Hello, I am a student currently doing an internship at my university. For the past two months, I’ve been working on updating our university’s application (remotelabz) to replace privileged containers with unprivileged ones.
I need help with a problem I’ve been facing for a week now.
I cannot get a container to start.
The Issue
After copying the container, I try to start it via systemd-run and lxc-start, but it fails silently with unclear logs. I suspect something is wrong with how I’m preparing or launching the container in the unprivileged context — maybe a permission issue, or a missing runtime config.
Am I missing a step or misconfiguring the container or systemd environment?
Any help is greatly appreciated. Thanks!
Context
I need to run a script as a privileged user that uses the command sudo -u unprivileged_user to interact with unprivileged containers. The workflow is:
- A base container (
Migration) is created usinglxc-createas the unprivileged user (remotelabz-lxc) viasystemd-run --user. - I copy this base container using
lxc-copy(didn’t achieve to do it from unpriviledge user).
(sudo lxc-copy -n Migration -P /home/remotelabz-lxc/.local/share/lxc -N 7139d2d2-69ef-4883-a26b-8099ba51bf60) - After that, I try to start the copied container using the following command:
systemd-run --unit=lxc-7139d2d2 --user --scope -p "Delegate=yes" -- lxc-start -n 7139d2d2-69ef-4883-a26b-8099ba51bf60 -f /opt/remotelabz-worker/instances/user/11a4ee00-7470-4210-9045-bf66e8be0fb7/9a2b1c0f-8ad9-43c6-b5ad-afbfd39f501f/7139d2d2-69ef-4883-a26b-8099ba51bf60/template.txt-new
But the container fails to start, and I’m not sure if the issue comes from a misconfiguration in the container setup or the way I handle unprivileged users and permissions.
lxc-checkconfig :
LXC version 5.0.3
Kernel configuration not found at /proc/config.gz; searching...
Kernel configuration found at /boot/config-6.8.0-59-generic
--- Namespaces ---
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled
--- Control groups ---
Cgroups: enabled
Cgroup namespace: enabled
Cgroup v1 mount points:
Cgroup v2 mount points:
- /sys/fs/cgroup
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup cpuset: enabled
--- Misc ---
Veth pair device: enabled, not loaded
Macvlan: enabled, not loaded
Vlan: enabled, not loaded
Bridges: enabled, loaded
Advanced netfilter: enabled, loaded
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled, not loaded
FUSE (for use with lxcfs): enabled, not loaded
--- Checkpoint/Restore ---
checkpoint restore: enabled
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: enabled
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: enabled
CONFIG_NETLINK_DIAG: enabled
File capabilities: enabled
template of the container :
lxc.arch = linux64
lxc.rootfs.path = dir:/home/remotelabz-lxc/.local/share/lxc/7139d2d2-69ef-4883-a26b-8099ba51bf60/rootfs
lxc.uts.name = 7139d2d2-69ef-4883-a26b-8099ba51bf60
# Network configuration
lxc.net.0.type = veth
lxc.net.0.name = eth0
lxc.net.0.link = br-9a2b1c0f
lxc.net.0.flags = up
lxc.net.0.ipv4.address = 10.11.0.17/24
lxc.net.0.ipv4.gateway = 10.11.0.30
lxc.net.0.hwaddr = 00:2D:EB:0F:8C:F6
lxc.hook.version = 1
lxc.apparmor.profile=unconfined
lxc.apparmor.allow_nesting=1
lxc.idmap = u 0 362144 65536
lxc.idmap = g 0 362144 65536
step done to setup the unpriviledge user :
sudo adduser --disabled-password --gecos "" remotelabz-lxc
echo "remotelabz-lxc:$FREE_RANGE:65536" >> /etc/subuid
echo "remotelabz-lxc:$FREE_RANGE:65536" >> /etc/subgid
echo "remotelabz-lxc veth lxcbr0 10" | sudo tee -a /etc/lxc/lxc-usernet
loginctl enable-linger remotelabz-lxc
mkdir -p /var/lib/systemd/linger
touch /var/lib/systemd/linger/remotelabz-lxc
chown remotelabz-lxc: /var/lib/systemd/linger/remotelabz-lxc
sudo -u remotelabz-lxc mkdir -p /home/remotelabz-lxc/.config/lxc
sudo -u remotelabz-lxc cp /etc/lxc/default.conf /home/remotelabz-lxc/.config/lxc/default.conf
cat <<EOF | sudo -u remotelabz-lxc tee -a /home/remotelabz-lxc/.config/lxc/default.conf > /dev/null
lxc.net.0.link = lxcbr0
lxc.apparmor.profile = unconfined
lxc.apparmor.allow_nesting = 1
lxc.idmap = u 0 $FREE_RANGE 65536
lxc.idmap = g 0 $FREE_RANGE 65536
EOF
chmod +x /home/remotelabz-lxc
return of the command with debug options, lxc-usernet is modified and i’ve checked cgroup permissions and the user have the correct right, which make me unable to understand the source of the problem.
Running as unit: lxc-7139d2d2.scope; invocation ID: c3c9a735e07a4d7a859b0443c5d8a2f0
lxc-start: 7139d2d2-69ef-4883-a26b-8099ba51bf60: ../src/lxc/cgroups/cgfsng.c: __cgfsng_delegate_controllers: 3341 Device or resource busy - Could not enable "+cpu +memory +pids" controllers in the unified cgroup 9
lxc-start: 7139d2d2-69ef-4883-a26b-8099ba51bf60: ../src/lxc/network.c: lxc_create_network_unpriv_exec: 2990 lxc-user-nic failed to configure requested network: ../src/lxc/cmd/lxc_user_nic.c: 1211: main: Quota reached
lxc-start: 7139d2d2-69ef-4883-a26b-8099ba51bf60: ../src/lxc/start.c: lxc_spawn: 1840 Failed to create the network
lxc-start: 7139d2d2-69ef-4883-a26b-8099ba51bf60: ../src/lxc/start.c: __lxc_start: 2107 Failed to spawn container "7139d2d2-69ef-4883-a26b-8099ba51bf60"
lxc-start: 7139d2d2-69ef-4883-a26b-8099ba51bf60: ../src/lxc/tools/lxc_start.c: main: 306 The container failed to start
lxc-start: 7139d2d2-69ef-4883-a26b-8099ba51bf60: ../src/lxc/tools/lxc_start.c: main: 311 Additional information can be obtained by setting the --logfile and --logpriority options
