126
- /1.0/instances/isbinstruments/snapshots/backup20221127
- /1.0/instances/isbinstruments/snapshots/backup20221128
- /1.0/instances/it
- /1.0/instances/it/snapshots/backup20221027
- /1.0/instances/it/snapshots/backup20221028
- /1.0/instances/it/snapshots/backup20221029
- /1.0/instances/it/snapshots/backup20221030
- /1.0/instances/it/snapshots/backup20221031
- /1.0/instances/it/snapshots/backup20221101
- /1.0/instances/it/snapshots/backup20221102
- /1.0/instances/it/snapshots/backup20221103
- /1.0/instances/it/snapshots/backup20221104
- /1.0/instances/it/snapshots/backup20221105
- /1.0/instances/it/snapshots/backup20221106
- /1.0/instances/it/snapshots/backup20221107
- /1.0/instances/it/snapshots/backup20221108
- /1.0/instances/it/snapshots/backup20221109
- /1.0/instances/it/snapshots/backup20221110
- /1.0/instances/itwiki
- /1.0/instances/itwiki/snapshots/backup20221027
- /1.0/instances/itwiki/snapshots/backup20221028
- /1.0/instances/itwiki/snapshots/backup20221029
- /1.0/instances/itwiki/snapshots/backup20221030
- /1.0/instances/itwiki/snapshots/backup20221031
- /1.0/instances/itwiki/snapshots/backup20221101
- /1.0/instances/itwiki/snapshots/backup20221102
- /1.0/instances/itwiki/snapshots/backup20221103
- /1.0/instances/itwiki/snapshots/backup20221104
- /1.0/instances/itwiki/snapshots/backup20221105
- /1.0/instances/itwiki/snapshots/backup20221106
- /1.0/instances/itwiki/snapshots/backup20221107
- /1.0/instances/itwiki/snapshots/backup20221108
- /1.0/instances/itwiki/snapshots/backup20221109
- /1.0/instances/itwiki/snapshots/backup20221110
- /1.0/instances/lecturedemos
- /1.0/instances/lecturedemos/snapshots/current
- /1.0/instances/lecturedemos/snapshots/now
- /1.0/instances/mahertest
- /1.0/instances/mahertest/snapshots/current
- /1.0/instances/martinlab
- /1.0/instances/martinlab/snapshots/backup20221114
- /1.0/instances/martinlab/snapshots/backup20221115
- /1.0/instances/martinlab/snapshots/backup20221116
- /1.0/instances/martinlab/snapshots/backup20221117
- /1.0/instances/martinlab/snapshots/backup20221118
- /1.0/instances/martinlab/snapshots/backup20221119
- /1.0/instances/martinlab/snapshots/backup20221120
- /1.0/instances/martinlab/snapshots/backup20221121
- /1.0/instances/martinlab/snapshots/backup20221122
- /1.0/instances/martinlab/snapshots/backup20221123
- /1.0/instances/martinlab/snapshots/backup20221124
- /1.0/instances/martinlab/snapshots/backup20221125
- /1.0/instances/martinlab/snapshots/backup20221126
- /1.0/instances/martinlab/snapshots/backup20221127
- /1.0/instances/martinlab/snapshots/backup20221128
- /1.0/instances/people
- /1.0/instances/people/snapshots/backup20221114
- /1.0/instances/people/snapshots/backup20221115
- /1.0/instances/people/snapshots/backup20221116
- /1.0/instances/people/snapshots/backup20221117
- /1.0/instances/people/snapshots/backup20221118
- /1.0/instances/people/snapshots/backup20221119
- /1.0/instances/people/snapshots/backup20221120
- /1.0/instances/people/snapshots/backup20221121
- /1.0/instances/people/snapshots/backup20221122
- /1.0/instances/people/snapshots/backup20221123
- /1.0/instances/people/snapshots/backup20221124
- /1.0/instances/people/snapshots/backup20221125
- /1.0/instances/people/snapshots/backup20221126
- /1.0/instances/people/snapshots/backup20221127
- /1.0/instances/people/snapshots/backup20221128
- /1.0/instances/redirected-sites
- /1.0/instances/redirected-sites/snapshots/backup20221114
- /1.0/instances/redirected-sites/snapshots/backup20221115
- /1.0/instances/redirected-sites/snapshots/backup20221116
- /1.0/instances/redirected-sites/snapshots/backup20221117
- /1.0/instances/redirected-sites/snapshots/backup20221118
- /1.0/instances/redirected-sites/snapshots/backup20221119
- /1.0/instances/redirected-sites/snapshots/backup20221120
- /1.0/instances/redirected-sites/snapshots/backup20221121
- /1.0/instances/redirected-sites/snapshots/backup20221122
- /1.0/instances/redirected-sites/snapshots/backup20221123
- /1.0/instances/redirected-sites/snapshots/backup20221124
- /1.0/instances/redirected-sites/snapshots/backup20221125
- /1.0/instances/redirected-sites/snapshots/backup20221126
- /1.0/instances/redirected-sites/snapshots/backup20221127
- /1.0/instances/redirected-sites/snapshots/backup20221128
- /1.0/instances/rt4-3-3
- /1.0/instances/rt4-3-3/snapshots/20191022_1342_pre-rt4-fetchmail-mod
- /1.0/instances/rt4-3-3/snapshots/20191028_1559_pre-install-getmail
- /1.0/instances/rt4-3-3/snapshots/20191028_1628_post-install-and-config-getmail
- /1.0/instances/rt4-3-3/snapshots/current
- /1.0/instances/rt4-3-3/snapshots/now
- /1.0/instances/rt4-3-3/snapshots/pre-getmail-install
- /1.0/instances/rt5
- /1.0/instances/rt5/snapshots/current
- /1.0/instances/samson
- /1.0/instances/samson/snapshots/current
- /1.0/instances/samson/snapshots/now
- /1.0/instances/sites
- /1.0/instances/sites/snapshots/backup20221114
- /1.0/instances/sites/snapshots/backup20221115
- /1.0/instances/sites/snapshots/backup20221116
- /1.0/instances/sites/snapshots/backup20221117
- /1.0/instances/sites/snapshots/backup20221118
- /1.0/instances/sites/snapshots/backup20221119
- /1.0/instances/sites/snapshots/backup20221120
- /1.0/instances/sites/snapshots/backup20221121
- /1.0/instances/sites/snapshots/backup20221122
- /1.0/instances/sites/snapshots/backup20221123
- /1.0/instances/sites/snapshots/backup20221124
- /1.0/instances/sites/snapshots/backup20221125
- /1.0/instances/sites/snapshots/backup20221126
- /1.0/instances/sites/snapshots/backup20221127
- /1.0/instances/sites/snapshots/backup20221128
- /1.0/instances/skouta
- /1.0/instances/skouta/snapshots/backup20221109
- /1.0/instances/skouta/snapshots/backup20221110
- /1.0/instances/skouta/snapshots/backup20221111
- /1.0/instances/skouta/snapshots/backup20221112
- /1.0/instances/skouta/snapshots/backup20221113
- /1.0/instances/skouta/snapshots/backup20221114
- /1.0/instances/skouta/snapshots/backup20221115
- /1.0/instances/skouta/snapshots/backup20221116
- /1.0/instances/skouta/snapshots/backup20221117
- /1.0/instances/skouta/snapshots/backup20221118
- /1.0/instances/skouta/snapshots/backup20221119
- /1.0/instances/skouta/snapshots/backup20221120
- /1.0/instances/skouta/snapshots/backup20221121
- /1.0/instances/skouta/snapshots/backup20221122
- /1.0/instances/skouta/snapshots/backup20221123
- /1.0/instances/template
- /1.0/instances/template-c20-04
- /1.0/instances/template-c20-04/snapshots/current
- /1.0/instances/template/snapshots/current
- /1.0/instances/walshsrv
- /1.0/instances/walshsrv/snapshots/current
- /1.0/instances/walshsrv/snapshots/now
- /1.0/instances/web-biochem
- /1.0/instances/web-biochem/snapshots/current
- /1.0/instances/web-chem
- /1.0/instances/web-chem/snapshots/20190614_1449_pre_timezone_change
- /1.0/instances/web-chem/snapshots/current
- /1.0/instances/welab
- /1.0/instances/welab/snapshots/backup20221114
- /1.0/instances/welab/snapshots/backup20221115
- /1.0/instances/welab/snapshots/backup20221116
- /1.0/instances/welab/snapshots/backup20221117
- /1.0/instances/welab/snapshots/backup20221118
- /1.0/instances/welab/snapshots/backup20221119
- /1.0/instances/welab/snapshots/backup20221120
- /1.0/instances/welab/snapshots/backup20221121
- /1.0/instances/welab/snapshots/backup20221122
- /1.0/instances/welab/snapshots/backup20221123
- /1.0/instances/welab/snapshots/backup20221124
- /1.0/instances/welab/snapshots/backup20221125
- /1.0/instances/welab/snapshots/backup20221126
- /1.0/instances/welab/snapshots/backup20221127
- /1.0/instances/welab/snapshots/backup20221128
- /1.0/instances/wptest
- /1.0/instances/wptest-20221128
- /1.0/instances/wptest/snapshots/backup20221108
- /1.0/instances/wptest/snapshots/backup20221109
- /1.0/instances/wptest/snapshots/backup20221110
- /1.0/instances/wptest/snapshots/backup20221111
- /1.0/instances/wptest/snapshots/backup20221112
- /1.0/instances/wptest/snapshots/backup20221113
- /1.0/instances/wptest/snapshots/backup20221114
- /1.0/instances/wptest/snapshots/backup20221115
- /1.0/instances/wptest/snapshots/backup20221116
- /1.0/instances/wptest/snapshots/backup20221117
- /1.0/instances/wptest/snapshots/backup20221118
- /1.0/instances/wptest/snapshots/backup20221119
- /1.0/instances/wptest/snapshots/backup20221120
- /1.0/instances/wptest/snapshots/backup20221121
- /1.0/instances/wptest/snapshots/backup20221122
- /1.0/instances/xtal
- /1.0/instances/xtal/snapshots/current
- /1.0/profiles/default
status: Created
locations:
- none
tomp
(Thomas Parrott)
January 17, 2023, 2:39pm
18
OK so pre-trim-database is present in both lxc info <instance> (the instance snapshot DB records list) and lxc storage volume list output (the storage volume snapshot DB records).
So we just need to delete the 2 orphaned storage volume snapshot DB records with IDs
So please run:
sudo lxd sql global 'delete from storage_volumes where id in (43243, 43344)'
tomp
(Thomas Parrott)
January 17, 2023, 2:41pm
19
Can you also show me the output of sudo lxd sql global 'select * from storage_volumes_snapshots' as it seems like the storage_volumes` table is incorrectly containing snapshots. Not sure whats gone on here.
johnmaher
(John Maher)
January 17, 2023, 2:49pm
20
So I have run the command to delete records with IDs 43243 and 43344. Two rows affected.
Here’s the other command you requested:
$ lxd sql global 'select * from storage_volumes_snapshots'
| id | storage_volume_id | name | description | expiry_date |
| 43350 | 8826 | link_error | Auto repaired | 0001-01-01T00:00:00Z |
| 43351 | 8826 | 500_error | Auto repaired | 0001-01-01T00:00:00Z |
| 43352 | 8826 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43353 | 23 | pre_upload_limit_change | Auto repaired | 0001-01-01T00:00:00Z |
| 43354 | 23 | pre_updates | Auto repaired | 0001-01-01T00:00:00Z |
| 43355 | 23 | pre_update_20210305 | Auto repaired | 0001-01-01T00:00:00Z |
| 43356 | 23 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43357 | 23 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43358 | 43 | pre_updates | Auto repaired | 0001-01-01T00:00:00Z |
| 43359 | 43 | pre_update_20210305 | Auto repaired | 0001-01-01T00:00:00Z |
| 43360 | 43 | preupdate_20210806 | Auto repaired | 0001-01-01T00:00:00Z |
| 43361 | 43 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43362 | 43 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43363 | 9634 | pre_labs_domain | Auto repaired | 0001-01-01T00:00:00Z |
| 43364 | 9634 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43365 | 9634 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43366 | 60 | backup20221108 | Auto repaired | 0001-01-01T00:00:00Z |
| 43367 | 60 | backup20221109 | Auto repaired | 0001-01-01T00:00:00Z |
| 43368 | 60 | backup20221110 | Auto repaired | 0001-01-01T00:00:00Z |
| 43369 | 60 | backup20221111 | Auto repaired | 0001-01-01T00:00:00Z |
| 43370 | 60 | backup20221112 | Auto repaired | 0001-01-01T00:00:00Z |
| 43371 | 60 | backup20221113 | Auto repaired | 0001-01-01T00:00:00Z |
| 43372 | 60 | backup20221114 | Auto repaired | 0001-01-01T00:00:00Z |
| 43373 | 60 | backup20221115 | Auto repaired | 0001-01-01T00:00:00Z |
| 43374 | 60 | backup20221116 | Auto repaired | 0001-01-01T00:00:00Z |
| 43375 | 60 | backup20221117 | Auto repaired | 0001-01-01T00:00:00Z |
| 43376 | 60 | backup20221118 | Auto repaired | 0001-01-01T00:00:00Z |
| 43377 | 60 | backup20221119 | Auto repaired | 0001-01-01T00:00:00Z |
| 43378 | 60 | backup20221120 | Auto repaired | 0001-01-01T00:00:00Z |
| 43379 | 60 | backup20221121 | Auto repaired | 0001-01-01T00:00:00Z |
| 43380 | 60 | backup20221122 | Auto repaired | 0001-01-01T00:00:00Z |
| 43381 | 61 | pre-LAM-new-cert | Auto repaired | 0001-01-01T00:00:00Z |
| 43382 | 61 | pre-LAM-new-cert2 | Auto repaired | 0001-01-01T00:00:00Z |
| 43383 | 61 | pre-LAM7.6-upgrade | Auto repaired | 0001-01-01T00:00:00Z |
| 43384 | 61 | pre-LAM-7.8-upgrade | Auto repaired | 0001-01-01T00:00:00Z |
| 43385 | 61 | pre-new-cert | Auto repaired | 0001-01-01T00:00:00Z |
| 43386 | 61 | pre-LAM-8.0.1-upgrade | Auto repaired | 0001-01-01T00:00:00Z |
| 43387 | 61 | pre-ldapadmins-change | Auto repaired | 0001-01-01T00:00:00Z |
| 43388 | 61 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43389 | 61 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43390 | 21 | pre_mic_cal | Auto repaired | 0001-01-01T00:00:00Z |
| 43391 | 21 | pre-mrbs-upgrade | Auto repaired | 0001-01-01T00:00:00Z |
| 43392 | 21 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43393 | 21 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43394 | 22389 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43395 | 22389 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43396 | 22 | pre_update | Auto repaired | 0001-01-01T00:00:00Z |
| 43397 | 22 | post_update | Auto repaired | 0001-01-01T00:00:00Z |
| 43398 | 22 | pre_slider_plugin | Auto repaired | 0001-01-01T00:00:00Z |
| 43399 | 22 | post_slider_plugin | Auto repaired | 0001-01-01T00:00:00Z |
| 43400 | 22 | pre_update_20210305 | Auto repaired | 0001-01-01T00:00:00Z |
| 43401 | 22 | preupdate_20210806 | Auto repaired | 0001-01-01T00:00:00Z |
| 43402 | 22 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43403 | 22 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43404 | 6187 | backup20221108 | Auto repaired | 0001-01-01T00:00:00Z |
| 43405 | 6187 | backup20221109 | Auto repaired | 0001-01-01T00:00:00Z |
| 43406 | 6187 | backup20221110 | Auto repaired | 0001-01-01T00:00:00Z |
| 43407 | 6187 | backup20221111 | Auto repaired | 0001-01-01T00:00:00Z |
| 43408 | 6187 | backup20221112 | Auto repaired | 0001-01-01T00:00:00Z |
| 43409 | 6187 | backup20221113 | Auto repaired | 0001-01-01T00:00:00Z |
| 43410 | 6187 | backup20221114 | Auto repaired | 0001-01-01T00:00:00Z |
| 43411 | 6187 | backup20221115 | Auto repaired | 0001-01-01T00:00:00Z |
| 43412 | 6187 | backup20221116 | Auto repaired | 0001-01-01T00:00:00Z |
| 43413 | 6187 | backup20221117 | Auto repaired | 0001-01-01T00:00:00Z |
| 43414 | 6187 | backup20221118 | Auto repaired | 0001-01-01T00:00:00Z |
| 43415 | 6187 | backup20221119 | Auto repaired | 0001-01-01T00:00:00Z |
| 43416 | 6187 | backup20221120 | Auto repaired | 0001-01-01T00:00:00Z |
| 43417 | 6187 | backup20221121 | Auto repaired | 0001-01-01T00:00:00Z |
| 43418 | 6187 | backup20221122 | Auto repaired | 0001-01-01T00:00:00Z |
| 43419 | 47 | backup20221109 | Auto repaired | 0001-01-01T00:00:00Z |
| 43420 | 47 | backup20221110 | Auto repaired | 0001-01-01T00:00:00Z |
| 43421 | 47 | backup20221111 | Auto repaired | 0001-01-01T00:00:00Z |
| 43422 | 47 | backup20221112 | Auto repaired | 0001-01-01T00:00:00Z |
| 43423 | 47 | backup20221113 | Auto repaired | 0001-01-01T00:00:00Z |
| 43424 | 47 | backup20221114 | Auto repaired | 0001-01-01T00:00:00Z |
| 43425 | 47 | backup20221115 | Auto repaired | 0001-01-01T00:00:00Z |
| 43426 | 47 | backup20221116 | Auto repaired | 0001-01-01T00:00:00Z |
| 43427 | 47 | backup20221117 | Auto repaired | 0001-01-01T00:00:00Z |
| 43428 | 47 | backup20221118 | Auto repaired | 0001-01-01T00:00:00Z |
| 43429 | 47 | backup20221119 | Auto repaired | 0001-01-01T00:00:00Z |
| 43430 | 47 | backup20221120 | Auto repaired | 0001-01-01T00:00:00Z |
| 43431 | 47 | backup20221121 | Auto repaired | 0001-01-01T00:00:00Z |
| 43432 | 47 | backup20221122 | Auto repaired | 0001-01-01T00:00:00Z |
| 43433 | 47 | backup20221123 | Auto repaired | 0001-01-01T00:00:00Z |
| 43434 | 57 | backup20221114 | Auto repaired | 0001-01-01T00:00:00Z |
| 43435 | 57 | backup20221115 | Auto repaired | 0001-01-01T00:00:00Z |
| 43436 | 57 | backup20221116 | Auto repaired | 0001-01-01T00:00:00Z |
| 43437 | 57 | backup20221117 | Auto repaired | 0001-01-01T00:00:00Z |
| 43438 | 57 | backup20221118 | Auto repaired | 0001-01-01T00:00:00Z |
| 43439 | 57 | backup20221119 | Auto repaired | 0001-01-01T00:00:00Z |
| 43440 | 57 | backup20221120 | Auto repaired | 0001-01-01T00:00:00Z |
| 43441 | 57 | backup20221121 | Auto repaired | 0001-01-01T00:00:00Z |
| 43442 | 57 | backup20221122 | Auto repaired | 0001-01-01T00:00:00Z |
| 43443 | 57 | backup20221123 | Auto repaired | 0001-01-01T00:00:00Z |
| 43444 | 57 | backup20221124 | Auto repaired | 0001-01-01T00:00:00Z |
| 43445 | 57 | backup20221125 | Auto repaired | 0001-01-01T00:00:00Z |
| 43446 | 57 | backup20221126 | Auto repaired | 0001-01-01T00:00:00Z |
| 43447 | 57 | backup20221127 | Auto repaired | 0001-01-01T00:00:00Z |
| 43448 | 57 | backup20221128 | Auto repaired | 0001-01-01T00:00:00Z |
| 43449 | 26 | pre-2fa-plugin | Auto repaired | 0001-01-01T00:00:00Z |
| 43450 | 26 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43451 | 26 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43452 | 15940 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43453 | 6 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43454 | 7674 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43455 | 7674 | pre_LAM_upgrade | Auto repaired | 0001-01-01T00:00:00Z |
| 43456 | 39927 | temp | Auto repaired | 0001-01-01T00:00:00Z |
| 43457 | 39927 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43458 | 39927 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43459 | 51 | backup20221114 | Auto repaired | 0001-01-01T00:00:00Z |
| 43460 | 51 | backup20221115 | Auto repaired | 0001-01-01T00:00:00Z |
| 43461 | 51 | backup20221116 | Auto repaired | 0001-01-01T00:00:00Z |
| 43462 | 51 | backup20221117 | Auto repaired | 0001-01-01T00:00:00Z |
| 43463 | 51 | backup20221118 | Auto repaired | 0001-01-01T00:00:00Z |
| 43464 | 51 | backup20221119 | Auto repaired | 0001-01-01T00:00:00Z |
| 43465 | 51 | backup20221120 | Auto repaired | 0001-01-01T00:00:00Z |
| 43466 | 51 | backup20221121 | Auto repaired | 0001-01-01T00:00:00Z |
| 43467 | 51 | backup20221122 | Auto repaired | 0001-01-01T00:00:00Z |
| 43468 | 51 | backup20221123 | Auto repaired | 0001-01-01T00:00:00Z |
| 43469 | 51 | backup20221124 | Auto repaired | 0001-01-01T00:00:00Z |
| 43470 | 51 | backup20221125 | Auto repaired | 0001-01-01T00:00:00Z |
| 43471 | 51 | backup20221126 | Auto repaired | 0001-01-01T00:00:00Z |
| 43472 | 51 | backup20221127 | Auto repaired | 0001-01-01T00:00:00Z |
| 43473 | 51 | backup20221128 | Auto repaired | 0001-01-01T00:00:00Z |
| 43474 | 6772 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43475 | 40044 | pre-mysql-config | Auto repaired | 0001-01-01T00:00:00Z |
| 43476 | 40044 | pre-wordpress-install-script | Auto repaired | 0001-01-01T00:00:00Z |
| 43477 | 40044 | pre-ldap-plugin-install | Auto repaired | 0001-01-01T00:00:00Z |
| 43478 | 40044 | post-ldap-pre-2fa | Auto repaired | 0001-01-01T00:00:00Z |
| 43479 | 40044 | pre-ssh-update-config | Auto repaired | 0001-01-01T00:00:00Z |
| 43480 | 40044 | pre-revert | Auto repaired | 0001-01-01T00:00:00Z |
| 43481 | 40044 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43482 | 40044 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43483 | 9631 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43484 | 2 | 20190614_1449_pre_timezone_change | Auto repaired | 0001-01-01T00:00:00Z |
| 43485 | 2 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43486 | 2787 | backup20191103 | Auto repaired | 0001-01-01T00:00:00Z |
| 43487 | 2787 | backup20191102 | Auto repaired | 0001-01-01T00:00:00Z |
| 43488 | 2787 | backup20191101 | Auto repaired | 0001-01-01T00:00:00Z |
| 43489 | 2787 | backup20191031 | Auto repaired | 0001-01-01T00:00:00Z |
| 43490 | 2787 | backup20191030 | Auto repaired | 0001-01-01T00:00:00Z |
| 43491 | 2787 | backup20191029 | Auto repaired | 0001-01-01T00:00:00Z |
| 43492 | 2787 | backup20191028 | Auto repaired | 0001-01-01T00:00:00Z |
| 43493 | 2787 | backup20191104 | Auto repaired | 0001-01-01T00:00:00Z |
| 43494 | 55 | backup20221114 | Auto repaired | 0001-01-01T00:00:00Z |
| 43495 | 55 | backup20221115 | Auto repaired | 0001-01-01T00:00:00Z |
| 43496 | 55 | backup20221116 | Auto repaired | 0001-01-01T00:00:00Z |
| 43497 | 55 | backup20221117 | Auto repaired | 0001-01-01T00:00:00Z |
| 43498 | 55 | backup20221118 | Auto repaired | 0001-01-01T00:00:00Z |
| 43499 | 55 | backup20221119 | Auto repaired | 0001-01-01T00:00:00Z |
| 43500 | 55 | backup20221120 | Auto repaired | 0001-01-01T00:00:00Z |
| 43501 | 55 | backup20221121 | Auto repaired | 0001-01-01T00:00:00Z |
| 43502 | 55 | backup20221122 | Auto repaired | 0001-01-01T00:00:00Z |
| 43503 | 55 | backup20221123 | Auto repaired | 0001-01-01T00:00:00Z |
| 43504 | 55 | backup20221124 | Auto repaired | 0001-01-01T00:00:00Z |
| 43505 | 55 | backup20221125 | Auto repaired | 0001-01-01T00:00:00Z |
| 43506 | 55 | backup20221126 | Auto repaired | 0001-01-01T00:00:00Z |
| 43507 | 55 | backup20221127 | Auto repaired | 0001-01-01T00:00:00Z |
| 43508 | 55 | backup20221128 | Auto repaired | 0001-01-01T00:00:00Z |
| 43509 | 27563 | pre_shiny_update | Auto repaired | 0001-01-01T00:00:00Z |
| 43510 | 27563 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43511 | 27563 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43512 | 50 | backup20221109 | Auto repaired | 0001-01-01T00:00:00Z |
| 43513 | 50 | backup20221110 | Auto repaired | 0001-01-01T00:00:00Z |
| 43514 | 50 | backup20221111 | Auto repaired | 0001-01-01T00:00:00Z |
| 43515 | 50 | backup20221112 | Auto repaired | 0001-01-01T00:00:00Z |
| 43516 | 50 | backup20221113 | Auto repaired | 0001-01-01T00:00:00Z |
| 43517 | 50 | backup20221114 | Auto repaired | 0001-01-01T00:00:00Z |
| 43518 | 50 | backup20221115 | Auto repaired | 0001-01-01T00:00:00Z |
| 43519 | 50 | backup20221116 | Auto repaired | 0001-01-01T00:00:00Z |
| 43520 | 50 | backup20221117 | Auto repaired | 0001-01-01T00:00:00Z |
| 43521 | 50 | backup20221118 | Auto repaired | 0001-01-01T00:00:00Z |
| 43522 | 50 | backup20221119 | Auto repaired | 0001-01-01T00:00:00Z |
| 43523 | 50 | backup20221120 | Auto repaired | 0001-01-01T00:00:00Z |
| 43524 | 50 | backup20221121 | Auto repaired | 0001-01-01T00:00:00Z |
| 43525 | 50 | backup20221122 | Auto repaired | 0001-01-01T00:00:00Z |
| 43526 | 50 | backup20221123 | Auto repaired | 0001-01-01T00:00:00Z |
| 43527 | 56 | backup20221114 | Auto repaired | 0001-01-01T00:00:00Z |
| 43528 | 56 | backup20221115 | Auto repaired | 0001-01-01T00:00:00Z |
| 43529 | 56 | backup20221116 | Auto repaired | 0001-01-01T00:00:00Z |
| 43530 | 56 | backup20221117 | Auto repaired | 0001-01-01T00:00:00Z |
| 43531 | 56 | backup20221118 | Auto repaired | 0001-01-01T00:00:00Z |
| 43532 | 56 | backup20221119 | Auto repaired | 0001-01-01T00:00:00Z |
| 43533 | 56 | backup20221120 | Auto repaired | 0001-01-01T00:00:00Z |
| 43534 | 56 | backup20221121 | Auto repaired | 0001-01-01T00:00:00Z |
| 43535 | 56 | backup20221122 | Auto repaired | 0001-01-01T00:00:00Z |
| 43536 | 56 | backup20221123 | Auto repaired | 0001-01-01T00:00:00Z |
| 43537 | 56 | backup20221124 | Auto repaired | 0001-01-01T00:00:00Z |
| 43538 | 56 | backup20221125 | Auto repaired | 0001-01-01T00:00:00Z |
| 43539 | 56 | backup20221126 | Auto repaired | 0001-01-01T00:00:00Z |
| 43540 | 56 | backup20221127 | Auto repaired | 0001-01-01T00:00:00Z |
| 43541 | 56 | backup20221128 | Auto repaired | 0001-01-01T00:00:00Z |
| 43542 | 59 | backup20221114 | Auto repaired | 0001-01-01T00:00:00Z |
| 43543 | 59 | backup20221115 | Auto repaired | 0001-01-01T00:00:00Z |
| 43544 | 59 | backup20221116 | Auto repaired | 0001-01-01T00:00:00Z |
| 43545 | 59 | backup20221117 | Auto repaired | 0001-01-01T00:00:00Z |
| 43546 | 59 | backup20221118 | Auto repaired | 0001-01-01T00:00:00Z |
| 43547 | 59 | backup20221119 | Auto repaired | 0001-01-01T00:00:00Z |
| 43548 | 59 | backup20221120 | Auto repaired | 0001-01-01T00:00:00Z |
| 43549 | 59 | backup20221121 | Auto repaired | 0001-01-01T00:00:00Z |
| 43550 | 59 | backup20221122 | Auto repaired | 0001-01-01T00:00:00Z |
| 43551 | 59 | backup20221123 | Auto repaired | 0001-01-01T00:00:00Z |
| 43552 | 59 | backup20221124 | Auto repaired | 0001-01-01T00:00:00Z |
| 43553 | 59 | backup20221125 | Auto repaired | 0001-01-01T00:00:00Z |
| 43554 | 59 | backup20221126 | Auto repaired | 0001-01-01T00:00:00Z |
| 43555 | 59 | backup20221127 | Auto repaired | 0001-01-01T00:00:00Z |
| 43556 | 59 | backup20221128 | Auto repaired | 0001-01-01T00:00:00Z |
| 43557 | 11 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43558 | 44 | pre_group_import | Auto repaired | 0001-01-01T00:00:00Z |
| 43559 | 44 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43560 | 44 | pre-update-of-papercut | Auto repaired | 0001-01-01T00:00:00Z |
| 43561 | 26536 | pre-privacyidea-install | Auto repaired | 0001-01-01T00:00:00Z |
| 43562 | 26536 | pre-virtualenv-install | Auto repaired | 0001-01-01T00:00:00Z |
| 43563 | 26536 | 2-pre-database-install | Auto repaired | 0001-01-01T00:00:00Z |
| 43564 | 26536 | 3-post-configuration | Auto repaired | 0001-01-01T00:00:00Z |
| 43565 | 26536 | 4-pre-web-config | Auto repaired | 0001-01-01T00:00:00Z |
| 43566 | 26536 | post-apt-PI-install-with-failure | Auto repaired | 0001-01-01T00:00:00Z |
| 43567 | 26536 | pre-privacyidea-apache2-install | Auto repaired | 0001-01-01T00:00:00Z |
| 43568 | 26536 | post-privacyidea-apache2-install | Auto repaired | 0001-01-01T00:00:00Z |
| 43569 | 26536 | post-privacyidea-initial-config | Auto repaired | 0001-01-01T00:00:00Z |
| 43570 | 26536 | pre-webui-login-diable | Auto repaired | 0001-01-01T00:00:00Z |
| 43571 | 26536 | post-webui-add-networks | Auto repaired | 0001-01-01T00:00:00Z |
| 43572 | 26536 | 20221005_1151 | Auto repaired | 0001-01-01T00:00:00Z |
| 43573 | 26536 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43574 | 26536 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43575 | 9 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43576 | 9 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43577 | 24 | pre-mrbs-upgrade | Auto repaired | 0001-01-01T00:00:00Z |
| 43578 | 24 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43579 | 24 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43580 | 48 | backup20221109 | Auto repaired | 0001-01-01T00:00:00Z |
| 43581 | 48 | backup20221110 | Auto repaired | 0001-01-01T00:00:00Z |
| 43582 | 48 | backup20221111 | Auto repaired | 0001-01-01T00:00:00Z |
| 43583 | 48 | backup20221112 | Auto repaired | 0001-01-01T00:00:00Z |
| 43584 | 48 | backup20221113 | Auto repaired | 0001-01-01T00:00:00Z |
| 43585 | 48 | backup20221114 | Auto repaired | 0001-01-01T00:00:00Z |
| 43586 | 48 | backup20221115 | Auto repaired | 0001-01-01T00:00:00Z |
| 43587 | 48 | backup20221116 | Auto repaired | 0001-01-01T00:00:00Z |
| 43588 | 48 | backup20221117 | Auto repaired | 0001-01-01T00:00:00Z |
| 43589 | 48 | backup20221118 | Auto repaired | 0001-01-01T00:00:00Z |
| 43590 | 48 | backup20221119 | Auto repaired | 0001-01-01T00:00:00Z |
| 43591 | 48 | backup20221120 | Auto repaired | 0001-01-01T00:00:00Z |
| 43592 | 48 | backup20221121 | Auto repaired | 0001-01-01T00:00:00Z |
| 43593 | 48 | backup20221122 | Auto repaired | 0001-01-01T00:00:00Z |
| 43594 | 48 | backup20221123 | Auto repaired | 0001-01-01T00:00:00Z |
| 43595 | 52 | backup20221027 | Auto repaired | 0001-01-01T00:00:00Z |
| 43596 | 52 | backup20221028 | Auto repaired | 0001-01-01T00:00:00Z |
| 43597 | 52 | backup20221029 | Auto repaired | 0001-01-01T00:00:00Z |
| 43598 | 52 | backup20221030 | Auto repaired | 0001-01-01T00:00:00Z |
| 43599 | 52 | backup20221031 | Auto repaired | 0001-01-01T00:00:00Z |
| 43600 | 52 | backup20221101 | Auto repaired | 0001-01-01T00:00:00Z |
| 43601 | 52 | backup20221102 | Auto repaired | 0001-01-01T00:00:00Z |
| 43602 | 52 | backup20221103 | Auto repaired | 0001-01-01T00:00:00Z |
| 43603 | 52 | backup20221104 | Auto repaired | 0001-01-01T00:00:00Z |
| 43604 | 52 | backup20221105 | Auto repaired | 0001-01-01T00:00:00Z |
| 43605 | 52 | backup20221106 | Auto repaired | 0001-01-01T00:00:00Z |
| 43606 | 52 | backup20221107 | Auto repaired | 0001-01-01T00:00:00Z |
| 43607 | 52 | backup20221108 | Auto repaired | 0001-01-01T00:00:00Z |
| 43608 | 52 | backup20221109 | Auto repaired | 0001-01-01T00:00:00Z |
| 43609 | 52 | backup20221110 | Auto repaired | 0001-01-01T00:00:00Z |
| 43610 | 12 | 20191022_1342_pre-rt4-fetchmail-mod | Auto repaired | 0001-01-01T00:00:00Z |
| 43611 | 12 | 20191028_1559_pre-install-getmail | Auto repaired | 0001-01-01T00:00:00Z |
| 43612 | 12 | 20191028_1628_post-install-and-config-getmail | Auto repaired | 0001-01-01T00:00:00Z |
| 43613 | 12 | pre-getmail-install | Auto repaired | 0001-01-01T00:00:00Z |
| 43614 | 12 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43615 | 12 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43616 | 10 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43617 | 10 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43618 | 58 | backup20221109 | Auto repaired | 0001-01-01T00:00:00Z |
| 43619 | 58 | backup20221110 | Auto repaired | 0001-01-01T00:00:00Z |
| 43620 | 58 | backup20221111 | Auto repaired | 0001-01-01T00:00:00Z |
| 43621 | 58 | backup20221112 | Auto repaired | 0001-01-01T00:00:00Z |
| 43622 | 58 | backup20221113 | Auto repaired | 0001-01-01T00:00:00Z |
| 43623 | 58 | backup20221114 | Auto repaired | 0001-01-01T00:00:00Z |
| 43624 | 58 | backup20221115 | Auto repaired | 0001-01-01T00:00:00Z |
| 43625 | 58 | backup20221116 | Auto repaired | 0001-01-01T00:00:00Z |
| 43626 | 58 | backup20221117 | Auto repaired | 0001-01-01T00:00:00Z |
| 43627 | 58 | backup20221118 | Auto repaired | 0001-01-01T00:00:00Z |
| 43628 | 58 | backup20221119 | Auto repaired | 0001-01-01T00:00:00Z |
| 43629 | 58 | backup20221120 | Auto repaired | 0001-01-01T00:00:00Z |
| 43630 | 58 | backup20221121 | Auto repaired | 0001-01-01T00:00:00Z |
| 43631 | 58 | backup20221122 | Auto repaired | 0001-01-01T00:00:00Z |
| 43632 | 58 | backup20221123 | Auto repaired | 0001-01-01T00:00:00Z |
| 43633 | 20 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43634 | 20 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43635 | 25 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43636 | 25 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43637 | 27 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43638 | 27 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43639 | 1 | pre_rt_cert_update | Auto repaired | 0001-01-01T00:00:00Z |
| 43640 | 1 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43641 | 1 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43642 | 53 | backup20221027 | Auto repaired | 0001-01-01T00:00:00Z |
| 43643 | 53 | backup20221028 | Auto repaired | 0001-01-01T00:00:00Z |
| 43644 | 53 | backup20221029 | Auto repaired | 0001-01-01T00:00:00Z |
| 43645 | 53 | backup20221030 | Auto repaired | 0001-01-01T00:00:00Z |
| 43646 | 53 | backup20221031 | Auto repaired | 0001-01-01T00:00:00Z |
| 43647 | 53 | backup20221101 | Auto repaired | 0001-01-01T00:00:00Z |
| 43648 | 53 | backup20221102 | Auto repaired | 0001-01-01T00:00:00Z |
| 43649 | 53 | backup20221103 | Auto repaired | 0001-01-01T00:00:00Z |
| 43650 | 53 | backup20221104 | Auto repaired | 0001-01-01T00:00:00Z |
| 43651 | 53 | backup20221105 | Auto repaired | 0001-01-01T00:00:00Z |
| 43652 | 53 | backup20221106 | Auto repaired | 0001-01-01T00:00:00Z |
| 43653 | 53 | backup20221107 | Auto repaired | 0001-01-01T00:00:00Z |
| 43654 | 53 | backup20221108 | Auto repaired | 0001-01-01T00:00:00Z |
| 43655 | 53 | backup20221109 | Auto repaired | 0001-01-01T00:00:00Z |
| 43656 | 53 | backup20221110 | Auto repaired | 0001-01-01T00:00:00Z |
| 43657 | 27888 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43658 | 45 | backup20201207 | Auto repaired | 0001-01-01T00:00:00Z |
| 43659 | 45 | backup20201208 | Auto repaired | 0001-01-01T00:00:00Z |
| 43660 | 45 | backup20201209 | Auto repaired | 0001-01-01T00:00:00Z |
| 43661 | 45 | backup20201210 | Auto repaired | 0001-01-01T00:00:00Z |
| 43662 | 45 | backup20201211 | Auto repaired | 0001-01-01T00:00:00Z |
| 43663 | 45 | backup20201212 | Auto repaired | 0001-01-01T00:00:00Z |
| 43664 | 45 | backup20201213 | Auto repaired | 0001-01-01T00:00:00Z |
| 43665 | 45 | backup20201214 | Auto repaired | 0001-01-01T00:00:00Z |
| 43666 | 45 | backup20201215 | Auto repaired | 0001-01-01T00:00:00Z |
| 43667 | 45 | backup20201216 | Auto repaired | 0001-01-01T00:00:00Z |
| 43668 | 45 | backup20201217 | Auto repaired | 0001-01-01T00:00:00Z |
| 43669 | 45 | backup20201218 | Auto repaired | 0001-01-01T00:00:00Z |
| 43670 | 45 | backup20201219 | Auto repaired | 0001-01-01T00:00:00Z |
| 43671 | 45 | backup20201220 | Auto repaired | 0001-01-01T00:00:00Z |
| 43672 | 45 | backup20201221 | Auto repaired | 0001-01-01T00:00:00Z |
| 43673 | 14362 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43674 | 14362 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43675 | 46 | backup20221109 | Auto repaired | 0001-01-01T00:00:00Z |
| 43676 | 46 | backup20221110 | Auto repaired | 0001-01-01T00:00:00Z |
| 43677 | 46 | backup20221111 | Auto repaired | 0001-01-01T00:00:00Z |
| 43678 | 46 | backup20221112 | Auto repaired | 0001-01-01T00:00:00Z |
| 43679 | 46 | backup20221113 | Auto repaired | 0001-01-01T00:00:00Z |
| 43680 | 46 | backup20221114 | Auto repaired | 0001-01-01T00:00:00Z |
| 43681 | 46 | backup20221115 | Auto repaired | 0001-01-01T00:00:00Z |
| 43682 | 46 | backup20221116 | Auto repaired | 0001-01-01T00:00:00Z |
| 43683 | 46 | backup20221117 | Auto repaired | 0001-01-01T00:00:00Z |
| 43684 | 46 | backup20221118 | Auto repaired | 0001-01-01T00:00:00Z |
| 43685 | 46 | backup20221119 | Auto repaired | 0001-01-01T00:00:00Z |
| 43686 | 46 | backup20221120 | Auto repaired | 0001-01-01T00:00:00Z |
| 43687 | 46 | backup20221121 | Auto repaired | 0001-01-01T00:00:00Z |
| 43688 | 46 | backup20221122 | Auto repaired | 0001-01-01T00:00:00Z |
| 43689 | 46 | backup20221123 | Auto repaired | 0001-01-01T00:00:00Z |
| 43690 | 54 | backup20221114 | Auto repaired | 0001-01-01T00:00:00Z |
| 43691 | 54 | backup20221115 | Auto repaired | 0001-01-01T00:00:00Z |
| 43692 | 54 | backup20221116 | Auto repaired | 0001-01-01T00:00:00Z |
| 43693 | 54 | backup20221117 | Auto repaired | 0001-01-01T00:00:00Z |
| 43694 | 54 | backup20221118 | Auto repaired | 0001-01-01T00:00:00Z |
| 43695 | 54 | backup20221119 | Auto repaired | 0001-01-01T00:00:00Z |
| 43696 | 54 | backup20221120 | Auto repaired | 0001-01-01T00:00:00Z |
| 43697 | 54 | backup20221121 | Auto repaired | 0001-01-01T00:00:00Z |
| 43698 | 54 | backup20221122 | Auto repaired | 0001-01-01T00:00:00Z |
| 43699 | 54 | backup20221123 | Auto repaired | 0001-01-01T00:00:00Z |
| 43700 | 54 | backup20221124 | Auto repaired | 0001-01-01T00:00:00Z |
| 43701 | 54 | backup20221125 | Auto repaired | 0001-01-01T00:00:00Z |
| 43702 | 54 | backup20221126 | Auto repaired | 0001-01-01T00:00:00Z |
| 43703 | 54 | backup20221127 | Auto repaired | 0001-01-01T00:00:00Z |
| 43704 | 54 | backup20221128 | Auto repaired | 0001-01-01T00:00:00Z |
| 43705 | 21134 | pre-trim-database | Auto repaired | 0001-01-01T00:00:00Z |
| 43706 | 21134 | now | Auto repaired | 0001-01-01T00:00:00Z |
| 43707 | 21134 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43708 | 2286 | pre_data_ingestion | Auto repaired | 0001-01-01T00:00:00Z |
| 43709 | 2286 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43710 | 10479 | orig_and_patched | Auto repaired | 0001-01-01T00:00:00Z |
| 43711 | 10479 | post_RocketChat_install | Auto repaired | 0001-01-01T00:00:00Z |
| 43712 | 10479 | pre_caddy_config | Auto repaired | 0001-01-01T00:00:00Z |
| 43713 | 10479 | pre_rocket_chat_config | Auto repaired | 0001-01-01T00:00:00Z |
| 43714 | 10479 | pre3.9.3Upgrade | Auto repaired | 0001-01-01T00:00:00Z |
| 43715 | 10479 | current | Auto repaired | 0001-01-01T00:00:00Z |
| 43716 | 49 | backup20221109 | Auto repaired | 0001-01-01T00:00:00Z |
| 43717 | 49 | backup20221110 | Auto repaired | 0001-01-01T00:00:00Z |
| 43718 | 49 | backup20221111 | Auto repaired | 0001-01-01T00:00:00Z |
| 43719 | 49 | backup20221112 | Auto repaired | 0001-01-01T00:00:00Z |
| 43720 | 49 | backup20221113 | Auto repaired | 0001-01-01T00:00:00Z |
| 43721 | 49 | backup20221114 | Auto repaired | 0001-01-01T00:00:00Z |
| 43722 | 49 | backup20221115 | Auto repaired | 0001-01-01T00:00:00Z |
| 43723 | 49 | backup20221116 | Auto repaired | 0001-01-01T00:00:00Z |
| 43724 | 49 | backup20221117 | Auto repaired | 0001-01-01T00:00:00Z |
| 43725 | 49 | backup20221118 | Auto repaired | 0001-01-01T00:00:00Z |
| 43726 | 49 | backup20221119 | Auto repaired | 0001-01-01T00:00:00Z |
| 43727 | 49 | backup20221120 | Auto repaired | 0001-01-01T00:00:00Z |
| 43728 | 49 | backup20221121 | Auto repaired | 0001-01-01T00:00:00Z |
| 43729 | 49 | backup20221122 | Auto repaired | 0001-01-01T00:00:00Z |
| 43730 | 49 | backup20221123 | Auto repaired | 0001-01-01T00:00:00Z |
| 43731 | 4 | current | Auto repaired | 0001-01-01T00:00:00Z |
But, I ran the following and the other snapshots continue to show. Is that a problem?
$ lxc storage show default | grep "pitemp/snapshots"
- /1.0/instances/pitemp/snapshots/current
- /1.0/instances/pitemp/snapshots/now
- /1.0/instances/pitemp/snapshots/pre-trim-database
$ lxc storage volume list default | grep "TYPE\|pitemp"
| TYPE | NAME | DESCRIPTION | CONTENT-TYPE | USED BY |
| container | pitemp | | filesystem | 1 |
| container (snapshot) | pitemp/current | Auto repaired | filesystem | 1 |
| container (snapshot) | pitemp/now | Auto repaired | filesystem | 1 |
| container (snapshot) | pitemp/pre-trim-database | | filesystem | 1 |
| container (snapshot) | pitemp/pre-trim-database | Auto repaired | filesystem | 1 |
$ lxd sql global 'select storage_volumes.name, storage_volumes_snapshots.* from storage_volumes_snapshots join storage_volumes on storage_volumes_snapshots.storage_volume_id = storage_volumes.id' | grep "pitemp"
| pitemp | 43705 | 21134 | pre-trim-database | Auto repaired | 0001-01-01T00:00:00Z |
| pitemp | 43706 | 21134 | now | Auto repaired | 0001-01-01T00:00:00Z |
| pitemp | 43707 | 21134 | current | Auto repaired | 0001-01-01T00:00:00Z |
