Hi All,
I’m following a basic web instruction on using lxc and I created an unprivileged container named c1. When I try to start c1, it fails. The specific line in the logfile is:
lxc-start c1 20201025225547.195 ERROR network - network.c:lxc_create_network_unpriv_exec:2657 - lxc-user-nic failed to configure requested network: cmd/lxc_user_nic.c: 1208: main: Quota reached
my ~/.config/lxc/default.conf file is:
lxc.idmap = u 0 100000 65536
lxc.idmap = g 0 100000 65536
lxc.net.0.type = veth
lxc.net.0.link = lxcbr0
ifconfig shows the ‘lxcbr0’ network connection is up:
lxcbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 10.0.3.1 netmask 255.255.255.0 broadcast 0.0.0.0
ether 00:16:3e:00:00:00 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
My system is Linux Mint 20.0 running linux kernel 5.4.0-52-generic. I’m not sure what additional info to add. The log message doesn’t leave much to go on. Neither syslog or ‘journalct l |grep lxc’ showed any clues. I’ve looked at the forum posts that were similar but none were about the network or ‘quota’ errors.
Thanks for any info you could share.
Best regards,
Bob G.
