Hi all,
I’m referring to this issue: https://github.com/lxc/lxd/issues/3687
Right now, I have the systemd fs mounted and if I install a fresh gentoo container I’m able to stop it.
While I’m doing some modification in the gentoo container (basically I recompiled the world), then I’m unable to stop it. The “lxc stop” command freezes; this is the verbose/debug:
ago@ctgate ~ $ lxc stop template2 --verbose --debug
DBUG[02-12|17:36:10] Connecting to a local LXD over a Unix socket
DBUG[02-12|17:36:10] Sending request to LXD etag= method=GET url=http://unix.socket/1.0
DBUG[02-12|17:36:10] Got response struct from LXD
"config": {
"images.auto_update_interval": "0"
"api_extensions": [
"storage_zfs_remove_snapshots",
"container_host_shutdown_timeout",
"container_stop_priority",
"container_syscall_filtering",
"auth_pki",
"container_last_used_at",
"etag",
"patch",
"usb_devices",
"https_allowed_credentials",
"image_compression_algorithm",
"directory_manipulation",
"container_cpu_time",
"storage_zfs_use_refquota",
"storage_lvm_mount_options",
"network",
"profile_usedby",
"container_push",
"container_exec_recording",
"certificate_update",
"container_exec_signal_handling",
"gpu_devices",
"container_image_properties",
"migration_progress",
"id_map",
"network_firewall_filtering",
"network_routes",
"storage",
"file_delete",
"file_append",
"network_dhcp_expiry",
"storage_lvm_vg_rename",
"storage_lvm_thinpool_rename",
"network_vlan",
"image_create_aliases",
"container_stateless_copy",
"container_only_migration",
"storage_zfs_clone_copy",
"unix_device_rename",
"storage_lvm_use_thinpool",
"storage_rsync_bwlimit",
"network_vxlan_interface",
"storage_btrfs_mount_options",
"entity_description",
"image_force_refresh",
"storage_lvm_lv_resizing",
"id_map_base",
"file_symlinks",
"container_push_target",
"network_vlan_physical",
"storage_images_delete",
"container_edit_metadata",
"container_snapshot_stateful_migration",
"storage_driver_ceph",
"storage_ceph_user_name",
"resource_limits",
"storage_volatile_initial_source",
"storage_ceph_force_osd_reuse",
"storage_block_filesystem_btrfs",
"resources",
"kernel_limits",
"storage_api_volume_rename",
"macaroon_authentication",
"network_sriov",
"console",
"restrict_devlxd",
"migration_pre_copy",
"infiniband",
"maas_network"
"api_status": "stable",
"api_version": "1.0",
"auth": "trusted",
"public": false,
"auth_methods": [
"tls"
"environment": {
"addresses": [],
"architectures": [
"x86_64",
"i686"
"certificate": "-----BEGIN CERTIFICATE-----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\nmwcrdQ==\n-----END CERTIFICATE-----\n",
"certificate_fingerprint": "92d91a065b9bb83c62a719ba815756e778e657e8daf030f0d14e7f5aaf66d27d",
"driver": "lxc",
"driver_version": "2.1.1",
"kernel": "Linux",
"kernel_architecture": "x86_64",
"kernel_version": "4.9.74-gentoo",
"server": "lxd",
"server_pid": 2623,
"server_version": "2.21",
"storage": "dir",
"storage_version": "1"
DBUG[02-12|17:36:10] Connected to the websocket
DBUG[02-12|17:36:10] Sending request to LXD etag= method=PUT url=http://unix.socket/1.0/containers/template2/state
"action": "stop",
"timeout": -1,
"force": false,
"stateful": false
DBUG[02-12|17:36:10] Got operation from LXD
"id": "80591ad9-da24-4ec1-ac21-722249b3766d",
"class": "task",
"created_at": "2018-02-12T17:36:10.857268356+01:00",
"updated_at": "2018-02-12T17:36:10.857268356+01:00",
"status": "Running",
"status_code": 103,
"resources": {
"containers": [
"/1.0/containers/template2"
"metadata": null,
"may_cancel": false,
"err": ""
DBUG[02-12|17:36:10] Sending request to LXD etag= method=GET url=http://unix.socket/1.0/operations/80591ad9-da24-4ec1-ac21-722249b3766d
"class": "task",
"status_code": 103,
"resources": {
"containers": [
"metadata": null,
"err": ""
In short this isn’t an LXD issue and this is the reason because I’m not continuing to write into the github ticket.
This is a container issue but I’d like to understand why it fails to stop
