lxc start container
Error: Common start logic: Failed to start device ‘eth0’: Invalid value for device option hwaddr: Invalid value, must 6 bytes of lower case hex separated by colons
OS Ubuntu: 18.04 LTS HWE LiveKernel Patching
lxd --version
3.17
It started with: Error: Get http://unix.socket/1.0: EOF but the error suddenly disappeared.
Cluster Status
| NAME | URL | DATABASE | STATE | MESSAGE |
| lxd-1 | https://192.168.100.1:8443 | YES | ONLINE | fully operational |
| lxd-2 | https://192.168.100.2:8443 | YES | ONLINE | fully operational |
| lxd-3 | https://192.168.100.3:8443 | YES | ONLINE | fully operational |
I will block future snap updates from applying automatically. This is annoying every time on production containers.
Debug Output
DBUG[09-11|07:54:20] Failure for task operation: 49f072c2-8e29-450d-8c20-883d097cdf52: Common start logic: Failed to start device ‘eth0’: Invalid value for device option hwaddr: Invalid value, must 6 bytes of lower case hex separated by colons
“type”: “async”,
“status”: “Operation created”,
“status_code”: 100,
“operation”: “/1.0/operations/49f072c2-8e29-450d-8c20-883d097cdf52”,
“error_code”: 0,
“error”: “”,
“metadata”: {
“id”: “49f072c2-8e29-450d-8c20-883d097cdf52”,
“class”: “task”,
“description”: “Starting container”,
“created_at”: “2019-09-11T07:54:20.826998128+02:00”,
“updated_at”: “2019-09-11T07:54:20.826998128+02:00”,
“status”: “Failure”,
“status_code”: 400,
“resources”: {
“containers”: [
“/1.0/containers/container”
“metadata”: null,
“may_cancel”: false,
“err”: “Common start logic: Failed to start device ‘eth0’: Invalid value for device option hwaddr: Invalid value, must 6 bytes of lower case hex separated by colons”,
“location”: “lxd-3”
DBUG[09-11|07:54:20] Handling ip=@ user= method=GET url=/1.0/operations/49f072c2-8e29-450d-8c20-883d097cdf52
Config Container
host:~$ lxc config show --expanded CONTAINER
image.architecture: amd64
image.description: ubuntu 18.04 LTS amd64 (release) (20190627.1)
image.label: release
image.os: ubuntu
image.release: bionic
image.serial: “20190627.1”
image.version: “18.04”
limits.cpu: “3”
limits.memory: 8192MB
security.privileged: “true”
volatile.base_image: 6ae1c6e92017402f1aee655fa8d785ee9d2337a3369d76115cecad5e7a303e07
volatile.eth0.hwaddr: 00:55:56:00:AA:23
volatile.eth0.name: eth0
volatile.idmap.base: “0”
volatile.idmap.current: ‘[]’
volatile.idmap.next: ‘[]’
volatile.last_state.idmap: ‘[]’
nictype: macvlan
parent: enp0s31f6
pool: local
- macvlan
description: “”
I have 1 node without online containers to troubleshoot (reboot etc.). I don’t want to stop the other running containers.
