I recently started using LXC with unprivileged containers on ubuntu 20.04.
But I ran into problems with resource limits via cgroup.
lxc-start container 20200427171713.527 ERROR cgfsng - cgroups/cgfsng.c:cg_legacy_set_data:2687 - No such file or directory - Failed to setup limits for the "cpuset" controller. The controller seems to be unused by "cgfsng" cgroup driver or not enabled on the cgroup hierarchy
lxc-start container 20200427171713.527 ERROR cgfsng - cgroups/cgfsng.c:cgfsng_setup_limits_legacy:2731 - No such file or directory - Failed to set "cpuset.cpus" to "1"
the memory limit “works” but it can be exceed anytime, the cpus limitation does not work and it runs into a fatal error.
Your cpuset cgroup isn’t writable for fully unprivileged containers. By default Ubuntu only enables freezer, memory, and name=systemd controllers. You can change that setting by editing:
